I also am curious about the New app. Please do not hestitate to publish it.
I really would like to be able to connect our comfoconnectpro with Homey
Hi!
Any luck posting the app in the homey app section? Would be awesome if it’s available for everyone!
Hi!
Did you get a chance to put the app in the app list? Would be awesome if it’s there and that we finally can control the comfoconnect in a stable way.
Thanks!
I have installed your app localy. but it doesn’t work .our comfoconnect pro isn’t found during pair session.
I have not seen a option to enter ip-adress, pin etc. how can i solve that?
[/quote]
@Henk_Feenstra No sorry I didn’t push the app to the store.
The git repo is here it has installation instructions
npm install -g homey
git clone ``https://github.com/Codeneos/homey-zehnder-comfoair.git
cd homey-zehnder-comfoair
npm install
@H_van_Barneveld In order for the library to find the comfo-connect box it needs to be on the same network as your homey and if not you need to set up the firewall rules.
I did want to add an option to manually enter the IP but didn’t yet get time to do it.
I am also planning to purchase a Comfoconnect Pro. Does it work with your app?
No.
There is no working option yet
I got many faults and warnings during local installation.
Mhh that’s a shame
The app seems to be crashing continually..
460954c2-52f3-4925-8f0a-48069c5d9b39
Is it possible tot run both apps in parallel for a while?
I think that should be possible. Just for discovery they will use the same port.
Thats a shame, let have a look. I honestly didn’t really look at the app at all any more as it running fine for me for a while now. But it could well be depedencies got out dated.
I’ve uploaded mey comfoair app into the homey app store and it is now available a test version: Zehnder ComfoAir | Homey
Let me know if you encounter any issues with installing or running it and i’ll have look at it ![]()
Note for the auto discovery of the LAN gateway to work your Homey NEEDs to be on the same network as the LAN gateway (or setup the firewall properly). As the discovery porotcol uses an broadcast package it will not work if you have both on seperate networks (vlans, etc).
Thanks already. I just tried to add my comfoconnect lan. It is at the same network but every time I get a Failed to register.
Install went fine. I am running both apps in parallel now. Everything working for the moment.
One strange thing: 1 watt difference between power reported in the apps
The test app is working for me! But it’s limited to dan state only.
Is there a way to operate the fan using 0-100% instead of the default dan speed settings? Or is the only way to hook up a 0-10v dimmer?
Hey, your app is supporting from Zehnder the next module:
- ComfoConnect LAN C
What about Zehnder Multi Control for EVO devices:
Thanks and Br,
Benjamin
Hi, when you will have time, just let me know, if your app si supporting the Multi-Control - EVO from Zehnder… If not, are you willing to integrated it?
Thanks, Beno
Ik heb een alternatieve versie van de integratie gemaakt die op basis van modbus connect. zie voor de testrelease: Zehnder ComfoConnect Pro | Homey
