[APP][Pro] WeatherLink (DEVELOPER NEEDED)
The app supports an old school file format and the cloud version of WeatherLink (API v1). So you could try if the WeatherLink Live is supported.
API Token v1: Homey - Error: Could not find that PairSession
Use Device ID (DID), Password (account owner) and API Token from WeatherLink.com
Am I doing something wrong?
Hi Thomas,
I don’t have a station connected to weatherlink. But can you try the demo account info which is show as a placeholder during the device add.
Device ID: 001D0A00DE6A
Password: DEMO
API Token: demo0a002bc5272033001d0a002bc527
Hi MarcoG,
the demo account works in homey but how do I get it to work with WeatherLink live?
Did you sign up with WeatherLink via https://www.weatherlink.com ? Ones your device is registered and available there the Homey app should be able to connect.
Yes and have made a API Token 1 and 2 and a Device ID but is password in app the same to log in to https://www.weatherlink.com ?
my.homey.app say:
Error: invalid json response body at https://pi.weatherlink.com/v1/NoaaExt.json?
User= “Device ID” &pass= “password to https://www.weatherlink.com” &apiToken= “My API Token 1” reason: Unexpected token S in JSON at position 0
Hi, my.homey.app respond … Unexpected token S in JSON at position 0. The weatherlink works with the demo but not my real one. It is the weatherlink live - do you have a solution ?
Hello Thomas, did you get the weather link to work with the Homey pro? I have the same problem as that you described. I’m searching the internet, but no solution found yet.
Hope you can help me.
Can’t get it to work
Hello lbundgaard, did you get the weather station to work on the homey pro?
Hello Rob, can you help me how you got the app to work? If I use the demo login, it is working, but if I use my data from WeatherLink I get a error.
Regards,
Hans.
