[App][Widget] Zone climate widget app
Thanks for the detailed reporting, I’ll give them a look over :+1:
You’re welcome. but seriously I have to say a big “thank you” because you even making this attempt to add these triggers.
Would it be possible to lower the threshold of The average temperature trigger from 0.5 degrees Celsius to at least 0.3 degrees Celsius please because the average doesn’t change so quickly with a few devices measuring temperature in the same zone and so a trend is not so noticeable then if it stays at 0.5 degrees Celsius.
The insight looks flat. :person_shrugging:t2:
Humidity with 2% looks fine as average threshold at this moment.(Although 1.5% or 1.2% as average humidity trigger threshold would probably work better to gather more data samples for the trend calculation).
Co2 I don’t know (yet) :person_shrugging:t2:
I jest published the new version to test:
I hope it solves the triggering problem and used your suggested thresholds.
Let me know how that works :slight_smile:
Thanks for the valuable feedback.
Dear @Kaoh Thank you very much ! (And my apologies that I didn’t respond sooner).
(I just returned from a 2 weeks business trip. And will test & use it the next few days but it looks good as you could see my insights of my outside zone “Terras”with currently 2 Temperature sensors. (3rd one is excluded from zone climate because its battery is low and only erratic gives strange values ).
And the Humidity looks also good :+1:t2:.
Hi Kaoh,
Thanks for this app. The widget is nice as a quick look on a dashboard. However, the flow cards are what I’m struggling with. I have a flow where When the comfort level changes, I flow through testing for each comfort level from Very Cold to Hot. I test each one, if true then it takes the appropriate actions, if it’s false, then I go to the next comfort level. Rinse and repeat. However, at the last comfort level in the chain, there are certain cases where the temperature and humidity values have failed all comfort level tests.
Is this intended behavior, a gap in the Comfort Levels, or a bug? It doesn’t happen often, and if my flow fails all comfort levels, I take no action. So, it’s not a huge deal.
Thanks for all of your time and effort.
Good catch, the comfort level can actually have 24 levels due to the combination of temp and humidity. So I added a second of this condition cards for the humidity comfort, combined they allow you to check all 24, but the temp one now should hit one of the options always.
Thanks for finding this one.
Hi all, I just released a new version.
It is just a rework to make it purely event driven instead of polling based.
This should result in better responses to changes on your devices and more importantly it takes much less CPU and MEM on your homey.
Some great updates are not functional :wink:
