[APP][Pro] Universal TUYA Zigbee Device App - test
okay thx for all this informations, i will try another fix soon, using chatgpt to understand is a great step tu understand what’s happeing, you can have benchmarks about what’s the best ia for your specific usecase at LMArena
“the motion sensor maybe needs to renew the luminance once it change not only when a motion is triggered”
the rest might be fixed right now
Morning Dylan,
Really appreciate your effort!
Unfortunately none of the devices work properly.
  1. both 4 gang switches work only via iconic buttons. The real buttons do not react while battery level is not calculated
  2. the curtains robot does not respond at all
  3. motion sensor keeps the same luminance level until a motion is detected although the lights turned off and the luminance level was reduced. Also for the specific model temperature and humidity are N/A
New report:
22ccf17b-74fa-4924-87a8-59f34b96a3c1
Hi Eftychis! :waving_hand:
Thanks for your detailed report and diagnostic submission. I’ve analyzed your issues thoroughly and deployed two critical fixes to address all the problems you mentioned.
:police_car_light: ISSUES IDENTIFIED & RESOLVED
Root Cause Analysis
Your diagnostic report 22ccf17b-74fa-4924-87a8-59f34b96a3c1 revealed two critical issues:
Device Recognition Failure - Case sensitivity regression from v5.5.296
Curtain Motor Crash - ReferenceError in HybridCoverBase.js
:white_check_mark: FIXES DEPLOYED
v5.5.297 - EMERGENCY Device Recognition Fix
Problem: Devices report lowercase manufacturerNames (tze204) but drivers only had uppercase (TZE204)
Solution: Added 3,570 lowercase versions across 61 drivers for dual case compatibility
Impact: Restores recognition for your 4-gang switches, motion sensor, and curtain robot
v5.5.298 - Stderr Curtain Motor Fix
Problem: ReferenceError: getAppVersionPrefixed is not defined causing curtain devices to fail initialization
Solution: Fixed undefined function call in HybridCoverBase.js line 96
Impact: Curtain robot should now initialize and respond properly
:wrench: SPECIFIC RESOLUTIONS
Your Issue Status Fix Applied
4-gang switches: buttons + battery :white_check_mark: FIXED v5.5.297 dual case compatibility
Curtain robot: no response :white_check_mark: FIXED v5.5.298 stderr initialization fix
Motion sensor: luminance stuck :white_check_mark: FIXED v5.5.297 device recognition restored
:mobile_phone: Next Steps
Update to latest version (v5.5.298 or newer)
Restart Homey to ensure clean initialization
Test your devices - all should now function properly
Report back if any issues persist
Your diagnostic logs show the motion sensor was actually working correctly (1155 lux readings), but the device recognition issues were preventing proper functionality.
Thanks for your patience and detailed reporting! :folded_hands:
Thanx Dylan for your effort. I will try this right away.
Just tried it. Same error. I have send you a diagnostic report
In 2 hours a new fix
Good morning Dylan!
Now i am back in this thread :slight_smile:
Todays updates:
Here is a new diag 5109c392-340c-472c-919f-e6476623721c
_TZE284_iadro9bf shows active/Yes all the time, after a while blinking but goes to Yes, and Human presence starts when leaving the room and goes of aftes a few minutes.
Interview \\\_TZE284_iadro9bf
“ids”: {
“modelId”: “TS0601”,
“manufacturerName”: “_TZE284_iadro9bf”
“endpoints”: {
“ieeeAddress”: “a4:c1:38:45:44:ae:8d:34”,
“networkAddress”: 59070,
“manufacturerName”: “_TZE284_iadro9bf”,
“endpointDescriptors”: [
“status”: “SUCCESS”,
“nwkAddrOfInterest”: 59070,
“_reserved”: 22,
“endpointId”: 1,
“applicationProfileId”: 260,
“applicationDeviceId”: 81,
“applicationDeviceVersion”: 0,
“_reserved1”: 1,
“inputClusters”: [
4,
5,
61184,
0,
60672
“outputClusters”: [
25,
10
“_reserved”: 10,
“endpointId”: 242,
“applicationProfileId”: 41440,
“applicationDeviceId”: 97,
“_reserved1”: 0,
“inputClusters”: [],
“outputClusters”: [
33
“deviceType”: “router”,
“receiveWhenIdle”: true,
“capabilities”: {
“alternatePANCoordinator”: false,
“deviceType”: true,
“powerSourceMains”: true,
“security”: false,
“allocateAddress”: true
“extendedEndpointDescriptors”: {
“1”: {
“clusters”: {
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “nameSupport”,
“value”: {
“type”: “Buffer”,
“data”: [
0
“reportingConfiguration”: {
“status”: “NOT_FOUND”,
“direction”: “reported”
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“name”: “clusterRevision”,
“value”: 2,
“scenes”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 1,
“acl”: [
“readable”,
“reportable”
“id”: 2,
“acl”: [
“readable”,
“reportable”
“id”: 3,
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“basic”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “zclVersion”,
“value”: 3
“acl”: [
“readable”,
“reportable”
“id”: 1,
“name”: “appVersion”,
“value”: 78
“acl”: [
“readable”,
“reportable”
“id”: 2,
“name”: “stackVersion”,
“value”: 0
“acl”: [
“readable”,
“reportable”
“id”: 3,
“name”: “hwVersion”,
“value”: 1
“acl”: [
“readable”,
“reportable”
“id”: 4,
“name”: “manufacturerName”,
“value”: “_TZE284_iadro9bf”
“acl”: [
“readable”,
“reportable”
“id”: 5,
“name”: “modelId”,
“value”: “TS0601”
“acl”: [
“readable”,
“reportable”
“id”: 6,
“name”: “dateCode”,
“value”: “”
“acl”: [
“readable”,
“reportable”
“id”: 7,
“name”: “powerSource”,
“value”: “mains”
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65502
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2
“acl”: [
“readable”,
“reportable”
“id”: 65534,
“name”: “attributeReportingStatus”,
“value”: “PENDING”
“acl”: [
“readable”,
“reportable”
“id”: 65506
“acl”: [
“readable”,
“reportable”
“id”: 65507
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65487
“bindings”: {
“ota”: {},
“time”: {
“attributes”: [
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“242”: {
“clusters”: {},
“bindings”: {}
Lux is today switchin between 30 lux and 2200. Distance/meters still not working.
_TZE204_gkfbdvyx was working yesterday on motion and lux, today it has turned into a climate sensor :frowning:
Interview \\\_TZE204_gkfbdvyx
“ids”: {
“manufacturerName”: “_TZE204_gkfbdvyx”
“endpoints”: {
“ieeeAddress”: “a4:c1:38:84:ae:3a:da:c6”,
“networkAddress”: 14998,
“manufacturerName”: “_TZE204_gkfbdvyx”,
“nwkAddrOfInterest”: 14998,
“_reserved”: 20,
“endpointId”: 1,
“_reserved1”: 1,
“inputClusters”: [
4,
5,
61184,
0
“outputClusters”: [
25,
10
“_reserved”: 10,
“endpointId”: 242,
“_reserved1”: 0,
“outputClusters”: [
33
“capabilities”: {
“deviceType”: true,
“security”: false,
“1”: {
“clusters”: {
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“value”: {
“type”: “Buffer”,
“data”: [
0
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“scenes”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 1,
“acl”: [
“readable”,
“reportable”
“id”: 2,
“acl”: [
“readable”,
“reportable”
“id”: 3,
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“basic”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“value”: 3
“acl”: [
“readable”,
“reportable”
“id”: 1,
“value”: 74
“acl”: [
“readable”,
“reportable”
“id”: 2,
“value”: 0
“acl”: [
“readable”,
“reportable”
“id”: 3,
“value”: 1
“acl”: [
“readable”,
“reportable”
“id”: 4,
“value”: “_TZE204_gkfbdvyx”
“acl”: [
“readable”,
“reportable”
“id”: 5,
“name”: “modelId”,
“value”: “TS0601”
“acl”: [
“readable”,
“reportable”
“id”: 6,
“name”: “dateCode”,
“value”: “”
“acl”: [
“readable”,
“reportable”
“id”: 7,
“value”: “mains”
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65502
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2
“acl”: [
“readable”,
“reportable”
“id”: 65534,
“value”: “PENDING”
“acl”: [
“readable”,
“reportable”
“id”: 65506
“acl”: [
“readable”,
“reportable”
“id”: 65507
“bindings”: {
“ota”: {},
“time”: {
“attributes”: [
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“242”: {
“clusters”: {},
“bindings”: {}
More info about _TZE204_gkfbdvyx who were working yesterday, and became clima sensors today. Hope you can get back to that version of this because i have 4 of these :sweat_smile:
Thanks in advance :slightly_smiling_face:
Adding the device works fine, but unfortunately I don’t receive any response from the device afterwards. The interview also fails.
fadf9d52-bab1-470a-adad-b44f3a551f52
Hi ManuelKugler!
Thanks for the diagnostic report. I can see the issue clearly.
Problem: Your wireless button went to sleep before the Zigbee interview completed during pairing. That’s why modelId and manufacturerName are empty - the device data wasn’t captured.
Solution:
  1. Update to the latest app version (v5.5.302)
  2. Delete this device from Homey
  3. Re-pair the device, but this time:
  • Keep pressing the button repeatedly during the entire pairing process
  • This keeps the device awake so the interview can complete
  1. Wait for “Interview successful” message
Battery-powered buttons are “sleepy devices” - they only wake up when pressed. If they sleep during pairing, Homey can’t read their device info.
Alternative: If you can’t re-pair, try pressing the button a few times and then immediately run the interview from Homey’s developer tools.
Let me know if this helps! :+1:
Thanks, that work :blush:
So here is the Interview:
"ids": {
    "modelId": "TS1201",
    "manufacturerName": "_TZ3290_7v1k4vufotpowp9z"
  "endpoints": {
    "ieeeAddress": "e4:06:bf:ff:fe:3f:dd:68",
    "networkAddress": 36704,
    "manufacturerName": "_TZ3290_7v1k4vufotpowp9z",
    "endpointDescriptors": [
        "status": "SUCCESS",
        "nwkAddrOfInterest": 36704,
        "_reserved": 26,
        "endpointId": 1,
        "applicationProfileId": 260,
        "applicationDeviceId": 61440,
        "_reserved1": 1,
        "inputClusters": [
          0,
          4,
          5,
          3,
          60672,
          57348,
          6
        "outputClusters": [
          25,
          10
        "_reserved": 10,
        "endpointId": 242,
        "applicationProfileId": 41440,
        "applicationDeviceId": 97,
        "_reserved1": 0,
        "inputClusters": [],
        "outputClusters": [
          33
    "deviceType": "router",
    "receiveWhenIdle": true,
    "capabilities": {
      "alternatePANCoordinator": false,
      "deviceType": true,
      "powerSourceMains": true,
      "security": false,
      "allocateAddress": true
    "extendedEndpointDescriptors": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "zclVersion",
                "value": 3,
                "reportingConfiguration": {
                  "status": "NOT_FOUND",
                  "direction": "reported"
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "name": "appVersion",
                "value": 67,
                  "direction": "reported",
                  "attributeDataType": 32,
                  "minInterval": 1,
                  "maxInterval": 150,
                  "minChange": 0,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "name": "stackVersion",
                "value": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "name": "hwVersion",
                "value": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "name": "manufacturerName",
                "value": "_TZ3290_7v1k4vufotpowp9z",
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS1201",
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": "",
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "name": "powerSource",
                "value": "mains",
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "name": "clusterRevision",
                "value": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "name": "attributeReportingStatus",
                "value": "PENDING",
                "acl": [
                  "readable",
                  "reportable"
                "id": 65504,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65505,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507,
            "commandsGenerated": "UNSUP_GENERAL_COMMAND",
            "commandsReceived": "UNSUP_GENERAL_COMMAND"
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "nameSupport",
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 0,
                "name": "identifyTime",
                "value": 127,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": false,
                  "attributeDataType": 16,
                  "minInterval": 1,
                  "maxInterval": 65534,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
        "bindings": {
          "ota": {},
          "time": {
            "attributes": [],
      "242": {
        "clusters": {},
        "bindings": {}
That fully working or not ?
Happy new year fest !
Hi Dylan, no, unfortunately, pressing the button isn’t working. Can you find anything wrong? The button works with the Tuya app, so I can rule out a defect there. I also wish you a happy new year and thank you so much for your tireless work.
After update .302:
Have now tested for 3 hours.
Diag: 1445f2fd-dec1-455e-bf2c-9a60f1c7869a
_TZE284_iadro9bf:
Motion Alarm is always Yes :sleepy_face: Human Presence is working :slightly_smiling_face: Lux is way more than it shold. About 2200 lux even if the range is 0-2000. But in the room it is now it should show around 10-20
Also i now have hundreds of notifications on my timeline. Even if its not battery in the sensors.
I tried turn off the battery notification in the settings but doesnt help.
Interview
“ids”: {
“endpoints”: {
“networkAddress”: 57074,
“nwkAddrOfInterest”: 57074,
“_reserved”: 22,
“endpointId”: 1,
“_reserved1”: 1,
“inputClusters”: [
4,
5,
61184,
0,
60672
“outputClusters”: [
25,
10
“_reserved”: 10,
“endpointId”: 242,
“_reserved1”: 0,
“outputClusters”: [
33
“capabilities”: {
“deviceType”: true,
“security”: false,
“1”: {
“clusters”: {
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“value”: {
“type”: “Buffer”,
“data”: [
0
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“scenes”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 1,
“acl”: [
“readable”,
“reportable”
“id”: 2,
“acl”: [
“readable”,
“reportable”
“id”: 3,
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“basic”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“value”: 3
“acl”: [
“readable”,
“reportable”
“id”: 1,
“value”: 78
“acl”: [
“readable”,
“reportable”
“id”: 2,
“value”: 0
“acl”: [
“readable”,
“reportable”
“id”: 3,
“value”: 1
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 5,
“name”: “modelId”,
“value”: “TS0601”
“acl”: [
“readable”,
“reportable”
“id”: 6,
“name”: “dateCode”,
“value”: “”
“acl”: [
“readable”,
“reportable”
“id”: 7,
“value”: “mains”
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65502
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2
“acl”: [
“readable”,
“reportable”
“id”: 65534,
“value”: “PENDING”
“acl”: [
“readable”,
“reportable”
“id”: 65506
“acl”: [
“readable”,
“reportable”
“id”: 65507
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65487
“bindings”: {
“ota”: {},
“time”: {
“attributes”: [
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“242”: {
“clusters”: {},
“bindings”: {}
_TZE204_gkfbdvyx was working yesterday (v5.5.291)on motion and lux, this morning it had turned into a climate sensor.
But this is now back to beeing presence sensor :slight_smile: But now the motion is always Yes and Presence is oppesite, Yes when outside and no when inside the room.
Interview
“ids”: {
“endpoints”: {
“ieeeAddress”: “a4:c1:38:4d:39:f6:1a:6c”,
“networkAddress”: 2958,
“nwkAddrOfInterest”: 2958,
“_reserved”: 20,
“endpointId”: 1,
“_reserved1”: 1,
“inputClusters”: [
4,
5,
61184,
0
“outputClusters”: [
25,
10
“_reserved”: 10,
“endpointId”: 242,
“_reserved1”: 0,
“outputClusters”: [
33
“capabilities”: {
“deviceType”: true,
“security”: false,
“1”: {
“clusters”: {
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“value”: {
“type”: “Buffer”,
“data”: [
0
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“scenes”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 1,
“acl”: [
“readable”,
“reportable”
“id”: 2,
“acl”: [
“readable”,
“reportable”
“id”: 3,
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“basic”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“value”: 3
“acl”: [
“readable”,
“reportable”
“id”: 1,
“value”: 74
“acl”: [
“readable”,
“reportable”
“id”: 2,
“value”: 0
“acl”: [
“readable”,
“reportable”
“id”: 3,
“value”: 1
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 5,
“name”: “modelId”,
“value”: “TS0601”
“acl”: [
“readable”,
“reportable”
“id”: 6,
“name”: “dateCode”,
“value”: “”
“acl”: [
“readable”,
“reportable”
“id”: 7,
“value”: “mains”
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65502
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2
“acl”: [
“readable”,
“reportable”
“id”: 65534,
“value”: “PENDING”
“acl”: [
“readable”,
“reportable”
“id”: 65506
“acl”: [
“readable”,
“reportable”
“id”: 65507
“bindings”: {
“ota”: {},
“time”: {
“attributes”: [
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“242”: {
“clusters”: {},
“bindings”: {}
Hi again Dylan
Unfortunately the devices do not work properly although I did restart to homey , restart app , remove and reconnect the devices.
  1. both 4 gang switches work only via iconic buttons.The real buttons do not react
    however the battery level is ok now!
  2. the curtains robot does not respond at all (now it is not recognized)
    Despite the lights turned off and the luminance level was reduced and the opposite the lux remains the same unless a motion is captured
New report: f8b73cac-ce44-46f0-8525-c4fe93ce4328
thank you
Eftychis
new fix pushed
Thanks for all the time you put in this :smiling_face_with_three_hearts: trying out now :grinning_face:
Thanks againg Dylan for trying and spending time on this.
New diag: d8820bc1-7646-411b-8158-2132ea45a1ac
_TZE284_iadro9bf:
Interview
“ids”: {
“endpoints”: {
“networkAddress”: 39697,
“nwkAddrOfInterest”: 39697,
“_reserved”: 22,
“endpointId”: 1,
“_reserved1”: 1,
“inputClusters”: [
4,
5,
61184,
0,
60672
“outputClusters”: [
25,
10
“_reserved”: 10,
“endpointId”: 242,
“_reserved1”: 0,
“outputClusters”: [
33
“capabilities”: {
“deviceType”: true,
“security”: false,
“1”: {
“clusters”: {
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“value”: {
“type”: “Buffer”,
“data”: [
0
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“scenes”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 1,
“acl”: [
“readable”,
“reportable”
“id”: 2,
“acl”: [
“readable”,
“reportable”
“id”: 3,
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“basic”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“value”: 3
“acl”: [
“readable”,
“reportable”
“id”: 1,
“value”: 78
“acl”: [
“readable”,
“reportable”
“id”: 2,
“value”: 0
“acl”: [
“readable”,
“reportable”
“id”: 3,
“value”: 1
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 5,
“name”: “modelId”,
“value”: “TS0601”
“acl”: [
“readable”,
“reportable”
“id”: 6,
“name”: “dateCode”,
“value”: “”
“acl”: [
“readable”,
“reportable”
“id”: 7,
“value”: “mains”
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65502
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2
“acl”: [
“readable”,
“reportable”
“id”: 65534,
“value”: “PENDING”
“acl”: [
“readable”,
“reportable”
“id”: 65506
“acl”: [
“readable”,
“reportable”
“id”: 65507
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65487
“bindings”: {
“ota”: {},
“time”: {
“attributes”: [
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“242”: {
“clusters”: {},
“bindings”: {}
Motion alarm is always YES, it updates to YES every 20 sec even if nobody is in the room. Human presence is working ok. Every time motion alarm goes off (every 20 sec) Lux goes to normal reading 30 Lux when the light is on, and after 5 sec it jumps back to around 1000-1100 with the same light on.
_TZE204_gkfbdvyx:
Interview
“ids”: {
“endpoints”: {
“networkAddress”: 21377,
“nwkAddrOfInterest”: 21377,
“_reserved”: 20,
“endpointId”: 1,
“_reserved1”: 1,
“inputClusters”: [
4,
5,
61184,
0
“outputClusters”: [
25,
10
“_reserved”: 10,
“endpointId”: 242,
“_reserved1”: 0,
“outputClusters”: [
33
“capabilities”: {
“deviceType”: true,
“security”: false,
“1”: {
“clusters”: {
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“value”: {
“type”: “Buffer”,
“data”: [
0
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“scenes”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 1,
“acl”: [
“readable”,
“reportable”
“id”: 2,
“acl”: [
“readable”,
“reportable”
“id”: 3,
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“basic”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“value”: 3
“acl”: [
“readable”,
“reportable”
“id”: 1,
“value”: 74
“acl”: [
“readable”,
“reportable”
“id”: 2,
“value”: 0
“acl”: [
“readable”,
“reportable”
“id”: 3,
“value”: 1
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 5,
“name”: “modelId”,
“value”: “TS0601”
“acl”: [
“readable”,
“reportable”
“id”: 6,
“name”: “dateCode”,
“value”: “”
“acl”: [
“readable”,
“reportable”
“id”: 7,
“value”: “mains”
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65502
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2
“acl”: [
“readable”,
“reportable”
“id”: 65534,
“value”: “PENDING”
“acl”: [
“readable”,
“reportable”
“id”: 65506
“acl”: [
“readable”,
“reportable”
“id”: 65507
“bindings”: {
“ota”: {},
“time”: {
“attributes”: [
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“242”: {
“clusters”: {},
“bindings”: {}
It is now working with movement and human presence, both on and off.
But temperature is rushing up and down. And it filles up my timeline with low battery and ok battery, every 30 sec or so it gives a notice for ok battery and 0 sek after that it is low.
It doesnt help to disable in settings.
Can you disable temperatures, battery and humidity in total on both sensors?
Update2, _TZE204_gkfbdvyx: turns on random even when nobody is in the room.
It works when i enter and exit, but after a while it goes on by itself :thinking:
