Aqara vibration sensor and window shutters flow
Hi there,
can someone help me with a flow?
What I want is to let the shutters (somfy) go up when the sun is down but only when my tilted window is closed. If got a aqara vibration sensor mounted on the window and it detects the angle if the window is open.
I thought to create a flow: When sunset and Sensor angle is … then close the shutter but I cant select anything but battery level in the vibration sensor.
Maybe someone had an idea?
Regards Marius
Get urself a logic card in the AND part and pick “Is less than” . Then find the tag of the sensor:
chrome_2019-06-26_21-04-56
Great that did the trick thanks !!!
Anytime.
