Alr. Thanks for the quick answer!
Great app! Any plans to add a flow card for cycling through presets?
hey @Ludvig any plans to fix the problem with color temp ? where if its set to warm it does cold white ?
Great app @Ludvig, thanks! Would also love a fix on the color temp ![]()
Hmm sorry for not updating this. Have been a lot of time spent on other things. Have just moved to my new house so will probably be some more work when setting things up here. To make my life simpler and get you a fix sooner can someboyd explain and give some example of the color temp issue. @Trissie666 @NicklasLK
Did some AI work on it so there is a new test version up WLED Controller | Homey that you can test. Let me know if things work
I had my esp32 flashed with wled connected to my homey for several days working very good. But then I had to disconnect the wled from power and when I connected it again it won’t connect to homey. I tried to remove the wled from homey and add it again but now homey won’t find it.
Restarted homey and wled but still won’t work. Any suggestions?
I can add another new wled (same model) without any problems, so there seems to be pairing and ID management from the app.
Hi all. I have a ESP8266 controller, type DOM-WLE-S. I have some connectivity issues. Every once in a while, completely random, the device drops the connection with the router. I have disabled some settings that have to do with sleep and power saving, but still no luck. The strange things is is that in the Android Wled app I don’t have the remove and add the device again. When the connection is restored the Android app finds it again, but Homey doesn’t. Once the connection is dropped it can’t be controlled, even if the connection is restored as shown in the Android app.
Any help would be much appreciated.
Think you have the same issue I just reported above, if the wled for some reason loses connection and then reconnect you can control with the wled app or via the broweser on your PC. But it won’t reconnect in Homey though this app by Ludvig.
Maybe. It’s quite similar. I also exchanged power supplies to rule that out. So maybe it’s a double problem. One with the Android Wled app and/or the controller, responsible for loosing the connection and one with the Homey Wled app that ones the connection is lost once it doesn’t reconnect?
I have created a new app for WLED based on Ludvigs app but with upgrades.
I have solved the problem with WLED devices not reconnecting after loss of connection to homey.
Still testing it out and adding a few more features, will release it once it is done.
Sorry not so up to date here. Good that your taking it to your own hands. One way if you want to have users use the same app is that you fork this GitHub - ludvigaldrin/com.svipler.app.wled · GitHub and then push a merge and i can push it out. You should of course add your self as a contributor. Then we dont have to add another WLED app to the market.
Ok I will look into that!
So , what is the upside of using this instead of D.A.L.O.R ?
they seem to be very similar ..
I hated their way of adding devices. Don’t remember today but it was annoying how they searched for devices or if IP changed. So overall they are quite the same.
