[APP][Pro] Universal TUYA Zigbee Device App - test
Contact sensor:
Summary
“ids”: {
“modelId”: “ZG-102Z”,
“manufacturerName”: “HOBEIAN”
“endpoints”: {
“ieeeAddress”: “a4:c1:38:a4:ac:29:7c:5f”,
“networkAddress”: 49392,
“manufacturerName”: “HOBEIAN”,
“endpointDescriptors”: [
“status”: “SUCCESS”,
“nwkAddrOfInterest”: 49392,
“_reserved”: 18,
“endpointId”: 1,
“applicationProfileId”: 260,
“applicationDeviceId”: 1026,
“applicationDeviceVersion”: 0,
“_reserved1”: 1,
“inputClusters”: [
0,
3,
1280,
61184,
1
“outputClusters”: []
“deviceType”: “enddevice”,
“receiveWhenIdle”: false,
“swBuildId”: “0122052017”,
“capabilities”: {
“alternatePANCoordinator”: false,
“deviceType”: false,
“powerSourceMains”: false,
“security”: false,
“allocateAddress”: true
“extendedEndpointDescriptors”: {
“1”: {
“clusters”: {
“basic”: {
“attributes”: [
“acl”: [
“readable”
“id”: 0,
“name”: “zclVersion”
“acl”: [
“readable”
“id”: 1,
“name”: “appVersion”
“acl”: [
“readable”
“id”: 2,
“name”: “stackVersion”
“acl”: [
“readable”
“id”: 3,
“name”: “hwVersion”
“acl”: [
“readable”,
“reportable”
“id”: 4,
“name”: “manufacturerName”,
“reportingConfiguration”: {
“status”: “NOT_FOUND”,
“direction”: “reported”
“acl”: [
“readable”
“id”: 5,
“name”: “modelId”
“acl”: [
“readable”
“id”: 7,
“name”: “powerSource”
“acl”: [
“readable”,
“writable”
“id”: 18,
“name”: “deviceEnabled”
“acl”: [
“readable”
“id”: 16384,
“name”: “swBuildId”
“acl”: [
“readable”
“id”: 65533,
“name”: “clusterRevision”
“acl”: [
“readable”
“id”: 6,
“name”: “dateCode”
“commandsGenerated”: “UNSUP_GENERAL_COMMAND”,
“commandsReceived”: “UNSUP_GENERAL_COMMAND”
“identify”: {
“attributes”: [
“acl”: [
“readable”,
“writable”
“id”: 0,
“name”: “identifyTime”,
“value”: 0
“acl”: [
“readable”
“id”: 65533,
“name”: “clusterRevision”,
“value”: 1
“iasZone”: {
“attributes”: [
“acl”: [
“readable”
“id”: 0,
“name”: “zoneState”,
“value”: “enrolled”
“acl”: [
“readable”
“id”: 1,
“name”: “zoneType”,
“value”: “contactSwitch”
“acl”: [
“readable”
“id”: 2,
“name”: “zoneStatus”,
“value”: {
“type”: “Buffer”,
“data”: [
1,
0
“acl”: [
“readable”,
“writable”
“id”: 16,
“name”: “iasCIEAddress”,
“value”: “3c:2e:f5:ff:fe:5c:b1:37”
“acl”: [
“readable”
“id”: 17,
“name”: “zoneId”,
“value”: 0
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 61441,
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 19,
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“powerConfiguration”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 32,
“name”: “batteryVoltage”,
“value”: 30,
“acl”: [
“readable”,
“reportable”
“id”: 33,
“name”: “batteryPercentageRemaining”,
“value”: 200,
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“bindings”: {}
That one’s already in the app. Just remove and re-pair, should work fine.
Forum Response - @blutch32 #1011
Reply to post
@blutch32
Thank you for the interviews! Here’s my analysis:
:one: HOBEIAN ZG-303Z - NOT a Contact Sensor!
Your interview shows this device has:
inputClusters: [0, 3, 61184, 1026, 1029, 1]
This means:
  • :white_check_mark: Tuya DP (61184)
  • :white_check_mark: temperatureMeasurement (1026)
  • :white_check_mark: relativeHumidity (1029)
  • :white_check_mark: powerConfiguration (1)
  • :cross_mark: NO IAS Zone (1280) = NO contact sensor capability!
The ZG-303Z is a SOIL/CLIMATE sensor (temperature + humidity), NOT a contact sensor!
It’s already supported in the soil_sensor driver. If you need a contact sensor, you have the wrong device.
Question: Do you have ANOTHER device that is the actual contact sensor? Please share its interview if so.
:two: Soil Sensor _TZE284_81yrt3lo - Already Supported!
This is actually a 2-channel CT power meter (energy clamp meter), already supported in power_clamp_meter driver.
When you pair it:
  • It should show power readings for 2 channels
  • Capabilities: measure_power, meter_power, measure_voltage, measure_current
:three: Energy Meter
Please share the interview for the energy meter if it’s a different device from the _TZE284_81yrt3lo.
Summary:
| Device | Status | Driver |
| ZG-303Z | :white_check_mark: Supported | soil_sensor (temp/humidity) |
| _TZE284_81yrt3lo | :white_check_mark: Supported | power_clamp_meter |
Please update to latest version and re-pair the devices! :folded_hands:
@blutch32
Thanks for the interviews! Here’s my analysis:
:one: Contact Sensor _TZ3000_996rpfy6 - “Alarm still no”
The interview shows iasZone: {} EMPTY - the cluster is not enrolled.
Action required:
  1. Remove the sensor from Homey
  2. Restart the Tuya Zigbee Universal App
  3. Re-pair the sensor
If still “no” after re-pairing, enable “Invert contact state” in the settings.
:two: HOBEIAN ZG-303Z Floor Sensor - :white_check_mark: OK
You confirmed it works!
:three: Power Meter _TZE284_81yrt3lo - “Detected as unknown”
This fingerprint is in the power_clamp_meter driver.
Action required:
  1. Remove the device
  2. Restart the application
  3. Re-pair → it should appear as “Power Clamp Meter”
After updating to v5.6.0, you must RE-PAIR the devices that were “unknown”! :folded_hands: Please send me also new inerviews .
Hi Dylan you getting there again :+1:t2:, quick status about my sensor, by the looks of it the Motion, Luminance and Temperature are okay now.
Humidity is still factor 10 to low and still no Battery selection in the Menu bar below.
Diagnostic code: fc08ae55-f9e9-4acd-af67-079305d81d91
Best regards Peter
ih good news , so i need to be more accuraite related battery and bruing back the battery status adn battery flows. :slight_smile:
Battery is back now :+1:t2:
// AVANT (bug)
101: { cap: ‘measure_humidity’, divisor: 10 } // 90/10 = 9% :cross_mark:
// APRÈS (fix)
101: { cap: ‘measure_humidity’, multiplier: 10 } // 9×10 = 90% :white_check_mark:
Is there anything else I can do with my devices?
If not, I’d like to use Tuya Cloud instead.
Thank you very much for trying.
Thanks for the answer, yes hobeian soil detector now works.
For the contact sensors, I did remove it and add it back but now and since the last big update you released with many changes, (it was before well detected and added as a contact sensor but was not working. Magnet or not, alarm stayed to no), now it is no more recognise. And I can not invert contact state as it is only recognise as an unknown zigbee device.
For the energy meter, it is finally well recognised as an clamp power meter. But everything is at 0w (well connected to components working at the moment). Also it shows 3 phases wen you said that I shoul see 2. Did , select the wrong one ? Took the one without an image on it.
Pease send me the diag log of the app.
please do an new diag log
@Haadeess Version 5.7.3 has just been released with support for your AVATTO TRV (_TZE284_o3x45p96).
Instructions:
  1. Update the Universal Tuya Zigbee app to v5.7.3
  2. Remove the current device
  3. Add it again via the “Thermostat / TRV” driver
  4. The target temperature, set temperature, battery, and mode controls should appear
If specific DPs are not working, please share the device logs so I can adjust the mappings.
•@blutch32 Thanks for the details! I’ve analyzed your devices:
1. Contact Sensor (_TZ3000_996rpfy6)
The fingerprint is in the driver - it should be recognized. But the pairing seems to be failing.
Please provide the complete Zigbee interview:
  1. Homey Developer Tools: Homey Developer Tools
  2. Devices → Your contact sensor → Zigbee tab
  3. Copy the entire TEXT (not a screenshot)
I’m specifically looking for the productId (should be TS0203).
2. Power Meter (_TZE284_81yrt3lo) - 0W and 3 phases
0W: The meter is not reporting data via Tuya DP.
→ Did you wait a few minutes after pairing?
→ Are the CT clamps properly connected?
3 phases: This is a 2-channel meter. Phase 3 should not be displayed.
→ I will fix this in the next version.
Please provide:
  1. The app diagnostic code (Settings → App → Generate diagnostic)
  2. The Zigbee interview of the power meter
With this information, I will be able to fix both problems! :wrench: •
Unfortunately, the same error pattern persists.
f5d2f7c4-c61b-4e4f-92e7-2906e6cdd724
Interview
“ids”: {
“modelId”: “TS0601”,
“manufacturerName”: “_TZE284_o3x45p96”
“endpoints”: {
“ieeeAddress”: “a4:c1:38:5d:15:01:6a:9a”,
“networkAddress”: 57539,
“manufacturerName”: “_TZE284_o3x45p96”,
“nwkAddrOfInterest”: 57539,
“_reserved”: 22,
“endpointId”: 1,
“applicationDeviceId”: 81,
“_reserved1”: 1,
“inputClusters”: [
4,
5,
61184,
0,
60672
“outputClusters”: [
25,
10
“capabilities”: {
“security”: false,
“1”: {
“clusters”: {
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “nameSupport”,
“value”: {
“type”: “Buffer”,
“data”: [
0
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2
“scenes”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 1,
“acl”: [
“readable”,
“reportable”
“id”: 2,
“acl”: [
“readable”,
“reportable”
“id”: 3,
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“basic”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “zclVersion”,
“value”: 3
“acl”: [
“readable”,
“reportable”
“id”: 1,
“name”: “appVersion”,
“value”: 80
“acl”: [
“readable”,
“reportable”
“id”: 2,
“name”: “stackVersion”,
“value”: 0
“acl”: [
“readable”,
“reportable”
“id”: 3,
“name”: “hwVersion”,
“value”: 1
“acl”: [
“readable”,
“reportable”
“id”: 4,
“value”: “_TZE284_o3x45p96”
“acl”: [
“readable”,
“reportable”
“id”: 5,
“name”: “modelId”,
“value”: “TS0601”
“acl”: [
“readable”,
“reportable”
“id”: 6,
“name”: “dateCode”,
“value”: “”
“acl”: [
“readable”,
“reportable”
“id”: 7,
“name”: “powerSource”,
“value”: “battery”
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65502
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2
“acl”: [
“readable”,
“reportable”
“id”: 65534,
“name”: “attributeReportingStatus”,
“value”: “PENDING”
“acl”: [
“readable”,
“reportable”
“id”: 65506
“acl”: [
“readable”,
“reportable”
“id”: 65507
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65487
“bindings”: {
“ota”: {},
“time”: {
“attributes”: [
“acl”: [
“readable”
“id”: 65533,
“value”: 1
thx a t fr the diaglog it’s usefull
I will start to answer for the power meter as it is easier to interview.
Yes well connected and I did wait for one hour before to report the issue.
Here is the diag :
a0f7de6a-7e07-4bea-99a1-68e4a7faa131
And here is the interview.
  "ids": {
    "modelId": "TS0601",
    "manufacturerName": "_TZE284_81yrt3lo"
  "endpoints": {
    "ieeeAddress": "a4:c1:38:a9:45:fb:a3:2f",
    "networkAddress": 25467,
    "manufacturerName": "_TZE284_81yrt3lo",
    "endpointDescriptors": [
        "status": "SUCCESS",
        "nwkAddrOfInterest": 25467,
        "_reserved": 22,
        "endpointId": 1,
        "applicationProfileId": 260,
        "applicationDeviceId": 81,
        "_reserved1": 1,
        "inputClusters": [
          4,
          5,
          61184,
          0,
          60672
        "outputClusters": [
          25,
          10
        "_reserved": 10,
        "endpointId": 242,
        "applicationProfileId": 41440,
        "applicationDeviceId": 97,
        "_reserved1": 0,
        "inputClusters": [],
        "outputClusters": [
          33
    "deviceType": "router",
    "receiveWhenIdle": true,
    "capabilities": {
      "alternatePANCoordinator": false,
      "deviceType": true,
      "powerSourceMains": true,
      "security": false,
      "allocateAddress": true
    "extendedEndpointDescriptors": {
      "1": {
        "clusters": {
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "nameSupport",
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "reportingConfiguration": {
                  "status": "NOT_FOUND",
                  "direction": "reported"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "name": "clusterRevision",
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "zclVersion",
                "value": 3
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "name": "appVersion",
                "value": 78
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "name": "stackVersion",
                "value": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "name": "hwVersion",
                "value": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "name": "manufacturerName",
                "value": "_TZE284_81yrt3lo"
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS0601"
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": ""
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "name": "powerSource",
                "value": "mains"
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "name": "attributeReportingStatus",
                "value": "PENDING"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65487
        "bindings": {
          "ota": {},
          "time": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
      "242": {
        "clusters": {},
        "bindings": {}
Will give you informations for the contact sensor afterward
merci beaucoup :slight_smile: •
thx
i have found more infotmatiosn hopping that will be fixing issues DP101: Power A (÷10) DP102: Direction A
DP105: Power B (÷10) DP104: Direction B
DP106-109: Energy Forward/Reverse A/B (÷100)
DP110: Power Factor A DP121: Power Factor B
DP111: AC Frequency DP112: Voltage (÷10)
DP113: Current A (÷1000) DP114: Current B
DP115: Total Power (÷10) DP129: Update Frequency
Added a Interview if needed
checking right now
