[APP] Shelly Control - Smart home automation is that easy!
There is no need to migrate your existing devices to the new app, you can just keep using it as is!
Absolutely not! As you can keep using the old app, you can also keep using your favourite gen1 devices!
We will keep maintaining the app as long as enough users are still using it. It is actually open source, so even if we stop in the far future, the community or you can still use it.
We do not, as it simply isn’t possible with Homey without requesting full system API access which we obviously do not want. And as the old app can still be used next to the new one, we also believe that such a migration is not even needed.
@drenso
Hello, I’ve been using the Presence Gen 4 successfully for a few days now.
But as of today, it’s no longer accessible; the following message appears, as shown in the image. What does “Initializing…” mean? Unfortunately, the app doesn’t have a feature to troubleshoot the device, as is common in some other apps. What can/should I do?
The app was updated today to fix an issue with the Input component. Are you running the latest version? If so, it is probably best to try to restart the app, sometimes Homey messes with the updates… Otherwise you can generate an app diagnostics report from the app settings.
Thanks for the tips, but I’ve already tried all of that.I have the latest version of the app, and I’ve already restarted it several times.
I’ll go ahead and submit a bug report then.
7ac981e2-25ee-4235-9d97-ccc43c07b4c8
just got my Shelly pill and to temperature sensors in the mail today, unfortunately I cannot add them to homey yet. Any roadmap for this little thing?
Can you please send us an email with that report id? That way our system automatically retrieves the relevant report from Homey and we can help you best! (you should have also gotten an email stating something similar.)
Everything will become available at some point, but we do prioritise devices that are getting requested more often (which was the case with the presence sensor, we got multiple requests in a short period of time). So, make sure to send us an email so that our counts are up to date! That way we can also let you know when the device you’ve requested is added to the app.
Overhere a Pill request as well!!! :wink: Currently planning on heating a water buffer controlled with a Pro3, but stuck because the Pill isn’t supported yet! Love to complete the project!
The Pill is supported now with our latest release :+1:t2:
Hi there
I’m still struggling to add pill using latest app version. Just says in the popup that no suitable device config can be found.
Cheers
Dan
Apologies for missing key info:
Shelly app version 3.63.2
Pill version S3SN-0U53X
Pill firmware 20251024-125919/g3d9429c
I’m adding it as “Any Shelly WiFi Device”, it appears as “ShellyPill-deviceid”, but once I press “Continue” I see popup with error
That’s the other (old) Shelly app. Install the new one here:
Ah, that makes sense. This experimental app does recognise my pill now. All sorted now. Thanks a lot for a swift response :+1:
The pill is working now as expected. Hover I have new issues with paired Shelly Flood Gen4 over Zigbee. When alert goes off it is visible in Homey and so flows can be triggered. However in many cases Homey is not resetting the flood state and keeps showing flood state even when buzzer goes silent. Any advice would be greatly appreciated. Should I try Matter instead? Cheers
is there a plan and timeline for adding Flood S to the app?
Thanks
In case of anyone needing to fix flows due to device/app replacement: the “flow-fix-script” by MartijnPoppen has evolved to a brilliant new app now..
It really works like a charm
https://homey.app/a/app.l4m.flowconverter/
Unfortunately not on my Pro 2019, it says it’s not compatible
Correct, Sven, it depends on the local API feature of the newer Pro models.
However, the original script (which the aforementioned app is based on) does the trick as well, including @ Pro 2016-2019 models plus Homey Cloud:
Hi there
I guess this is first vote request to add support for Shelly Plus RGBW PM.
Currently using both Shelly and Shelly Control apps but wouldn’t be so cool just to have everything in single Shelly Control app? :slight_smile:
Thanks
I am using a Shelly Color Bulb Gen3 and Homey Pro.
The bulb is detected by the Shelly app, but pairing fails with:
“No suitable device config found. This device might not be supported yet.”
Device information:
  • Model: S3BL-C010007AEU
  • App: RGBCCTBulbG3
  • Gen: 3
  • Firmware: 1.8.99-rgbcctbulbg3prod4
  • Hostname: shellycolorblbg3-907069491720
The device is fully reachable via LAN and RPC. Homey detects it, but apparently no matching driver exists.
Could support for Shelly Color Bulb Gen3 (RGBCCTBulbG3) be added to the Shelly app?
Thank you.
Looks like you are using the older app: if you use the link in the topic start here to install Shelly Control that bulb should be supported.
