[App][Pro] Viessmann App for Homey Pro
Hey @Thomas_Brenac
The diagnostics report show me that the authentication against the Viessmann API has failed for an unknown reason.
I’ve pushed v1.6.2 towards stable now, this version should give more feedback on the exact error.
Kind regards,
Hi
Thanks but same error (although the content is not written the same way, the message is the same)
164e5cc3-0315-46f5-8123-be1d535f2a60
Hello @Thomas_Brenac ,
This does not sound good. Did you exceed the threshold for the Viessmann API? Do you have maybe another integration with Home Assistant or something else?
The error code you get is 402, which means “Payment Required”.
Could you look in your Viessmann Developer Portal if you see any more information there?
PS: I have a feeling that Viessmann will start blocking these APIs in the future.
Hi
No other instance (I also use the official apps from vissman so maybe that is the reason it’s counting) and I tried apparently 31 times over several days.
hi
each time i try to install the equipement via the apps it increases the
counter in the developper dashboard. Now 35 in a month time
all the rest seems ok and account is basic individual allowing 1450 api
calls per day, and it is still indicated FREE :slight_smile: Shall i open a ticket
with them ? what error code you see in return from them ?
7e97c017-2a85-4d9d-9531-f0f3c3114be0
kind regards
Hey Thomas,
The app gets HTTP error 402 during the OAuth2 handshake.
Kind regards,
I created an ID, it worked too. However, I always get an error message when inserting the device. device or resource not found
I have a Vitocal 222S
Could you share a screenshot?
I went four weeks without Viessmann, wasn’t working, uninstalled the app yesterday, restarted Homey, reinstalled the app, and logged in. Everything is working again. Phew, thank goodness.
i was using the ViCare App but this app stopped working this morning, tried this one and the error is the same, so I assume a API error on my account. I always get a “premature closed” message from the server. What am I missing here? in the App Setting, the API Output calls: No OAuth2 Client Found.
I’ve also deleted the apps, the token and everything was rebooted. Same issue.
230ede44-9133-4db0-8c86-441a2dad515b
Hey @JayR
The diagnostics report does not give me much info. Could you share more info on the error? E.g. some screenshots?
Thanks,
Hi Kenny, the API connection has stopped working today. I’ve already generated a new API key, but the error remains the same. The error is… failed to retrieve the features.json: [OAuth2Error] Error: Client authentication failed
Hmm. Could you maybe share a diagnostics report?
43fd7a9e-2b92-434e-9ee0-4962360171bd
Hey Joe,
I don’t get much wiser form the report, the authentication API from Viessmann tells me “Invalid grant” in your case.
Did you try recreating the client completely?
Hi Kenny,
Since 2 weeks or so I get the same “invalid grant” errror.
I have removed the app completely and re-installed it. When adding a new device it wants to go to the login page of Viessmann, but that gives a “proxy error” page.
So there seems to be going something wrong during authentication. Can you please help?
Yes
Hey guys,
This is sadly something on viessmann side, we’ve seen it popping up in the past already a few times.
Some hints from this topic to try out:
Let me know the results.
Kind regards
Repair Helps
Hi Kenny, I think I may have found an issue with power consumption reporting for a Vitocal 200-S (AWB-M-E-AC 201.E10) in the Viessmann Homey app.
The electrical consumption features are available when I query the Viessmann V2 API directly (heating.power.consumption.current, .heating and .total), including actual historical kWh values. However, these features are missing from the features.json generated by the Homey app, and consequently no measure_power / meter_power capabilities are created in Homey.
I also have a Vitocal 150-A connected to the same Homey/Viessmann setup, for which the power reporting works correctly.
I have the features.json and the direct API results available for comparison. I can’t seem to send you a PM yet. What would be the best way to send these files to you privately?
Thanks, Michiel
