I am waiting for new icons to publish to live, so the icons you get if you install this version will just be temporary.
To use the app you will need to obtain some login credentials from the YoLink app.
Open the YoLink mobile app.
Open the menu and select Settings.
Select Account.
Select Advanced Settings.
Select User Access Credentials.
Copy the UAID as this will be requested when you install a device. The app remembers this for adding devices later.
Add your first device(s) to Homey using the normal method and the UAID when prompted.
Copy the Secret Key as will will be request when you add the first device(s) using the UAID. It should only be required once as the app exchanges that for a OAuth tokens which are frequently refreshed.
Hello Adrian, I would like to add my thanks for doing this. In addition to what I have seen here for requests, there is also the yolink plug, vibration sensor, garage door controller, and temperature probe - for your consideration. I look forward to testing your driver.
I have just submitted the first version for review, so it will hopefully be released soon.
Once this version is available, if you need support for other devices to be added, then please go to the app settings page, tap on the Get Devices button and then Send Log. Once you have sent the log, let me know and I will then be able to add the drivers and ask you to test the update.
