[APP][Pro] VeSync (Levoit)
Feel free to test the Core300s :slight_smile:
If something is not working, hit me up and we will find the issue
Version 1.0.1 Rewrite Update :rocket:
Hey VeSync app users!
I’m excited to announce that I’m working on a major rewrite of the app. This new version will make it much easier to support even more devices in the future. It’s a huge step forward, and I can’t wait for you to experience it!
:tada: What’s New in Version 1.0.1:
* Complete rewrite of the app for improved performance and easier future device support.
* Testing done the following devices:
  * Core200s
  * Core400s
  * F422S
  * Vital200s
* Bug fixes for many devices in 1.0.1
:microscope: Help Me Test the Rewrite:
The rewrite is still in testing, and while I’ve ensured the above devices work smoothly, I need your help to test other models. If you own any of the devices listed below and are interested in helping, please reach out!
:electric_plug: Devices I Need Help Testing:
  • Air Purifiers:
    • Core300s
    • Core600s
    • Vital100s
    • LV131S
  • Humidifiers:
    • Classic200s
    • Classic300s
    • Dual200s
    • Oasis1000s
    • Oasis450s
    • LV600s
Your feedback is incredibly valuable for making this app as reliable and feature-rich as possible!
:light_bulb: Support My Development:
If you appreciate my work and want to help out, consider buying me an energy drink :high_voltage: or a beer :beer_mug:. Donations are a great way to support and motivate me!
:globe_with_meridians: How to Donate:
You can donate via PayPal. Your generosity helps keep this solo project moving forward!
:woman_technologist: Calling All Developers!
Are you a developer? Want to contribute to this project? I’d love to collaborate! Feel free to send a pull request on GitHub and join me in making this app even better.
:folded_hands: Thank you for your support!
Hi. Just put up my humidifiers again after a long sleep during summer. I got a Classic 300s and a LV600s. Both seem to work OK.
Please let me know if you want me to test out anything spesific.
I did some more testing.
Looks like Display and Nightlight can not be controlled from Homey App and not via flows. Nightlight has 3 states. Off, Medium and Max.
Hi.
Is it possible to add Dual 200s Pro? In version 1.0.1 also doesn’t work.
Cheers.
Will check soon once I have some time :slight_smile:
Dual200s Pro is not supported (yet). I have to check it’s API and if my current implementation will work.
Any progress? :slightly_smiling_face:
Nope, could you share me the device? And/or send me a diag. report after a restart. spkes@spkes.de is my email for VeSync.
I need some data, support should be quite easy
The device is shared.
Check out the latest test version.
I’ve just tested app and it works almost fine. First of all Dual 200S Pro has been added and it works with workflows.
But there are two drawbacks: it’s weird to control the device (there are auto mode, low level mode, high and night mode) with a vertical bar because when the bar is at 0 it turns off the device, 1 turns on low level, 2 high level, 3 high level - I think it should be corrected.
The second disadvantage is significant because the Dual 200S Pro has LED lighting and you can’t control it in the app.
Additionally, you can add a device cleanup alert.
Nevertheless, you deserve a thumbs up :+1: for your work so far.
Thanks for the feedback! Awesome to hear the Dual 200S Pro is working – that’s a win.
About the issues: the control bar is the manuell mode.
Sadly, Homey doesn’t let me create custom controls, and without a web-based dashboard, widgets aren’t really an option for me right now.
For the LED lighting: I’ll add support for that on a later date.
As for the device cleanup alert, can you explain what you mean?
Still, I’m happy you’re enjoying the progress so far—your thumbs-up means a lot! :+1:
Thanks for explaining the problem with the vertical bar.
What I mean is that the device should be cleaned regularly to avoid the growth of bacteria. The device notifies you for example once a week when cleaning is needed. This functionality is provided by the VeSync app.
I look forward to further development of the application’s functionality, including adding LED light control.
Is it be possible to add the Everest Air? Would highly appreciate that.
Thank you for the app, works good for me and my new core300s.
I would also like to be able to control the display via flows
@spkesDE : could you please have a look at the everest air?
Hi. What an awesome work you are putting into this app. After the massive rewrite you talked about: Any chance that support for Cosori airfryers could be added? I would be happy to contribute by granting access to my Cosori Dual Blaze for testing. TIA.
I just bought an Oasis Mist 1000S. VeSync activated, credentials are ok. But when I want to add it to Homey Pro 23 via the Homey WeSync app I get the error message “could not login with username (my e-mail address)”. Tried
  • deleting the device from the VeSync app
  • connecting Homey Pro 23 and the 1000S to the same 2.4Ghz wifi network
  • change mail address
  • activate 2FA
    Nothing works. Please help :wink:
I can’t say exactly why it’s not working, the diagnostic report you sent doesn’t show any error messages.
Please try using the test version; it’s working fine for hundreds of other users. You might also want to check if something like a DNS blocker (e.g., Pi-hole) is interfering.
Please try to login on the web, then check the console logs of your browser of errors.
Since an air fryer isn’t as straightforward as a light bulb or a fan, it’s still a bit new to me. I’d need access to it to help properly, but I prefer not to start or stop your device remotely from my location.
I’ll take a closer look at the Everest Air once I’m working on it again to see how complex it is or how it differs from the other devices.
Edit: Added experimental support, untested. EverestAir should use the same API as the Vital series. For better support, please send me a PM and give me access to this devices via the VeSync app (spkes@spkes.de)
Sure, I’ll put it on my todo list but no ETA
Via flow or as a sensor?
I mean I added something like this already for some devices
Having the same problem as @ArnoMeijer with login, what else should I send you?
Here are some captures.
