Hi, there are many devices in the Aqara and XiaomiMI Home app but doorbell G410 is missing… Anybody knows the reason behind or workaround to the the G410?
Thx.
Thx.
Resurrecting an old thread, but does anyone know if it is possible to bring the Aqara G410 into Homey Pro?
I also wanna know if something is possible. Saw some solutions using HomeKit control, but in no case I wanna lose the apple home secure video function. So anybody knows if it is possible to have the Aqara G410 in Homey + HomeKit with the secure video function
I’m not sure if this is the solution you guys are looking for, but this is how I managed to get doorbell triggers working in Homey using Aqara and Matter.
Open Profile → Connected Ecosystems → Matter
Select Add to another ecosystem
Add the Aqara Hub G410 (410 Hub) to Homey via Matter
Next, expose the doorbell events:
Go to Profile → Connected Ecosystems → Matter
Open Scene & Signal Sync
Create a new Signal
IF → Doorbell ringing
THEN → Add to Matter
Give it a clear name, e.g. “Doorbell Pressed”
The newly created Matter signal will now appear as a trigger
You can use it directly in Flows
Hope this helps ![]()
Thank you, I will give this a go at the weekend
It works perfectly, if I press ring, a voice comes to my Google Nest 2 via Homey Pro and tablet. Is it possible to create another scene, or just when the doorbell rings, something like this, so that if someone stands in front of the doorbell but doesn’t ring, it says some message that someone is standing in front of the door?
I managed to expose the signal from the doorbell directly to Homey Pro and created a Flow where, when someone presses the doorbell, Sonos plays a sound and I receive a notification on my phone.
PS: I created the signal directly in the Aqara doorbell itself, not through the Aqara M3 Hub.
The notification works every time, but the Sonos sound doesn’t always play.
Has anyone managed to get this working reliably? I’d really appreciate it if someone could share how they set it up. Thanks!
short question please…i have a cam G5 and use the same way for the signals, after i have done the settings like described above in the Aqara App i must add a new matter device in Homey…so i create a matter code in the Aqara App and ad this device into Homey..is this procedure right because you wrote:
or is there a other way which i currently not understand?
maybe this thread is the right one for my question but if anyone has an input i would apriziate it-thx Aqara G5 Pro's Capabilities in Homey
