I’m using the Aqara switch with neutral, and when I use the (fysical) switch the switch status does not get updated in Homey (this works with HA).
For example if I turn the light on or off with the fysical switch, I dont see an event in Homey, If I use a card to test if the light is on, I says its off. Is there something I might have overlooked?
use-case: I like to turn-on the lamp with a motion detector and turn it off again after a 60 seconds, except when its turned of with fysical switch, then It should not be turned off.
Kind regards,
Renee
