Aqara Hub M100 installed. Just info :-)
Installed Aqara Hub M100 to Homey Pro as matter device.
I had too many zigbee devices. Some of my devices disappeared.
Moved/added Aqara temperature/humidity and Aqara single button to the M100 without problems
They end up in homey as matter devices and not zigbee devices.
Probably because i added the M100 as matter.
Have not moved any more devices to the M100 yet.
This is just info to those who might do the same :slight_smile:
You are aware that the maximum zigbee devices you can add to that is 20?
Emile once wrote a Pro 2023 should be capable of controlling “up to” 200 zigbee devices in perfect conditions.
Now let’s divide that by 2 to get realistic, 100 devices:
How many is too many in your case?
Just curious!
I had 16 at one time but then 2 simply disappeared
No matter how many times i tried added the two missing devices the could not get them back.
Including changing battery of course. Standing besides the homey pro etc.
I have no zigbee bridges only enddevices according to homey development
Just put in the M100 and they connected to the M100 without any problems and even with the old batteries :slight_smile:
No but problem for me :slight_smile:
Oh, that’s odd. The 2 devices might have been dangling on the end of the range?
When starting with Homey, I’ve had 12 Aqara sensors w/o additional zigbee routers throughout my home, it ran pretty stable @ Pro 2019. Distances were 4 - 5 meters max, 1 walls and/or 1 concrete ceiling in between. One sensor inside a freezer.
Again just out of curiosity, did you try to solve it, or was immediately adding a M100 the ‘solution’?
I can imagine when you tried several things w/o any luck, you buy an other zigbee controller in the end :wink:
Yes it was odd :frowning:
They were the furthest from the Pro but had worked for months until they suddenly disappeared.
That is why i thought batteries first.
Even a meter from the Pro 2023 with new batteries it could not find them again so distance should not be a problem.
Also turned off the Pro one hour so the zigbee devices should rethink the route to the Pro.
No luck …
The devices where in the scripts and device list but there simply was no data received.
Also tried a repair device with no luck.
That is why i deleted the devices and tried to add the devices again with no luck.
I could probably have done a factory reset but did everything from scratch but have so many scripts that i did not have time for that.
I could not think of other things to test so added a aqara hub to the aqara devices and everything worked :slight_smile:
