@Rrrr somehow the repair is still not working perfectly. it creates a weird memory leak which i cant really find, removing and re-adding always works..
I will check with athom as it seems the store of data is not cleared properly
Removing and reinstalling was straightforward as all the links to groups remained the same. Thanks!
Great app! I do have an issue where it causes my phone to no longer receive any push notifications. It does show them as unread. It behaves the same as having the desktop app open for example where all notifications will be silenced on your phone while using it on the desktop app. Is there any way to fix this?
@MRAJEKO
Most of the time you can fix this by sending a WhatsApp from homey once and then the device will appear as offline
I’ve got the same issue, where I can’t seem to repair because it keeps loading.
I have quite some apps that are using this, so remove and adding again is quite some work.
Hope there’ll be a fix somewhere in the future ![]()
Strangely, I have two numbers connected. One does work, but for the other it doesn’t want to send a new pair request… It gives this error: Not Found: PairSession with ID 9ab44a53-6534-46fe-a1b1-f2e123620505
Diagnostics report: b72c0e52-45e3-44f6-80d6-427db60d2c55
@Daan_Dagevos thats a homey app error, cant influence that.
Yep i know a fix would be nice but never found it.
re-adding is not that much work if you use this script: [HOW-TO][Pro][Cloud] - Tool to FIX (advanced) flows after removing and re-adding devices
That’s too bad! I get it quite often, specifically on this WhatsApp app.
The tool to fix flows is very, very, very usefull. Thanks man! Bought you a beer for all your support here and all other apps ![]()
Thank you so much!
I will definetely try to fix the repair
Cannot pair widget to group
First i added whatsapp app on homey after i created a new device and connected my whatsapp
After i added a new whatsapp widget and typed the code on the selected group (i am there)
but nothing happened. I don’t know how to continue from here
will appreciate help (logs sent). Thanks!!!
Hey @Eran_Abir
Thanks for your detailed description
I don’t see anything in the logs for this
Can you try to restart the app and go the widget again the code will be different probably and then try again?
Hey I tried again and no luck i restarted the app and added a new widget with new code and nothing happened when typing the code in group chat ![]()
Try to remove and re-add the device. It’s a known issue that repair does currently not work for Whatsapp
@Eran_Abir And the Homey number is part of that groupchat? (and a admin in the group)
Yeah ots my own personal phone number i am the admin in the group chat and there
Tried multiple times. It keeps loading.
@MikeT87 please send a diagnostic report
Hoi Martijn,
Wat een leuke app! Dit maakt de Homey zo leuk. Ik kan nu m’n vrouw een berichtje sturen dat ze haar regenpak moet meenemen als Buienalarm regen voorspelt en een snapshot van de beveiligingscamera naar m’n telefoon als de bel gaat ![]()
Een vraag: ik heb het gisteravond geïnstalleerd, ik krijg nu steeds een melding op mijn telefoon (en dus smartwatch): “De synchronisatie met Whatsapp op Google Chrome (Ubuntu) is voltooid”, een tijdje nadat ik de service heb gebruikt. Op zich is het prima dat het gebeurd, maar die melding is wel overbodig.
Heb je een idee hoe dit komt en wat ik er aan kan doen (behalve meldingen uitzetten, maar dan krijg ik helemaal geen meldingen meer van WA)?
Groet,
Jaap
Hi @PoJa84
Thanks!
First of all please translate your post this is a English topic
The answer to your question is this:
Hi @martijnpoppen,
As said this seems successful but it is not in the end.
To really fix the issue I had to remove the device and add it again.
In the meanwhile I read the other (newer) messages on the topic and this seems to be a know issue for now ![]()
