It took 5 days, but I finally received that it’s on the list, one hour ago. ![]()
I have a Gen4 presence sensor. I can see the values changing, but the triggers don’t work within a flow. When I test the flow manually from here, it works perfectly—so something clearly isn’t functioning as it should. How can I fix this? Or is it a bug? The presence sensor is connected via Wi-Fi.
I also have a Gen4 presence sensor and it works. But I can’t see all the flow cards, just the card for detection. What about Illuminance and so on?
The zone names also doesn’t apear in homey, just zone 1 to 10.
Can anyone help me, what did I wrong?
The functionality depends on which protocol you used to integrate the presence sensor. If you used Matter, then according to the App Store, there are currently only Flow cards available for motion. If you use Wi-Fi or Zigbee, there are significantly more Flow cards available.
I use Zigbee. Do you see all cards according to the App Store?
Now I tried LAN as connection type and it works, I can see all card as metioned in the store.
I have a vpn connection to another network and can see Shelly’s in the other location and open their website. I can’t add them in homey as they are not in the same subnet.
Any option to achieve this?
I don’t actually have the presence sensor myself, I just looked it up in the App Store.
In Zigbee mode, there should actually be a large number of Flow cards available, at least according to the information in the App Store.
Are you sure you connected the sensor via Zigbee?
If so, it might be a bug. You should probably ask the app developer.
Hi everyone,
I’ve moved just two devices over to Shelly Control so far and was really looking forward to trying firmware updates. With this small setup, I’ve run into a few things and wondered how it’s been going for others.
I updated a Wave 1PM Mini from 11.5.0 to 14.3.0 with Homey right next to it. Homey reported a failure on both attempts, and the device became unreachable. After waiting about an hour, I power-cycled it and Homey, which brought it back online. The update did actually succeed: the device’s Advanced Settings now show the new firmware version, although Homey’s timeline still shows two failed updates.
The other device I’ve moved over is a Zigbee Gen4 1PM Mini. Strangely, these two devices are never reachable at the same time: one always shows “No response.” Restarting the app sometimes switches which one works, but I haven’t managed to get both working together. The Wave also isn’t reporting power or energy readings.
I’ve emailed support with the details, but I’d love to hear about your experiences too. Have firmware updates worked smoothly for you? Has anyone seen similar availability or reporting issues?
Thanks for reading and for any experiences or tips you can share! And a big thank you to the developer for all the work on the app ![]()
No, I’ve registered that as a Zigbee device
After updating my Shelly Wave 1PM Mini, I noticed that Detached Mode appeared under Advanced Settings. When I enable it, the related Flow cards become available: Short Press, Double Press, Long Press, and Hold.
I’m using it with a momentary switch, but unfortunately, none of these Flow triggers seem to work. Something definitely changes when I enable Detached Mode, though, because the physical switch no longer turns the lights on or off either.
I’ve also tried restarting the device from the Maintenance menu, but that didn’t help.
Is anyone else experiencing this issue, or has anyone managed to get it working?
Is it just me who still have issues adding EU version of I4 Gen 3?
Cant find it - even if I chose the correct product when adding the device - it cant be found - do I need to factory reset the product in the Shelly App?
