[APP][Pro] WhatsApp - Simple. Reliable. Private
@Rrrr youre welcome
Yeah until today I have no clue why WhatsApp fails sometimes
For me it’s always running and never have the issue
I do restart my homey nightly though, not sure if that affects it
Will add the tool to the top post
@martijnpoppen
Sent you a diagnostic report:
7db678ae-ac73-4503-9f89-d721cf2f7a6c
Some reason it didn’t sent a WhatsApp (18:28:27)
Maybe you can see something :folded_hands::dizzy:
@Seinuh no sorry nothing to see af that timestamp:/
No problem, the number that wasn’t triggered is a WhatsApp business number. If I search my memory, I’ve had this before when my laptop was also open with WhatsApp. That might sometimes lead to a conflict. Now I’m logged out of WhatsApp on my laptop. Let’s see what happens. :folded_hands::magic_wand::top_hat::crystal_ball::sparkles:
Hi guys, I have problems thinking of a good way to do the following:
I want to sent texts on a specific time to someone, a text that I already wrote somewhere. Could be notes, could be an agenda item, could be anything, I don’t care as long as I don’t have to create a flow for every message.
So my question is: what would you do? I prefer to do the writing on my iPhone/MacBook. An app like Slack would also be good.
@TheBigFella I made a app exactly for that purpose
More info: [APP][Pro] Schedule Message
It seems that the Homey WhatsApp app has lost its integration with my WhatsApp account. I already tried signing out from the Ubuntu server in WhatsApp, but that didn’t work. I’m also unable to reconnect using a new OTP.
Does anyone have any suggestions or can help me with this strange issue?
There seems to be a bug in fixing it by the repair option.
You could delete the old one (write down the ID before removing or find it in the broken flowcard afterwards) and add it again.
The flows can be fixed by using the this script.
The only thing you need to change is the ID of the old and new device and change softrun from true jaar false.
@HvN no idea but sending a diagnostic report is the best you can do so I can have a look
Good evening Martijn,
Please find attached the diagnostics report id: ‘d7c589ff-4c12-40c4-b783-7cdc2de9180f’.
Thank you!
Best Regards, Hugo
@HvN I can’t find your report
Which app version are you using?
I think the latest available, version 1.30.0.
@HvN the comment from @Glenn_Dijkstra is the solution in this case [APP][Pro] WhatsApp - Simple. Reliable. Private - #1605 by Glenn_Dijkstra
Also your report is not coming trough.
I would suggest a homey restart as well
Hi @martijnpoppen,
I have restarted Homey, retrieved the old device ID using the script, removed the old WhatsApp device from Homey, and am now trying to add a new WhatsApp device. Unfortunately, I still get the same error when I try to add the new pairing code: “Kan apparaat niet koppelen. Controleer of het telefoonnummer op je apparaat juist is of vraag een nieuwe code aan. [OK]” (Translation: “Unable to link device. Check if the phone number on your device is correct or request a new code.”).
I also still see the old connected Ubuntu instance listed under WhatsApp’s linked devices, but I’m unable to sign it out directly from WhatsApp. Is it possible to force this sign-out from the Ubuntu server side?
Many thanks for your help.
@HvN no not that I’m aware of sound like a WhatsApp issue to me. Not something I can help with
Hi @martijnpoppen,
It seems to be a WhatsApp issue indeed. When I go to other settings that require an internet connection within my second WhatsApp account, I get warning messages about my internet connection. Strangely enough, I only have these issues with my second WhatsApp account. I’ve already checked a lot of settings (internet, mobile, dual-sim config, etc, etc.), but so far without success. I understand that your support ends here. Thank you so far. I will try to solve this myself or with WhatsApp support. It’s a very strange issue.
New app update (:green_square: LIVE: 1.33.0):
Changelog:
NEW:
1: NEW: add support for anonymous participant ID
2: NEW: update SDK
FIXES:
1: FIX: get correct senders number (unhash)
More - apps - Whatsapp - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
After the update, the “device is unavailable.” Is it true that the repair button has disappeared? If so, how do I get the connection working again?
@Marco0499 no it’s not dissapeared.
in the webapp:
  • right click and press repair
in the mobile app:
  • settings wheel - maintenance - repair
Weird, but I don’t have either option?!
