[APP][Pro] WebPanel – Your Homey dashboard on any wall tablet
Hey @Leopold – absolutely amazing work! I’ve finally found something to replace my MagicMirror instance in the house!
I have one feature request. The ‘secondary’ data rows are difficult to read. Would it be possible to add configurable font sizes for these lines as well?
Hi Leopold,
first of all I’d like to thank you for the great development work! :slight_smile:
I’ve got a problem with PocketPanel to report. I hope this forum is the right place for it.
I can’t connect to Homey when I’m outside my home Wi-Fi network. I’ve linked Homey in the app. There’s no response, either when the app is open or via the widgets.
Best regards
hi, sorry for the delay in answering but i’m transferring a shelly hardware panel of switch and GU 10 indicator lights to webpanel while running the BNB. tricky.
This is the tile for room entry time and the drop down menu to highlight them
Hey! Yes this is intentional unfortunately. Athom has blocked me from using the technique that I made to get it to work without an account. So I am implementing a way to login for “super users” with a homey account and having a “guest style” workaround for users that should only be accessable through wifi. As it is only a test app I haven’t been able to work on it too much.
That is strange, I can’t really understand why it would render it like that.
I will have to look at that.
OK, I see. When do you reckon you’ll have that implemented? I’ll have another look at the app then.
I think it’s good that there’s an alternative to the Homey widgets. I like using them when I’m out and about.
WebPanel’s tile editor is new: tap a tile while editing and you see it at the top, exactly as it will look on your wall, changing as you change it. Nothing happens on the dashboard until you tap Done.
See it in action:
What you can do:
• Text and icon sizes with arrows up and down (1 px a step, hold to go faster), or Auto
• The tile’s colour, text colour and icon colour, all in one row
• Pick the values in order: 1 is shown big, 2 to 4 small under it
• Standard, graph or gauge look
• Reset look to start over, keeping what the tile shows
I’m still having this issue, all other kiosks panels are working fine, but WebPanel Kiosk are giving me this issue. A restart will solve the issue, but something is wrong here.
Can you check the versions of all the apps?
What do you have in here?
I have 1.1.8 and the same settings as in your screenshot. Sorry, 1.18.0 should it be. Ehh, wait. On the front page at the top it says v.1.18.0 and when I open settings it says at the bottom 1.1.8.
Yeah it’s a little confusing, but the android app is 1.1.8.
Please update to 1.1.9 and follow the guide.
Hold on, are you in the tester group?
Nope, I’m just a simple enduser. But, if you need some help with testing I’m here. Just let me know
No, I have removed the closed testing now. That’s why I asked. It looked like you had a wrong version. But please try the “guide” in the “Screen” section.
Awesome app! The only thing I haven’t been able to do is to change the color of a tile through a flow (e.g. green when everything is OK, red when an alarm is active). Is there a way…or something that might be added in the future?
There is a function called “Highlight” which can outline a tile with a color but you want the full tile to be a color?
Yes, the full tile. I’ve played with the outline and like the animations, but from a distance it doesn’t pop as much as a full red tile.
Contact sensors seem to light up, but not logic variables (yes/no)…and some more special cases like if a value is over ”300” or those kind of things that you can’t really build into the app, but perhaps control through flows instead.
ok, thanks. kind regards Luc
I’m using your app to make a signage on the door. ‘open’ message during the day, ‘closed’ during the night. I use a tablet with fully kiosk and webpanel door with page 1 for open and page 2 for closed. every 120 sec. it falls back from page 2 to 1. I use this script as mitiigation but there must be a better way. I think. I hope?
Is there anyway to change from military clock to a regular clock on the screensaver?
