Not sure but i guess this is it ![]()
4659aff2-77d6-4fad-a5b5-16539afbd80f
This is soooo over my head ![]()
perfect i recieved it
fixed now please test it again , if not working well detail issues and do a new daig log. version 5.5.276
I have released a new fix
Please try it again and tell me what’s happening and if not totally well please send me an new diag report
Hi Dylan,
Unfortunately both curtains robot and the 4 gang Switch(the one above but also a MOES one _TZ3000_wkai4ga5) Do not respond
No battery level , no buttons responses
Thank you in advance
Please do an diag log
Here is a new diag
bf8130dd-4742-4b85-a2c8-d208dff7aeec
_TZE284_iadro9bf shows active when not in the room and inactive when i enter the room.
Lux is over spesified range from producer (0-2000) and meters is not responsing.
_TZE204_gkfbdvyx is working fine in motion detection but no lux or meters is working.
This night a new release
Everyone can check if it’s fixed or not
Done
3125fd27-09e2-4a5d-a2f6-892c9c0a8581
Thank you for the diagnostics report. However, the logs received are from a smoke detector, not the 4-gang switch or curtain robot you mentioned.
To help you, I need:
Manufacturer IDs of the problematic devices
Diagnostics from those specific devices
Update to v5.5.284 (just published)
Please send new diagnostics from the actual problematic devices and I’ll
investigate further.
when you send a new diag please cli on some buttons randimmly before ( like long press , short double , button 1 2 3 and 4 multiple times ) sans for other devices
Dylan
@Fiek - v5.5.291 deployed! ![]()
I found and fixed the root cause of your “Could not get device by id” error:
The problem: HybridLightBase wasn’t registering the capabilities (onoff, dim) with Homey’s flow system. As a result, Homey couldn’t find the device when the flows tried to trigger.
The solution: Added registerCapability() for all light capabilities, which properly connects them to Homey’s flow system.
Required action:
Update the app to v5.5.291
REMOVE your TS0505B bulb from Homey
RE-PAIR the bulb
Re-pairing is necessary because the ZCL bindings are configured during the initial pairing. After that, the native flows (“Light on”, “Brightness changed”) will work correctly!
Here is a new diag 592f8506-a989-4955-bf4d-67947d791b0a
It`s opposite: _TZE284_iadro9bf shows active/Yes when not in the room, and inactive/No when i enter the room.
“ids”: {
“modelId”: “TS0601”,
“manufacturerName”: “_TZE284_iadro9bf”
“endpoints”: {
“ieeeAddress”: “a4:c1:38:45:44:ae:8d:34”,
“networkAddress”: 64852,
“manufacturerName”: “_TZE284_iadro9bf”,
“endpointDescriptors”: [
“status”: “SUCCESS”,
“nwkAddrOfInterest”: 64852,
“_reserved”: 22,
“endpointId”: 1,
“applicationProfileId”: 260,
“applicationDeviceId”: 81,
“applicationDeviceVersion”: 0,
“_reserved1”: 1,
“inputClusters”: [
4,
5,
61184,
0,
60672
“outputClusters”: [
25,
10
“_reserved”: 10,
“endpointId”: 242,
“applicationProfileId”: 41440,
“applicationDeviceId”: 97,
“_reserved1”: 0,
“inputClusters”: [],
“outputClusters”: [
33
“deviceType”: “router”,
“receiveWhenIdle”: true,
“capabilities”: {
“alternatePANCoordinator”: false,
“deviceType”: true,
“powerSourceMains”: true,
“security”: false,
“allocateAddress”: true
“extendedEndpointDescriptors”: {
“1”: {
“clusters”: {
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “nameSupport”,
“value”: {
“type”: “Buffer”,
“data”: [
0
“reportingConfiguration”: {
“status”: “NOT_FOUND”,
“direction”: “reported”
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“name”: “clusterRevision”,
“value”: 2,
“scenes”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 1,
“acl”: [
“readable”,
“reportable”
“id”: 2,
“acl”: [
“readable”,
“reportable”
“id”: 3,
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“basic”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “zclVersion”,
“value”: 3
“acl”: [
“readable”,
“reportable”
“id”: 1,
“name”: “appVersion”,
“value”: 78
“acl”: [
“readable”,
“reportable”
“id”: 2,
“name”: “stackVersion”,
“value”: 0
“acl”: [
“readable”,
“reportable”
“id”: 3,
“name”: “hwVersion”,
“value”: 1
“acl”: [
“readable”,
“reportable”
“id”: 4,
“name”: “manufacturerName”,
“value”: “_TZE284_iadro9bf”
“acl”: [
“readable”,
“reportable”
“id”: 5,
“name”: “modelId”,
“value”: “TS0601”
“acl”: [
“readable”,
“reportable”
“id”: 6,
“name”: “dateCode”,
“value”: “”
“acl”: [
“readable”,
“reportable”
“id”: 7,
“name”: “powerSource”,
“value”: “mains”
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65502
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2
“acl”: [
“readable”,
“reportable”
“id”: 65534,
“name”: “attributeReportingStatus”,
“value”: “PENDING”
“acl”: [
“readable”,
“reportable”
“id”: 65506
“acl”: [
“readable”,
“reportable”
“id”: 65507
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65487
“bindings”: {
“ota”: {},
“time”: {
“attributes”: [
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“242”: {
“clusters”: {},
“bindings”: {}
Lux should be around 10 according to the sensor standing nextby. Distance/meters not working.
_TZE204_gkfbdvyx is working fine in motion detection AND NOW lux, but distance/meters is not working.(Not important)
“ids”: {
“manufacturerName”: “_TZE204_gkfbdvyx”
“endpoints”: {
“ieeeAddress”: “a4:c1:38:84:ae:3a:da:c6”,
“networkAddress”: 57366,
“manufacturerName”: “_TZE204_gkfbdvyx”,
“nwkAddrOfInterest”: 57366,
“_reserved”: 20,
“endpointId”: 1,
“_reserved1”: 1,
“inputClusters”: [
4,
5,
61184,
0
“outputClusters”: [
25,
10
“_reserved”: 10,
“endpointId”: 242,
“_reserved1”: 0,
“outputClusters”: [
33
“capabilities”: {
“deviceType”: true,
“security”: false,
“1”: {
“clusters”: {
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“value”: {
“type”: “Buffer”,
“data”: [
0
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“scenes”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 1,
“acl”: [
“readable”,
“reportable”
“id”: 2,
“acl”: [
“readable”,
“reportable”
“id”: 3,
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“basic”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“value”: 3
“acl”: [
“readable”,
“reportable”
“id”: 1,
“value”: 74
“acl”: [
“readable”,
“reportable”
“id”: 2,
“value”: 0
“acl”: [
“readable”,
“reportable”
“id”: 3,
“value”: 1
“acl”: [
“readable”,
“reportable”
“id”: 4,
“value”: “_TZE204_gkfbdvyx”
“acl”: [
“readable”,
“reportable”
“id”: 5,
“name”: “modelId”,
“value”: “TS0601”
“acl”: [
“readable”,
“reportable”
“id”: 6,
“name”: “dateCode”,
“value”: “”
“acl”: [
“readable”,
“reportable”
“id”: 7,
“value”: “mains”
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65502
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2
“acl”: [
“readable”,
“reportable”
“id”: 65534,
“value”: “PENDING”
“acl”: [
“readable”,
“reportable”
“id”: 65506
“acl”: [
“readable”,
“reportable”
“id”: 65507
“bindings”: {
“ota”: {},
“time”: {
“attributes”: [
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“242”: {
“clusters”: {},
“bindings”: {}
Hi again Dylan,
In my first query I sent the code of each device combined with their interviews and a link for the picture.
Unfortunately I cannot extract a diagnostic report throughout the advanced Settings of the device only through the app. I cannot find the menu you referred above. Maybe I am missing something..?
clique create diagnostic repoort after multiple press on your moes device
ef3578f2-f732-489d-a469-047db96cfbc4
just created
Thank you
Eftychis
thx dude
I realized that the iconic buttons in the device are working but this is not the case with the real buttons.
If it helps in the previous app (Johan’s) the 4 gang button was working perfectly
It was needed only to add the New devices manufacturers name to the drivers.
I had done it through a version of mine (ChatGPT) but as you build the app from scratch and as I have more devices I decided to move to your app.
Also the motion sensor maybe needs to renew the luminance once it change not only when a motion is triggered.
