Aqara Thermostat w200 (matter) not displaying in widget
Hello all I added the w200 via matter but it does not show up under the widget for thermostat I verify it listed as a device type any ideas
Photos added
I miss this setting in your 'Advanced settings" screenshot:
which shows to me Homey doesn’t “see” the temperature sensor.
Can you show a screenshot of the capabilities?
To view those, go to
https://tools.developer.homey.app/tools/devices
and enter the device name in the filter bar on top.
I"m also curious about the device class, which also will be shown.
Example:
On my phone I’ll get a better screenshot but here
The device class is Bridge, instead of Thermostat, but that probably doesn’t matter;
To run some tests, I created a virtual device with device class ‘Scooter’, with the minimal needed capabilities for a thermostat, being ‘measure_temperature’ and ‘target_temperature’.
I can add my test thermostat it to the dash as well.
It should look like this when you longpress the device:
Does your thermostat look like that, Ryan, when you longpress the device tile in the Homey app? It can be colored black/blue/orange.
Yes the card is working fine it the widget that’s not working I think it’s the class
I see. What else could be wrong idk
It’s odd, because this appeared to work, I could add the ‘Scooter’ class thermostat to the dash:
Because it’s a Matter thermostat, and Matter is built-in, you’d report this issue to homey.app/support.
You’d best point them to this topic to show what we’ve tried.
Looking at a w200 to replace my Nest. Found a few YouTube videos and looks a neat thermostat being able to play notifications through it as well as view camera feeds .etc
With the w200 connected with matter is any of this possible with homey flows (sending notifications,camera feeds) or is it only available as a thermostat?
It’s currently only available as a Thermostat Hub and I should mention it does not work with the climate widget but I hoping homey will fix that soon
