[APP][Pro] Universal TUYA Zigbee Device App - test
Hi Dylan,
three days ago with version 817 I recognized by test flow that physical buttons worked. Since I was on business, I just now could test. With version 860 physical buttons still worked until I re-paired the device. Now the buttons don’t work anymore. Virtual buttons didn’t work before r-pairing today an not after.
Here again a new diag: c33007b0-d28d-4fda-bab8-b5423def961b
Best regards, Hartmut
Might be fixed already on the next version
I have some issue with pushing to homey.
Just be patient.
Hello, Dylan. Sideloaded V5.5.977. And it is still the same.
Recognized:
BSEED 1 button wall switch zigbee with neutral. _TZ3000_ysdv91bk TS0001
BSEED 1 button wall switch zigbee with neutral. _TZ3000_blhvsaqf TS0001
LED control for wallswitch not working.
Seen as “unknown zigbee devices”:
BSEED 2 button wallswitch zigbee with neutral _TZ3000_l9brjwau TS0003
BSEED 3 button wall switch zigbee with neutral _TZ3000_qkixdnon TS0003
Sadly i can’t send a diagnostic rapport because it is in development mode.
Hi Dylan Good morning :sun_with_face:,
Everytime an update is installed my HOBEIAN Multisensor app display is changing and then the lights are turning On & Off because of Lux fluctuating all the time and triggering the flow.
This morning on Ver 977 my app screen’s Multisensor was changed to this one,
And after the automatic update later this morning it changed to this one,
So I’m missing the Temperature & Battery Data again.
Hope you can fix that soon.
Thanks again for all your effort and good luck :crossed_fingers:t2:
Best regards Peter.
"Hi Peter,
Sorry to hear about the ‘disco lights’ and the missing data! That is definitely not intended.
Since I have been refactoring parts of the code to improve the app’s stability, it seems a regression slipped in affecting the HOBEIAN Multisensor specifically. The missing battery/temperature suggests the device might not be initializing all capabilities correctly in the new version.
I will look into the driver code right away to restore the missing data and check the Lux reporting interval to stop the fluctuations.
Thanks for the screenshots, they are very helpful to identify the issue. I’ll push a fix as soon as possible.
I’m still getting the “payload too large” when doing a “homey app run”, which make troubleshooting difficult.
attilla-mlt:com.tuya.zigbee-packet attilla$ homey app run
✓ Pre-processing app...
✓ Validating app...
✓ App validated successfully against level `debug`
✓ Creating Remote Debug Session...
✖ <!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<title>Error</title>
</head>
<body>
<pre>Payload Too Large</pre>
</body>
</html>
Thanks Dylan and hope you’ll have a nice day :smiling_face:
New version published
Please test
If not Working well p’ease add an new interview and diag log
Size too large perhaps image are too big
Hi Dylan, been following your great work for a long while, and finally jumped on the bandwagon :wink:. thanks for your continued effort!
Installed a radar sensor: TZE200kb5noeto TS0601. Install went well, device is detected. the device detect persons, so far so good! only problem is that the battery detection is switching from 100% to 1 or 2% continuously The setting do allow to remove the battery detection, but even though the settings can be saved, it keeps getting different battery levels. anything you can do on that (and does it have to do with the SW, or is it a HW problem?)
Also, distance and humidity both do not work :slight_smile:. And the PIR/mmwave part does not seem to be present, only the motion
diagnostics: 211668d0-4dd2-44fa-b0b6-6a3802d52bd8
interview of the device:
Summary
“ids”: {
“modelId”: “TS0601”,
“manufacturerName”: “_TZE200_kb5noeto”
“endpoints”: {
“ieeeAddress”: “a4:c1:38:34:05:8a:5f:45”,
“networkAddress”: 50418,
“manufacturerName”: “_TZE200_kb5noeto”,
“endpointDescriptors”: [
“status”: “SUCCESS”,
“nwkAddrOfInterest”: 50418,
“_reserved”: 18,
“endpointId”: 1,
“applicationProfileId”: 260,
“applicationDeviceId”: 1026,
“applicationDeviceVersion”: 0,
“_reserved1”: 1,
“inputClusters”: [
0,
3,
1280,
1,
1024
“outputClusters”: []
“deviceType”: “enddevice”,
“receiveWhenIdle”: false,
“swBuildId”: “0122052017”,
“capabilities”: {
“alternatePANCoordinator”: false,
“deviceType”: false,
“powerSourceMains”: false,
“security”: false,
“allocateAddress”: true
“extendedEndpointDescriptors”: {
“1”: {
“clusters”: {
“basic”: {
“attributes”: [
“acl”: [
“readable”
“id”: 0,
“name”: “zclVersion”
“acl”: [
“readable”
“id”: 1,
“name”: “appVersion”
“acl”: [
“readable”
“id”: 2,
“name”: “stackVersion”
“acl”: [
“readable”
“id”: 3,
“name”: “hwVersion”
“acl”: [
“readable”,
“reportable”
“id”: 4,
“name”: “manufacturerName”,
“reportingConfiguration”: {
“status”: “NOT_FOUND”,
“direction”: “reported”
“acl”: [
“readable”
“id”: 5,
“name”: “modelId”
“acl”: [
“readable”
“id”: 7,
“name”: “powerSource”
“acl”: [
“readable”,
“writable”
“id”: 18,
“name”: “deviceEnabled”
“acl”: [
“readable”
“id”: 16384,
“name”: “swBuildId”
“acl”: [
“readable”
“id”: 65533,
“name”: “clusterRevision”
“commandsGenerated”: “UNSUP_GENERAL_COMMAND”,
“commandsReceived”: “UNSUP_GENERAL_COMMAND”
“identify”: {
“attributes”: [
“acl”: [
“readable”,
“writable”
“id”: 0,
“name”: “identifyTime”,
“value”: 0
“acl”: [
“readable”
“id”: 65533,
“name”: “clusterRevision”,
“value”: 1
“iasZone”: {
“attributes”: [
“acl”: [
“readable”
“id”: 0,
“name”: “zoneState”,
“value”: “notEnrolled”
“acl”: [
“readable”
“id”: 1,
“name”: “zoneType”,
“value”: “motionSensor”
“acl”: [
“readable”
“id”: 2,
“name”: “zoneStatus”,
“value”: {
“type”: “Buffer”,
“data”: [
1,
0
“acl”: [
“readable”,
“writable”
“id”: 16,
“name”: “iasCIEAddress”,
“value”: “3c:2e:f5:ff:fe:5c:a1:6f”
“acl”: [
“readable”
“id”: 17,
“name”: “zoneId”,
“value”: 0
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“powerConfiguration”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 32,
“name”: “batteryVoltage”,
“value”: 30,
“acl”: [
“readable”,
“reportable”
“id”: 33,
“name”: “batteryPercentageRemaining”,
“value”: 200,
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“illuminanceMeasurement”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “measuredValue”,
“value”: 33251,
“direction”: “reported”,
“attributeDataType”: 33,
“minInterval”: 10,
“maxInterval”: 300,
“minChange”: 1,
“status”: “SUCCESS”
“acl”: [
“readable”
“id”: 1,
“name”: “minMeasuredValue”,
“value”: 0
“acl”: [
“readable”
“id”: 2,
“name”: “maxMeasuredValue”,
“value”: 4000
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“bindings”: {}
Hi Dylan I’ve reset the Multisensor 45 Min ago and still no Temperature Humidity and Battery readings no Battery select in menu below, see screenshot and I’ve also got a diagnostic code: 9018c1c9-0c9c-4da4-9a84-ca0d896b34f1
for you.
I hope this is what you can use to solve it.
Best regards Peter.
No Change
aba2c0c3-9925-4528-b876-24deb63cf932
Summary
“ids”: {
“manufacturerName”: “_TZE284_o3x45p96”
“endpoints”: {
“ieeeAddress”: “a4:c1:38:5d:15:01:6a:9a”,
“networkAddress”: 25886,
“manufacturerName”: “_TZE284_o3x45p96”,
“nwkAddrOfInterest”: 25886,
“_reserved”: 22,
“endpointId”: 1,
“applicationDeviceId”: 81,
“_reserved1”: 1,
“inputClusters”: [
4,
5,
61184,
0,
60672
“outputClusters”: [
25,
10
“capabilities”: {
“security”: false,
“1”: {
“clusters”: {
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “nameSupport”,
“value”: {
“type”: “Buffer”,
“data”: [
0
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“scenes”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 1,
“acl”: [
“readable”,
“reportable”
“id”: 2,
“acl”: [
“readable”,
“reportable”
“id”: 3,
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“basic”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “zclVersion”,
“value”: 3
“acl”: [
“readable”,
“reportable”
“id”: 1,
“name”: “appVersion”,
“value”: 80
“acl”: [
“readable”,
“reportable”
“id”: 2,
“name”: “stackVersion”,
“value”: 0
“acl”: [
“readable”,
“reportable”
“id”: 3,
“name”: “hwVersion”,
“value”: 1
“acl”: [
“readable”,
“reportable”
“id”: 4,
“value”: “_TZE284_o3x45p96”
“acl”: [
“readable”,
“reportable”
“id”: 5,
“name”: “modelId”,
“value”: “TS0601”
“acl”: [
“readable”,
“reportable”
“id”: 6,
“name”: “dateCode”,
“value”: “”
“acl”: [
“readable”,
“reportable”
“id”: 7,
“name”: “powerSource”,
“value”: “battery”
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65502
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2
“acl”: [
“readable”,
“reportable”
“id”: 65534,
“name”: “attributeReportingStatus”,
“value”: “PENDING”
“acl”: [
“readable”,
“reportable”
“id”: 65506
“acl”: [
“readable”,
“reportable”
“id”: 65507
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65487
“bindings”: {
“ota”: {},
“time”: {
“attributes”: [
“acl”: [
“readable”
“id”: 65533,
“value”: 1
@dlnraja No Change for _TZE204_ztqnh5cg
The presence sensor worked some time in October last year, except the flows. As far as I understand: Until today (v980) there is an issue with Presence Sensors not being recognised anymore. Can you confirm?
Interview [APP][Pro] Universal TUYA Zigbee Device App - test - #1006 by tlink
@dlnraja don’t know if you had a look to my previous message including interviews for both contact sensor and amperemetric energy meter which are detected as unknown aigbee devices so far.
Hi Dylan it’s going wrong again after your latest update 989 the motion sensor is living it’s own life again what makes the lights going on and off again having Disco party outside now​:mirror_ball::man_dancing:t2:
Before on version 987 it was stable only wrong reading 9% in Humidity instead of 90% and no Battery menu bottom line.
Diagnostic code: 9b3495bb-16c7-4e90-8ee6-335b0f2fdec6
Good luck and thanks again, Peter.
please re give me new homey interneiw now they are to many herobian devices to manage withotu any conflict.
Hi, the
TZ3000_yj6k7vo
file didn’t work. Could you take a look at it? Thanks in advance.
e8f3e458-be41-4532-bdef-548545e1af87
Summary
“ids”: {
“modelId”: “TS0041”,
“manufacturerName”: “_TZ3000_yj6k7vfo”
“endpoints”: {
“ieeeAddress”: “a4:c1:38:8c:a9:71:b4:11”,
“networkAddress”: 55507,
“manufacturerName”: “_TZ3000_yj6k7vfo”,
“nwkAddrOfInterest”: 55507,
“_reserved”: 20,
“endpointId”: 1,
“applicationDeviceId”: 0,
“_reserved1”: 1,
“inputClusters”: [
1,
6,
57344,
0
“outputClusters”: [
25,
10
“_reserved”: 14,
“endpointId”: 2,
“_reserved1”: 1,
“inputClusters”: [
6,
1,
6
“outputClusters”:
“_reserved”: 14,
“endpointId”: 3,
“_reserved1”: 1,
“inputClusters”: [
6,
1,
6
“outputClusters”:
“_reserved”: 14,
“endpointId”: 4,
“_reserved1”: 1,
“inputClusters”: [
6,
1,
6
“outputClusters”:
“capabilities”: {
“security”: false,
“1”: {
“clusters”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 32,
“value”: 30,
“acl”: [
“readable”,
“reportable”
“id”: 33,
“value”: 200,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 1,
“onOff”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “onOff”,
“value”: false,
“attributeDataType”: 16,
“minInterval”: 60,
“maxInterval”: 600,
“status”: “SUCCESS”
“basic”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“value”: 3
“acl”: [
“readable”,
“reportable”
“id”: 1,
“value”: 68
“acl”: [
“readable”,
“reportable”
“id”: 2,
“value”: 0
“acl”: [
“readable”,
“reportable”
“id”: 3,
“value”: 1
“acl”: [
“readable”,
“reportable”
“id”: 4,
“value”: “_TZ3000_yj6k7vfo”
“acl”: [
“readable”,
“reportable”
“id”: 5,
“name”: “modelId”,
“value”: “TS0041”
“acl”: [
“readable”,
“reportable”
“id”: 6,
“name”: “dateCode”,
“value”: “”
“acl”: [
“readable”,
“reportable”
“id”: 7,
“value”: “battery”
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65502
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2
“acl”: [
“readable”,
“reportable”
“id”: 65534,
“value”: “PENDING”
“acl”: [
“readable”,
“reportable”
“id”: 65506
“acl”: [
“readable”,
“reportable”
“id”: 65507
“bindings”: {
“ota”: {},
“time”: {
“attributes”: [
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“2”: {
“clusters”: {
“onOff”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “onOff”,
“value”: false,
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 32,
“value”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 33,
“value”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 1,
“bindings”: {}
“3”: {
“clusters”: {
“onOff”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “onOff”,
“value”: false,
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 32,
“value”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 33,
“value”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 1,
“bindings”: {}
“4”: {
“clusters”: {
“onOff”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “onOff”,
“value”: false,
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0
“acl”: [
“readable”,
“reportable”
“id”: 32,
“value”: 0
“acl”: [
“readable”,
“reportable”
“id”: 33,
“value”: 0
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 1
“bindings”: {}
Water sensor:
Summary
“ids”: {
“modelId”: “ZG-222Z”,
“manufacturerName”: “HOBEIAN”
“endpoints”: {
“ieeeAddress”: “a4:c1:38:aa:a7:aa:7c:88”,
“networkAddress”: 65171,
“manufacturerName”: “HOBEIAN”,
“nwkAddrOfInterest”: 65171,
“_reserved”: 18,
“endpointId”: 1,
“_reserved1”: 1,
“inputClusters”: [
0,
3,
1280,
1
“outputClusters”: [
10
“capabilities”: {
“security”: false,
“1”: {
“clusters”: {
“basic”: {
“attributes”: [
“acl”: [
“readable”
“id”: 0,
“value”: 3
“acl”: [
“readable”
“id”: 1,
“value”: 65
“acl”: [
“readable”
“id”: 2,
“value”: 2
“acl”: [
“readable”
“id”: 3,
“value”: 1
“acl”: [
“readable”,
“reportable”
“id”: 4,
“value”: “HOBEIAN”,
“acl”: [
“readable”
“id”: 5,
“name”: “modelId”,
“value”: “ZG-222Z”
“acl”: [
“readable”
“id”: 7,
“value”: “battery”
“acl”: [
“readable”,
“writable”
“id”: 18,
“name”: “deviceEnabled”,
“value”: true
“acl”: [
“readable”
“id”: 16384,
“name”: “swBuildId”,
“value”: “0122052017”
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“identify”: {
“attributes”: [
“acl”: [
“readable”,
“writable”
“id”: 0,
“value”: 0
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“iasZone”: {
“attributes”: [
“acl”: [
“readable”
“id”: 0,
“value”: “enrolled”
“acl”: [
“readable”
“id”: 1,
“name”: “zoneType”,
“value”: “waterSensor”
“acl”: [
“readable”
“id”: 2,
“value”: {
“type”: “Buffer”,
“data”: [
0,
0
“acl”: [
“readable”,
“writable”
“id”: 16,
“value”: “3c:2e:f5:ff:fe:5c:b1:37”
“acl”: [
“readable”
“id”: 17,
“name”: “zoneId”,
“value”: 0
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 61441,
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 19,
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 32,
“value”: 30,
“acl”: [
“readable”,
“reportable”
“id”: 33,
“value”: 200,
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“bindings”: {
“time”: {
“attributes”: [],
Diagnostics: 33677378-eb74-437d-9ab6-35e8e4168a47
Radar sensor is only thing I have installed, so should be clean.
Motion works, distance, temp, lux, battery not working or present
interview
“ids”: {
“endpoints”: {
“_reserved”: 18,
“endpointId”: 1,
“_reserved1”: 1,
“inputClusters”: [
0,
3,
1280,
1,
1024
“capabilities”: {
“security”: false,
“1”: {
“clusters”: {
“basic”: {
“attributes”: [
“acl”: [
“readable”
“id”: 0,
“acl”: [
“readable”
“id”: 1,
“acl”: [
“readable”
“id”: 2,
“acl”: [
“readable”
“id”: 3,
“name”: “hwVersion”
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”
“id”: 5,
“name”: “modelId”
“acl”: [
“readable”
“id”: 7,
“acl”: [
“readable”,
“writable”
“id”: 18,
“acl”: [
“readable”
“id”: 16384,
“name”: “swBuildId”
“acl”: [
“readable”
“id”: 65533,
“identify”: {
“attributes”: [
“acl”: [
“readable”,
“writable”
“id”: 0,
“value”: 0
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“iasZone”: {
“attributes”: [
“acl”: [
“readable”
“id”: 0,
“acl”: [
“readable”
“id”: 1,
“name”: “zoneType”,
“acl”: [
“readable”
“id”: 2,
“value”: {
“type”: “Buffer”,
“data”: [
1,
0
“acl”: [
“readable”,
“writable”
“id”: 16,
“acl”: [
“readable”
“id”: 17,
“name”: “zoneId”,
“value”: 0
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 32,
“value”: 30,
“acl”: [
“readable”,
“reportable”
“id”: 33,
“value”: 200,
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“value”: 33251,
“minInterval”: 10,
“maxInterval”: 300,
“minChange”: 1,
“status”: “SUCCESS”
“acl”: [
“readable”
“id”: 1,
“value”: 0
“acl”: [
“readable”
“id”: 2,
“value”: 4000
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“bindings”: {}
Hi Dylan Good day, I’ve made a new interview from my HOBEIAN ZG-204ZV Mutisensor.
  "ids": {
    "modelId": "ZG-204ZV",
    "manufacturerName": "HOBEIAN"
  "endpoints": {
    "ieeeAddress": "a4:c1:38:d5:15:e9:3c:ae",
    "networkAddress": 8870,
    "manufacturerName": "HOBEIAN",
    "endpointDescriptors": [
        "status": "SUCCESS",
        "nwkAddrOfInterest": 8870,
        "_reserved": 26,
        "endpointId": 1,
        "applicationProfileId": 260,
        "applicationDeviceId": 1026,
        "_reserved1": 1,
        "inputClusters": [
          0,
          3,
          1280,
          61184,
          1026,
          1029,
          1,
          1024
        "outputClusters": [
          3
    "deviceType": "enddevice",
    "receiveWhenIdle": false,
    "swBuildId": "0122052017",
    "capabilities": {
      "alternatePANCoordinator": false,
      "deviceType": false,
      "powerSourceMains": false,
      "security": false,
      "allocateAddress": true
    "extendedEndpointDescriptors": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "name": "zclVersion"
                "acl": [
                  "readable"
                "id": 1,
                "name": "appVersion"
                "acl": [
                  "readable"
                "id": 2,
                "name": "stackVersion"
                "acl": [
                  "readable"
                "id": 3,
                "name": "hwVersion"
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "name": "manufacturerName",
                "reportingConfiguration": {
                  "status": "NOT_FOUND",
                  "direction": "reported"
                "acl": [
                  "readable"
                "id": 5,
                "name": "modelId"
                "acl": [
                  "readable"
                "id": 7,
                "name": "powerSource"
                "acl": [
                  "readable",
                  "writable"
                "id": 18,
                "name": "deviceEnabled"
                "acl": [
                  "readable"
                "id": 16384,
                "name": "swBuildId"
                "acl": [
                  "readable"
                "id": 65533,
                "name": "clusterRevision"
                "acl": [
                  "readable"
                "id": 6,
                "name": "dateCode"
            "commandsGenerated": "UNSUP_GENERAL_COMMAND",
            "commandsReceived": "UNSUP_GENERAL_COMMAND"
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable"
                "id": 0,
                "name": "identifyTime",
                "value": 0
                "acl": [
                  "readable"
                "id": 65533,
                "name": "clusterRevision",
                "value": 1
          "iasZone": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "name": "zoneState",
                "value": "enrolled"
                "acl": [
                  "readable"
                "id": 1,
                "name": "zoneType",
                "value": "motionSensor"
                "acl": [
                  "readable"
                "id": 2,
                "name": "zoneStatus",
                "value": {
                  "type": "Buffer",
                  "data": [
                    1,
                    0
                "acl": [
                  "readable",
                  "writable"
                "id": 16,
                "name": "iasCIEAddress",
                "value": "bc:02:6e:ff:fe:9f:ae:44"
                "acl": [
                  "readable"
                "id": 17,
                "name": "zoneId",
                "value": 0
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 61441,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 19,
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
          "temperatureMeasurement": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "measuredValue",
                "value": 2020,
                  "direction": "reported",
                  "attributeDataType": 41,
                  "minInterval": 30,
                  "maxInterval": 3600,
                  "minChange": 10,
                  "status": "SUCCESS"
                "acl": [
                  "readable"
                "id": 1,
                "name": "minMeasuredValue",
                "value": -32768
                "acl": [
                  "readable"
                "id": 2,
                "name": "maxMeasuredValue",
                "value": -32768
                "acl": [
                  "readable"
                "id": 3
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
          "relativeHumidity": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 6920,
                  "attributeDataType": 33,
                  "minInterval": 300,
                  "minChange": 200,
                  "status": "SUCCESS"
                "acl": [
                  "readable"
                "id": 1,
                "value": 32768
                "acl": [
                  "readable"
                "id": 2,
                "value": 32768
                "acl": [
                  "readable"
                "id": 3,
                "name": "tolerance",
                "value": 0
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
          "powerConfiguration": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 32,
                "name": "batteryVoltage",
                "value": 30,
                "acl": [
                  "readable",
                  "reportable"
                "id": 33,
                "name": "batteryPercentageRemaining",
                "value": 200,
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
          "illuminanceMeasurement": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 27926,
                  "minInterval": 10,
                  "maxInterval": 300,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable"
                "id": 1,
                "value": 0
                "acl": [
                  "readable"
                "id": 2,
                "value": 4000
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
        "bindings": {
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable"
                "id": 0,
                "value": 0
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
Good Luck and have a nice day, regards Peter,
