I will test this with the new version of the app.
Thank you for your input, much appreciated!
Ok, then we’ll wait for the new app. Your effort is much appreciated !
I expect to release a test version today.
There is a chance that your device must be re-added, but not 100% sure.
First, try to just update the app and see how it does. If it fails, remove the device and add it again.
I will keep you posted here…
Allright, a new test version is available and can be installed here.
Please let me know if there are any issues, or if it all works as expected (also nice to hear).
Thanks!
Is working. Didn’t need to repair of re-adding. It just worked the moment the testversion was installed.
Right, update/install app and running.. Sweet !
Same here — I can’t add my Blackbird P60 either. Before I read about the app update, I’d already removed it from Devices to re-add it. Even after updating and reinstalling the Weheat Homey app, I still get the same issue. The response is: “ Weheat API heeft toegang tot dit apparaat geweigerd”
Do you guys ever reed back a few posts or?
Install the test version, which is in review by Athom. So the newest version is not live yet.
Yes, can confirm that the update to the test version repaired my Flint. No need to remove and add the device. A repair of the existing device was enough.
Did install the test version but auto-update was too quick to revert back 1.1.0. 1.2.0 works when trying to add the device again. Thanks for the fix!
That did the trick. Thanks ! Much appreciated.
Many thanks Edwin, test version works perfectly fine so far, without having to re-add my Sparrow.
The latest version is now live in the app store.
Yes I have read it back ![]()
Thank you for the new update!
Same here…
I will let Weheat know. They need to fix this. I will keep you informed here.
Are you using the latest version of the app? Could you copy-paste the URL here?
Yes, I am using the latest version 1.2.1. When connecting to my Blackbird it tried to log into WeHeat using the following URL: https://auth.weheat.nl/auth/realms/Weheat/protocol/openid-connect/auth?response_type=code&client_id=HomeAssistantAPI&scope=openid+offline_access&redirect_uri=https%3A%2F%2Fcallback.athom.com%2Foauth2%2Fcallback&code_challenge=kp_zFEg_2MBRspxax7MOBHv4yWIJWw6TBFVi9cj5TjY&code_challenge_method=S256&state=a4e369bc-8a84-4d95-91a2-5e6b90aa3db8
