[APP][Pro] Universal TUYA Zigbee Device App - test
Hi, can I ask for help and add a device? ;)
Hey @dlnraja
I can now add my smart button correctly and it shows battery data but the button presses don’t get passed through in test flows! Getting closer!
Side question: Is it possible to remove the tabs for a device where they’re not applicable? Eg. On a device that doesn’t have a power button (AKA no listener for that function) can you hide that tab?
Perhaps the same can be true for motion sensors. My motion sensor only has light and motion, yet there are readouts for humidity, temperature and contact.
Hi
Seems like you are almost there with the sensor also!
I think the battery is correct, but temp and humidity is not working atm.
Good luck mate!
okey i check everthing for the next version
now it’s must be fixed
yes anyway :wink:
about the tab, idk. For the rest it’s must be fixed right now, issues remain ?
Seems to be working now :heart_eyes:
Thank you so much!
@dlnraja I still see this message on the recent latest builds
Could you please send me an new app diag log
Hi thanks a lot for helping out. Heres the info I have and I shared a diagnosis report through the app with the code 2215bd68-2afb-43ba-a8df-444b70ee7454.
Do you need more info?
thx
I had this same “could not get device by id” error too.
the next version might fix your issue :
  • Fixed ‘could not get device by id’ errors in FlowCardManager.js
  • Added protective device reference validation to ALL flow card handlers (conditions + actions)
  • Prevents flow crashes when device references become corrupted/invalid
  • Resolves button flow integration issues reported post v5.5.215
  • Enhanced error logging for better debugging of device reference problems
  • All registerRunListener handlers now validate args.device before access
Affected handlers: temperature_above/below, humidity_above/below, battery_below,
has_motion, is_open/closed, alarm_active, set_brightness, dim_by, brighten_by,
set_color_temperature, set_target_temperature, increase/decrease_temperature,
identify_device, reset_device, send_custom_command + more
Released now
Could you add gas sensor Device Request - Zigbee Combustible Gas Detector - _TZE204_chbyv06 / TS0601 · Issue #626 · JohanBendz/com.tuya.zigbee · GitHub
It detects as Climate sensor
okay i will do asap , done on the next version
  1. :white_check_mark: Fixed the gas sensor issue from forum #638 - moved _TZE204_chbyv06 from climate_sensor to gas_detector
  2. :white_check_mark: Confirmed IR Remote ZS06 from Issue #91 is already supported
  3. :white_check_mark: Added MOES Scene Switch 4 gang from Johan #1327
  4. :white_check_mark: Added Bseed Wall socket from Johan #1326
  5. :white_check_mark: Added E14 LED color bulb from Johan #1325
  6. :white_check_mark: Added WenzhiIoT mmWave Motion Sensor from Johan #1322
  7. :white_check_mark: Added Tuya PIR from Johan #1321
  8. :white_check_mark: Confirmed Smart Light sensor from Johan #1320 is already supported
Could you add this sensor to new version
it’s not working ?
Hello, my TS0041 is not recognized as a switch and is installed as a virtual device that cannot be controlled. Can this be fixed?
Give me more details please , like an interview and diag log please .
