[APP][Pro] Universal TUYA Zigbee Device App - test
No, it hasn’t been added. It displayed as Unknown device
Please give me the manufacturer name of this device
You can find it on the device setting on homey app
"manufacturerName": "_TZE204_chbyv06x"
Here was the request Device Request - Zigbee Combustible Gas Detector - _TZE204_chbyv06 / TS0601 · Issue #626 · JohanBendz/com.tuya.zigbee · GitHub
Okay I will check it asap.
Good night
Hello, here’s the information. I tried the interview a few times but didn’t get any results.
Hersteller-ID _TZ3000_yj6k7vfo
Produkt-ID TS0041
fe596300-4461-4797-93f3-0fde22051b4b
Thank you in advance :blush:
Hello, is it possible to add these SEDEA temperature and humidity zigbee sensors ? Thanks a lot :slight_smile:
have you already tried the app to check if it’s already implemented ?
Thanks for adding
“:white_check_mark: Added MOES Scene Switch 4 gang from Johan #1327”
Unfortunately, the device is added now, but don’t work :
  • don’t show the action
  • In the flow, there is no choice for wich button is pressed or the number of press, only “one button is pressed”, “one button is long pressed”, and it don’t work :
In the supported devices list, there is another “4 button controler” that seems the same design and that offer all the functions. :
MOES :
The other one :
okay i will check asap cyril, could you please also provide me the interview of the moes 4 gang device ?
hi Dylan,
Unfortunately it is still showing “could not get device by id” error. eventhough its still not working i notice one chagne; It does now say default level 33% for dimlevel and 77% for tilt option in the dropdown menu for the cover controller. Eventhough its incorrect and doesnt work accordingly it is a change which I didnt saw before.
Link to post with detailed info
Uninstall the app
Connect and pair it again, the device without any app " generic zigbee " then do an interview with https://tools.developer.homey.app/tools/zigbee
And give the interview result here .
Cordialement
I have started a interview for a while, but it seems to be very long.
I have tried to retire and replace the battery and push all buttons with no success
Is there a solution to force the wake up of the device?
“ids”: {
“modelId”: “TS0041”,
“manufacturerName”: “_TZ3000_yj6k7vfo”
“endpoints”: {
“ieeeAddress”: “a4:c1:38:42:c3:33:6a:b4”,
“networkAddress”: 5817,
“manufacturerName”: “_TZ3000_yj6k7vfo”,
“endpointDescriptors”: [
“status”: “SUCCESS”,
“nwkAddrOfInterest”: 5817,
“_reserved”: 20,
“endpointId”: 1,
“applicationProfileId”: 260,
“applicationDeviceId”: 0,
“applicationDeviceVersion”: 0,
“_reserved1”: 1,
“inputClusters”: [
1,
6,
57344,
0
“outputClusters”: [
25,
10
“_reserved”: 14,
“endpointId”: 2,
“_reserved1”: 1,
“inputClusters”: [
6,
1,
6
“outputClusters”: []
“_reserved”: 14,
“endpointId”: 3,
“_reserved1”: 1,
“inputClusters”: [
6,
1,
6
“_reserved”: 14,
“endpointId”: 4,
“_reserved1”: 1,
“inputClusters”: [
6,
1,
6
“deviceType”: “enddevice”,
“receiveWhenIdle”: false,
“capabilities”: {
“alternatePANCoordinator”: false,
“deviceType”: false,
“powerSourceMains”: false,
“security”: false,
“allocateAddress”: true
“extendedEndpointDescriptors”: {
“1”: {
“clusters”: {
“powerConfiguration”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“reportingConfiguration”: {
“status”: “NOT_FOUND”,
“direction”: “reported”
“acl”: [
“readable”,
“reportable”
“id”: 32,
“name”: “batteryVoltage”,
“value”: 30,
“acl”: [
“readable”,
“reportable”
“id”: 33,
“name”: “batteryPercentageRemaining”,
“value”: 200,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“name”: “clusterRevision”,
“value”: 1,
“onOff”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “onOff”,
“value”: false,
“direction”: “reported”,
“attributeDataType”: 16,
“minInterval”: 60,
“maxInterval”: 600,
“status”: “SUCCESS”
“basic”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “zclVersion”,
“value”: 3
“acl”: [
“readable”,
“reportable”
“id”: 1,
“name”: “appVersion”,
“value”: 68
“acl”: [
“readable”,
“reportable”
“id”: 2,
“name”: “stackVersion”,
“value”: 0
“acl”: [
“readable”,
“reportable”
“id”: 3,
“name”: “hwVersion”,
“value”: 1
“acl”: [
“readable”,
“reportable”
“id”: 4,
“name”: “manufacturerName”,
“value”: “_TZ3000_yj6k7vfo”
“acl”: [
“readable”,
“reportable”
“id”: 5,
“name”: “modelId”,
“value”: “TS0041”
“acl”: [
“readable”,
“reportable”
“id”: 6,
“name”: “dateCode”,
“value”: “”
“acl”: [
“readable”,
“reportable”
“id”: 7,
“name”: “powerSource”,
“value”: “battery”
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65502
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2
“acl”: [
“readable”,
“reportable”
“id”: 65534,
“name”: “attributeReportingStatus”,
“value”: “PENDING”
“acl”: [
“readable”,
“reportable”
“id”: 65506
“acl”: [
“readable”,
“reportable”
“id”: 65507
“bindings”: {
“ota”: {},
“time”: {
“attributes”: [
“acl”: [
“readable”
“id”: 65533,
“2”: {
“clusters”: {
“onOff”: {},
“powerConfiguration”: {}
“bindings”: {}
“3”: {
“clusters”: {
“onOff”: {},
“bindings”: {}
“4”: {
“clusters”: {
“onOff”: {},
“bindings”: {}
Just waiting sometime an interview can last 1h .
I have this message
I will try after delete/re-add the item
Edit:
I have deleted device, de-activate the universal tuya app, added the button as generic Zigbee : Same message when interviewing
verry stange , pehraps an hidden button to press on the device ?
I have added it to a MOES gateway, and then deleted and re-add to Homey. It works ! :
“ids”: {
“modelId”: “TS0044”,
“manufacturerName”: “_TZ3000_zgyzgdua”
“endpoints”: {
“ieeeAddress”: “a4:c1:38:b7:1d:a0:94:53”,
“networkAddress”: 39252,
“manufacturerName”: “_TZ3000_zgyzgdua”,
“nwkAddrOfInterest”: 39252,
“_reserved”: 20,
“endpointId”: 1,
“_reserved1”: 1,
“inputClusters”: [
1,
6,
57344,
0
“outputClusters”: [
25,
10
“_reserved”: 14,
“endpointId”: 2,
“_reserved1”: 1,
“inputClusters”: [
6,
1,
6
“_reserved”: 14,
“endpointId”: 3,
“_reserved1”: 1,
“inputClusters”: [
6,
1,
6
“_reserved”: 14,
“endpointId”: 4,
“_reserved1”: 1,
“inputClusters”: [
6,
1,
6
“capabilities”: {
“security”: false,
“1”: {
“clusters”: {
“powerConfiguration”: {},
“onOff”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “onOff”,
“value”: false,
“basic”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“value”: 3
“acl”: [
“readable”,
“reportable”
“id”: 1,
“value”: 68
“acl”: [
“readable”,
“reportable”
“id”: 2,
“value”: 0
“acl”: [
“readable”,
“reportable”
“id”: 3,
“value”: 1
“acl”: [
“readable”,
“reportable”
“id”: 4,
“value”: “_TZ3000_zgyzgdua”
“acl”: [
“readable”,
“reportable”
“id”: 5,
“name”: “modelId”,
“value”: “TS0044”
“acl”: [
“readable”,
“reportable”
“id”: 6,
“name”: “dateCode”,
“value”: “”
“acl”: [
“readable”,
“reportable”
“id”: 7,
“value”: “battery”
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65502
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2
“acl”: [
“readable”,
“reportable”
“id”: 65534,
“value”: “PENDING”
“acl”: [
“readable”,
“reportable”
“id”: 65506
“acl”: [
“readable”,
“reportable”
“id”: 65507
“bindings”: {
“ota”: {},
“time”: {}
“2”: {
“clusters”: {
“onOff”: {},
“bindings”: {}
“3”: {
“clusters”: {
“onOff”: {},
“bindings”: {}
“4”: {
“clusters”: {
“onOff”: {},
“bindings”: {}
Thank you, the Sedea Zigbee sensor works perfectly.
You can have an official app now released a few days ago
https://homey.app/fr-fr/app/com.meross/Meross/
Cordialement.
It’s MOES, not MEROSS :grin:
MOES Smart Home Devic: Smart Switches, Thermostats & Security Sensor
