[APP][Pro] Universal TUYA Zigbee Device App - test
Morning @dlnraja, more progress! :raising_hands:
I added my smart button again and it’s showing up properly now. Battery levels seem to be reporting correctly (ie not 100% or unknown) but still no activity through test flows. I get the following error when I use the GUI button for the device:
As for my motion sensors, I’m getting humidity, contact sensor and temperature labels for it when they’re not applicable but it’s not exactly harming anything. The sensors seem to be working regardless, with the exception of the battery readouts. They still say 100%.
Diagnostic code: 47225917-e6d6-4794-a145-7e2b226b7527
Version: 5.5.110
Thank you and keep up the great work!
okey i will add it on the next version.
Good morning Dylan,
The sensors below worked with an older version of your app. However, now they don’t work at all.
The Motion sensor no longer shows any values, and when I add the Radar sensor again, it changes it to a Climate sensor.
Can I download an older version of your app somewhere, or is there another solution?
:folded_hands:
I can send you the zip , with version does it works well ?
Or give the the interview and the diag log to fix it on the latest version
Hi Dylan Good morning :sunrise_over_mountains: the Multisensor is working well now :face_savoring_food:
But having difficulty’s to add SOS button now,
Installed app version 5.5.125, at first I tried to repair the device but it says can’t find device, then I deleted the device and tried to re-add it again but says device already added. Then I restarted the Homey and resetting the SOS button and after I tried it again but still no luck see screenshots.
Diagnostic code: bd5c1899-e3e8-4842-a394-d07988f8d83a
Thanks for all your effort again and good luck solving all the problems with the app, I admire your drive and skills.
Best regards Peter.
please regive me the interview and the manifacturername et productid of the sos device. best regard.
Hi Dylan, I posted the interview already here on 21st of October do you still want a new one, because I can’t add the SOS button at the moment so I can’t interview it now.
And I saw in your Screenshot from December 08 that you’ve got the same device, is that one working flawless in your setup.
Best regards Peter.
New version 5.5.127 I’m able to add SOS button again, but still no battery or triggering.
Okay I will check
Yes I have bought the same device.
Please send me a new interview
ZG-204ZM is spamming battery reports. Its changes between 2% and 100% everytime when the sensor sends data. For now I have to delete it as I get multiple notofications every minute.
diagnostic code 73632c1f-7bc1-4d3a-8d0d-6e85f8538531
Hi Dylan Genius :blush: you fixed it the SOS Buttons :sos_button: are finally working they are triggering the flow’s and there is a Battery indicator what’s working.
Thank you very very much for all your effort.
Have a nice day and good luck with your development.
Best regards Peter.
Hi Dylan, I noticed that one of my SOS buttons in this case SOS Peter was triggering the flow by itself.
In the Flow action menu IF there are 2 almost the same choices “SOS knop ingedrukt” the top one is with an exclamation mark what I used in SOS Peter and at Fariba I used the second one without the exclamation mark which doesn’t give a false trigger.
I changed mine now also to the second option and no false triggers anymore.
So i think you have to remove the top one with the exclamation mark from the menu.
I also don’t understand the options in the Menu “Het contactalarm gaat aan” and “Het contactalarm gaat uit” because that don’t make any sense.
Have a nice day and keep up the good work :+1: :wink:
Best regards Peter.
Hi Peter, v5.5.164 removes the duplicate SOS triggers. Now there’s only one clear trigger per action. The alarm_contact capability triggers are from Homey’s built-in system - you should use the custom “SOS button pressed” trigger instead.
Hi Dylan thanks, that will solve the problem and i noticed that the Multisensor Motion Luminance Temperature and Humidity gave also wrong movement and I checked the List in the flow that there are also a lot of doubles like Motion detection with and without exclamation mark and De bewegingsmelder is aan is also same as Motion Detection but than in Dutch to choose from, see screenshot
Good luck and have a nice weekend.
Regards Peter.
It might be fixed on the 167 version :slight_smile:
Hi Peter, v5.5.168 is out now!
I removed the duplicate motion triggers (motion_detected , motion_cleared ). The issue was that Homey automatically generates flow cards for the alarm_motion capability (“De bewegingsmelder is aan/uit”), and we had additional custom triggers doing the same thing.
Now you should only see the standard Homey motion triggers, plus the extra illuminance triggers specific to this app.
Please update and let me know if it’s cleaner now!
My smart button is a generic device and isn’t able to used in the latest version.
Diagnostic code: 17074581-cbc5-4170-883a-2d41db947c52
Version: 5.5.169
Fixed on the next version
Hi Dylan thanks for all the changes and it’s a lot clearer now, good job.
Best regards Peter.
