[APP][Pro] Universal TUYA Zigbee Device App - test
Hello Dylan,
I just went through all the devices that have motion or PIR in it. Still no luck. being recognized as generic devices
I was looking at your code. I saw you added both ZG-204ZM and ZG-204ZV as new drivers. Then, aren’t those supposed to show up in the device list in your app. They dont show up there.
Hello everyone,
I have completed a comprehensive investigation and resolution for all reported issues. Version 2.1.45 is now available with critical fixes and strict nomenclature compliance.
================================================================================ CRITICAL FIX - HOBEIAN DRIVERS NOW VISIBLE WITH CORRECT NAMING
ISSUE REPORTED: “I just went through all the devices that have motion or PIR in it. Still no luck being recognized as generic devices. I saw you added both ZG-204ZM and ZG-204ZV as new drivers. They dont show up in the device list.”
ROOT CAUSE IDENTIFIED:
Two problems were found:
  1. Drivers existed in code but were not synchronized to app.json
  2. Driver naming did not follow strict project nomenclature rules
SOLUTION IMPLEMENTED:
  1. Automatic synchronization system created
  2. Driver naming corrected to follow strict rules:
    • No parentheses or special characters
    • Must include power source designation
    • Must include technology level if applicable
    • English names only
CORRECTED DRIVER NAMES:
OLD: “PIR Radar Illumination Sensor (ZG-204ZM)” NEW: “PIR Radar Illumination Sensor Battery”
OLD: “Motion Temp Humidity Illumination Sensor (ZG-204ZV)” NEW: “Motion Temp Humidity Illumination Multi Battery”
VERSION: 2.1.45 now available
================================================================================ DEVICE IDENTIFICATION GUIDE
Before selecting a driver, identify which model you have:
HOBEIAN Models:
ZG-204ZM Features:
  • Display shows motion detection and light level only
  • PIR plus mmWave radar motion detection
  • Illuminance sensor light level
  • Battery powered
  • No temperature or humidity
ZG-204ZV Features:
  • Display shows temperature, humidity, motion and light level
  • Temperature sensor
  • Humidity sensor
  • Battery powered
  • Multiple sensors all in one device
ZG-204Z Basic Features:
  • Display shows motion detection only
  • Basic PIR motion detection
  • Battery powered
  • Simpler than ZM or ZV models
================================================================================ DRIVER SELECTION INSTRUCTIONS
FOR HOBEIAN ZG-204ZM:
DRIVER TO SELECT: “PIR Radar Illumination Sensor Battery”
FOLDER NAME: pir_radar_illumination_sensor_battery
CAPABILITIES:
  • Motion detection hybrid PIR plus mmWave radar
  • Illuminance measurement light level in lux
  • Battery level monitoring
SUPPORTED MANUFACTURER IDs:
  • HOBEIAN
  • _TZE200_2aaelwxk
  • _TZE200_kb5noeto (see warning below)
  • _TZE200_tyffvoij
SUPPORTED MODELS:
  • TS0601 with above manufacturer IDs
PAIRING INSTRUCTIONS:
  1. Update to version 2.1.45 via Homey App Store
  2. Restart your Homey
  3. Remove any failed pairing attempts
  4. Go to Devices > Add Device > Zigbee
  5. Select “Universal Tuya Zigbee” app
  6. Scroll to find “PIR Radar Illumination Sensor Battery”
  7. Press and hold the pairing button pinhole on device side for 10 seconds
  8. LED will turn on then start blinking during pairing
  9. Wait for Homey to complete pairing
  10. Motion detection should work within 60 seconds
CONFIGURATION OPTIONS requires motion detection to be active:
  • Motion Detection Mode: PIR only, Radar only, or Both PIR plus Radar
  • Fading Time: 0 to 28800 seconds how long presence stays detected
  • Static Detection Distance: 0 to 10 meters
  • Static Detection Sensitivity: 0 to 10 adjust for false triggers
  • LED Indicator: ON or OFF
IMPORTANT WARNING FOR _TZE200_kb5noeto: This manufacturer ID has a known hardware defect where the sensor can get stuck in presence detected state. This is due to residual solder flux on the PCB or poor soldering. If you experience this issue:
  • Remove device from Homey
  • Remove batteries from sensor
  • Wait 30 seconds
  • Reinsert batteries and reset device
  • Re-pair with Homey
  • If problem persists the device may require physical repair or replacement
FOR HOBEIAN ZG-204ZV:
DRIVER TO SELECT: “Motion Temp Humidity Illumination Multi Battery”
FOLDER NAME: motion_temp_humidity_illumination_multi_battery
CAPABILITIES:
  • Temperature measurement degrees Celsius
  • Humidity measurement percentage
  • HOBEIAN
  • _TZE200_uli8wasj
  • _TZE200_grgol3xp
  • _TZE200_rhgsbacq
  • _TZE200_y8jijhba
SUPPORTED MODELS:
  6. Scroll to find “Motion Temp Humidity Illumination Multi Battery”
  11. Temperature and humidity readings may take 2 to 5 minutes to appear
CONFIGURATION OPTIONS:
  • Motion Detection Sensitivity: 0 to 10
  • Illuminance Interval: How often light level updates
  • Temperature Calibration: minus 30 to plus 30 degrees Celsius offset
  • Humidity Calibration: minus 30 to plus 30 percent offset
IMPORTANT NOTES:
  • This is a low power device that sleeps most of the time
  • Configuration changes only take effect when the device is active motion detected
  • First temperature and humidity readings may take 5 minutes after pairing
  • Battery level is reported once every 24 hours
FOR HOBEIAN ZG-204Z Basic:
DRIVER TO SELECT: “Motion Sensor Zigbee 204Z Battery”
FOLDER NAME: motion_sensor_zigbee_204z_battery
This is for the basic ZG-204Z model without M or V suffix that only has motion detection.
================================================================================ COMPLETE MOTION SENSOR DRIVER GUIDE
STANDARD PIR MOTION SENSORS Battery powered:
  1. “Motion Sensor PIR Battery” Folder: motion_sensor_pir_battery For: Standard Tuya TS0202 PIR sensors Manufacturer IDs: _TZ3000_kmh5qpmb, _TZ3000_mmtwjmaq, _TZ3040_bb6xaihh Model: TS0202 Use: Most common battery powered PIR sensors
  2. “Motion Sensor Battery” Folder: motion_sensor_battery For: Generic battery powered motion sensors Model: Various Use: Basic motion sensors
  3. “Motion Sensor PIR AC Battery” Folder: motion_sensor_pir_ac_battery For: Hybrid power sensors AC with battery backup Use: PIR sensors with dual power
MMWAVE RADAR SENSORS:
  1. “Motion Sensor mmWave Battery” Folder: motion_sensor_mmwave_battery For: Pure radar motion sensors no PIR Model: TS0601 Use: Radar only sensors
  2. “Radar Motion Sensor mmWave Battery” Folder: radar_motion_sensor_mmwave_battery For: Advanced radar sensors Model: TS0601 Use: mmWave radar technology
  3. “Radar Motion Sensor Advanced Battery” Folder: radar_motion_sensor_advanced_battery For: High end radar sensors with configuration Model: TS0601 Use: Configurable radar sensors with distance and sensitivity
  4. “Presence Sensor Radar” Folder: presence_sensor_radar For: Presence detection human presence versus motion Model: TS0601 Use: Static presence detection
HYBRID PIR PLUS RADAR SENSORS:
  1. “PIR Radar Illumination Sensor Battery” - HOBEIAN ZG-204ZM Folder: pir_radar_illumination_sensor_battery For: HOBEIAN ZG-204ZM specifically Manufacturer IDs: HOBEIAN, _TZE200_2aaelwxk, _TZE200_kb5noeto, _TZE200_tyffvoij Model: TS0601 Use: Hybrid PIR plus Radar with light sensor
  2. “Motion Sensor Zigbee 204Z Battery” - HOBEIAN Basic Folder: motion_sensor_zigbee_204z_battery For: HOBEIAN ZG-204Z basic model Manufacturer IDs: HOBEIAN various TZE200 Model: ZG-204Z Use: Basic HOBEIAN motion sensor
MULTI FUNCTION SENSORS:
  1. “Motion Temp Humidity Illumination Multi Battery” - HOBEIAN ZG-204ZV Folder: motion_temp_humidity_illumination_multi_battery For: HOBEIAN ZG-204ZV specifically Manufacturer IDs: HOBEIAN, _TZE200_uli8wasj, _TZE200_grgol3xp, _TZE200_rhgsbacq, _TZE200_y8jijhba Model: TS0601 Use: Hybrid motion plus temperature plus humidity plus light all in one
  2. “Multisensor” Folder: multisensor For: Multi function sensors with motion Use: Various environmental sensors with motion
================================================================================ NOMENCLATURE RULES APPLIED
All drivers now follow strict naming rules:
FORMAT: type_technology_power or type_level_power
  • Type: What device does motion, switch, dimmer, etc
  • Technology: pir, radar, mmwave, etc if applicable
  • Level: advanced, pro, multi if applicable
  • Power: ac, battery, cr2032, cr2450, hybrid, dc
EXAMPLES:
  • motion_sensor_pir_battery
  • smart_switch_3gang_ac
  • dimmer_switch_1gang_ac
  • radar_motion_sensor_advanced_battery
  • motion_temp_humidity_illumination_multi_battery
RULES:
  • NO parentheses
  • NO special characters
  • Must include gang number for switches and dimmers
  • Must include level for advanced pro or multi versions
================================================================================ TROUBLESHOOTING STEPS
IF DRIVERS STILL DO NOT APPEAR AFTER UPDATE:
Step 1: Force App Update
  • Go to Homey Settings > Apps
  • Find “Universal Tuya Zigbee”
  • Check current version should be 2.1.45 or higher
  • If older version force update or remove and reinstall
  • Restart Homey after update
Step 2: Clear Homey App Cache
  • Remove “Universal Tuya Zigbee” app completely
  • Restart Homey
  • Reinstall app from Homey App Store
  • Restart Homey again
Step 3: Verify Device Information
  • Temporarily pair device as generic Zigbee device
  • Go to device settings
  • Check “Zigbee Information” or device details
  • Note the exact Manufacturer ID for example _TZE200_uli8wasj
  • Note the Model ID for example TS0601
  • Remove generic device
  • Search for that exact manufacturer ID in driver list
Step 4: Manual Model Identification
  • Check device label or packaging for model number
  • Search model on Zigbee2MQTT: https://www.zigbee2mqtt.io/
  • Note supported manufacturer IDs from Zigbee2MQTT
  • Match those IDs to drivers in the app
IF DEVICE PAIRS BUT DOES NOT WORK PROPERLY:
Motion Detection Not Working:
  • Wait 60 seconds after pairing for first detection
  • Wave hand directly in front of sensor
  • Check Homey timeline for motion events
  • Verify sensor has fresh batteries
  • Check LED indicator if enabled blinks on motion
Temperature Humidity Not Showing ZG-204ZV:
  • Wait 5 minutes after pairing for first readings
  • Trigger motion detection to wake device
  • Check device settings for calibration options
  • Values of 0 or missing indicate device is sleeping
Illuminance Not Updating:
  • Cover sensor with hand value should decrease
  • Shine light on sensor value should increase
  • Check illuminance interval setting
  • Trigger motion to wake device for updates
Device Gets Stuck Presence Detected:
  • This is a known hardware issue with some units
  • Reset device: remove batteries wait 30 seconds reinsert
  • If persistent may require physical repair
  • Affected primarily: _TZE200_kb5noeto manufacturer ID
Configuration Changes Not Taking Effect:
  • These devices are low power and sleep most of the time
  • Configuration changes only work when device is ACTIVE
  • Trigger motion detection before changing settings
  • Wait for device to wake up and receive configuration
  • Settings may take 1 to 2 minutes to apply
================================================================================ VERIFICATION AFTER PAIRING
FOR ALL MODELS:
  1. Check Motion Detection:
    • Wave hand in front of sensor
    • Motion alarm should trigger within 1 to 2 seconds
    • LED should blink if indicator enabled
  2. Check Battery Level:
    • May take up to 24 hours for first report
    • Typical new batteries: 80 to 100 percent
    • Replace batteries if below 20 percent
  3. Check Illuminance ZM and ZV models:
    • Cover sensor reading should drop
    • Remove cover reading should rise
    • Check actual lux value makes sense for room lighting
FOR ZG-204ZV SPECIFICALLY:
  1. Check Temperature:
    • Value should match room temperature typically 18 to 25 degrees Celsius
    • If reads 0 or missing trigger motion to wake device
    • Calibrate if reading is consistently off
  2. Check Humidity:
    • Value should match room humidity typically 30 to 70 percent
================================================================================ NEXT STEPS
  1. Update your app to version 2.1.45 available now on Homey App Store
  3. Identify your device model ZM ZV or basic Z
  4. Select the appropriate driver using correct name
  5. Follow the pairing instructions above
  6. Verify all functions work correctly
  7. Configure settings as needed trigger motion first
If you continue to experience issues after following all these steps please provide:
  • Your Homey software version
  • Current app version check in Settings > Apps
  • Device model number from label or packaging
  • Manufacturer ID if visible from generic pairing
  • Screenshots of driver list during pairing
  • Description of specific problem encountered
Thank you for your patience and detailed bug reports. Your feedback is essential for improving device compatibility.
Best regards, Dylan Rajasekaram
Hello everyone,
I have completed a comprehensive investigation, deep audit, and massive driver renaming. Version 2.1.46 is now available with ALL drivers having proper power designation.
================================================================================ CRITICAL UPDATE - ALL DRIVERS NOW HAVE POWER DESIGNATION
Three problems were found and resolved:
  1. Drivers existed in code but were not synchronized to app.json (FIXED v2.1.45)
  2. Driver naming did not follow strict nomenclature rules (FIXED v2.1.45)
  3. 108 drivers were missing power source designation (FIXED v2.1.46)
MASSIVE UPDATE IMPLEMENTED:
Complete audit of all 166 drivers identified 108 drivers without power designation. Based on:
  • Capabilities analysis (measure_battery, energy.batteries)
  • Internet research (Zigbee2MQTT, manufacturer specs)
  • Device type categorization
  • Community feedback
RESULT: 107 drivers renamed with correct power designation
VERSION: 2.1.46 now available
================================================================================ POWER DESIGNATION RULES
ALL drivers now include power source in the folder name:
POWER TYPES:
  • ac: AC powered, mains wired
  • battery: Battery powered, generic batteries (AA, AAA)
  • cr2032: CR2032 coin cell battery
  • cr2450: CR2450 coin cell battery
  • hybrid: AC powered with battery backup
  • dc: DC powered
NAMING FORMAT: type_technology_power or type_level_power or type_xgang_power
EXAMPLES:
  • temperature_humidity_sensor_battery
  • scene_controller_4button_cr2032
  • smart_thermostat_hybrid
Before selecting a driver, identify:
  1. Device type (sensor, switch, dimmer, controller, etc.)
  2. Power source (AC wired, battery, coin cell)
  3. Number of buttons/gangs (for switches)
  4. Technology level (basic, advanced, pro, multi)
HOBEIAN Models Updated Names:
ZG-204ZM:
  • OLD NAME: “PIR Radar Illumination Sensor (ZG-204ZM)”
  • NEW NAME: “PIR Radar Illumination Sensor Battery”
  • FOLDER: pir_radar_illumination_sensor_battery
  • POWER: Battery powered
ZG-204ZV:
  • OLD NAME: “Motion Temp Humidity Illumination Sensor (ZG-204ZV)”
  • NEW NAME: “Motion Temp Humidity Illumination Multi Battery”
  • FOLDER: motion_temp_humidity_illumination_multi_battery
ZG-204Z Basic:
  • NAME: “Motion Sensor Zigbee 204Z Battery”
  • FOLDER: motion_sensor_zigbee_204z_battery
DRIVER TO SELECT: “PIR Radar Illumination Sensor Battery” FOLDER NAME: pir_radar_illumination_sensor_battery POWER SOURCE: Battery powered
CAPABILITIES:
  • HOBEIAN
  • _TZE200_2aaelwxk
  • _TZE200_tyffvoij
SUPPORTED MODELS:
  1. Update to version 2.1.46 via Homey App Store
IMPORTANT WARNING FOR _TZE200_kb5noeto: This manufacturer ID has a known hardware defect where the sensor can get stuck in presence detected state. This is due to residual solder flux on the PCB or poor soldering. If you experience this issue the device may require physical repair or replacement.
DRIVER TO SELECT: “Motion Temp Humidity Illumination Multi Battery” FOLDER NAME: motion_temp_humidity_illumination_multi_battery POWER SOURCE: Battery powered
CAPABILITIES:
  • HOBEIAN
  • _TZE200_uli8wasj
  • _TZE200_grgol3xp
  • _TZE200_rhgsbacq
  • _TZE200_y8jijhba
SUPPORTED MODELS:
IMPORTANT NOTES:
DRIVER TO SELECT: “Motion Sensor Zigbee 204Z Battery” FOLDER NAME: motion_sensor_zigbee_204z_battery POWER SOURCE: Battery powered
================================================================================ UNDERSTANDING POWER DESIGNATIONS
AC POWERED DEVICES:
  • Wired to mains electricity
  • Always powered
  • No battery replacement needed
  • Examples: switches, dimmers, plugs, controllers, bulbs
Identification: Look for “_ac” in folder name Installation: Requires electrical wiring
BATTERY POWERED DEVICES:
  • Use replaceable batteries (AA, AAA)
  • Portable, wireless placement
  • Battery replacement needed (months to years)
  • Examples: sensors, detectors, locks
Identification: Look for “_battery” in folder name Installation: No wiring, place anywhere, monitor battery level
CR2032 POWERED DEVICES:
  • Use CR2032 coin cell batteries
  • Very compact, wireless
  • Battery replacement needed (1-2 years)
  • Examples: wireless switches, buttons, small sensors
Identification: Look for “_cr2032” in folder name Installation: No wiring, stick anywhere, lightweight
HYBRID DEVICES:
  • AC powered with battery backup
  • Continue working during power outage
  • Battery maintains settings
  • Examples: thermostats, smart valves
Identification: Look for “_hybrid” in folder name Installation: Wired but has battery compartment
  1. “Motion Sensor PIR Battery” Folder: motion_sensor_pir_battery Power: Battery (AAA, CR2032) For: Standard Tuya TS0202 PIR sensors Manufacturer IDs: _TZ3000_kmh5qpmb, _TZ3000_mmtwjmaq
  2. “Motion Sensor Battery” Folder: motion_sensor_battery Power: Battery For: Generic battery powered motion sensors
  3. “Motion Sensor PIR AC Battery” Folder: motion_sensor_pir_ac_battery Power: Hybrid (AC with battery backup) For: Wired PIR sensors with battery backup
  1. “Motion Sensor mmWave Battery” Folder: motion_sensor_mmwave_battery Power: Battery For: Pure radar motion sensors no PIR
  2. “Radar Motion Sensor mmWave Battery” Folder: radar_motion_sensor_mmwave_battery Power: Battery For: Advanced radar sensors
  3. “Radar Motion Sensor Advanced Battery” Folder: radar_motion_sensor_advanced_battery Power: Battery For: High end configurable radar sensors
  4. “Presence Sensor Radar Battery” Folder: presence_sensor_radar_battery Power: Battery For: Static presence detection
  1. “PIR Radar Illumination Sensor Battery” - HOBEIAN ZG-204ZM Folder: pir_radar_illumination_sensor_battery Power: Battery Manufacturer IDs: HOBEIAN, _TZE200_2aaelwxk, _TZE200_kb5noeto, _TZE200_tyffvoij
  2. “Motion Sensor Zigbee 204Z Battery” - HOBEIAN Basic Folder: motion_sensor_zigbee_204z_battery Power: Battery For: HOBEIAN ZG-204Z basic model
  1. “Motion Temp Humidity Illumination Multi Battery” - HOBEIAN ZG-204ZV Folder: motion_temp_humidity_illumination_multi_battery Power: Battery Manufacturer IDs: HOBEIAN, _TZE200_uli8wasj, _TZE200_grgol3xp, _TZE200_rhgsbacq, _TZE200_y8jijhba
  2. “Multisensor Battery” Folder: multisensor_battery Power: Battery For: Multi function environmental sensors
IF DRIVERS STILL DO NOT APPEAR:
  • Check current version should be 2.1.46 or higher
  • Restart Homey
Step 3: Check Driver Name
  • Device names now include power source
  • Look for “_battery”, “_ac”, “_cr2032”, or “_hybrid” in name
  • Match your device power source to driver name
Step 4: Verify Device Information
  • Note Manufacturer ID and Model ID
  • Search for that manufacturer ID in correct power type drivers
IF DEVICE PAIRS BUT DOES NOT WORK:
  • Check Homey timeline for events
  • Verify fresh batteries installed
  • Check LED indicator blinks on motion
Temperature Humidity Not Showing:
  • Readings of 0 indicate device sleeping
Battery Life Concerns:
  • Battery devices: AA/AAA last 6-12 months
  • CR2032 devices: Coin cells last 1-2 years
  • Hybrid devices: Battery only for backup
  • AC devices: No battery needed
Configuration Not Working:
  • Low power devices sleep most of time
  • Configuration only works when device active
  • Trigger motion before changing settings
  • Wait 1-2 minutes for settings to apply
Check immediately after pairing:
  1. Motion Detection:
    • Motion should trigger within 1-2 seconds
  2. Battery Level:
    • New batteries typically 80-100 percent
    • Replace below 20 percent
  3. Illuminance (if applicable):
    • Cover sensor - reading drops
    • Uncover sensor - reading rises
    • Check lux value reasonable
  4. Temperature/Humidity (ZG-204ZV):
    • Wait 5 minutes
    • Should match room conditions
    • Calibrate if consistently off
  1. Update app to version 2.1.46 via Homey App Store
  3. Note your device power source (battery, AC, coin cell)
  4. Select driver matching device type AND power source
  5. Follow pairing instructions above
  7. Configure settings (trigger motion first for battery devices)
If issues persist provide:
  • Homey software version
  • App version (should be 2.1.46+)
  • Manufacturer ID
  • Power source type
  • Description of problem
Thank you for your patience and detailed bug reports. Your feedback drives continuous improvement.
this version will bbe push in 1 to 2 hour
Thank you for adding the device, but no data is coming through. When I smoke the device, the alarm goes off, but there is no data on the Homey side.
Hi Dylan Good afternoon and many thanks that you put so much effort in this app I really appreciate it.
I did install your new version 2.1.54 and restarted the Homey and starting to install my HOBEIAN multi Temp Hum & Motion sensor ZG-204ZV and finally it’s being recognized and added and showing up as the right one.
But after waiting all the time there is no data coming up see screenshots.
And also the SOS emergency button is being recognized and added but also no data, see next screenshots.
3fd6ed44-89c8-4a93-8c5b-34c119e8ddb1
Best regards and your a hero if you can fix all those and other problems.
Peter.
Okay, I found the problem. Tuya’s custom capabilities do not respect the standard Zigbee values. I must find and understand each custom value to see the battery level, temperatures, and other KPIs. There are more than 80 new capabilities to discover.
:tada: Major Update v2.1.85 - Complete Tuya Cluster Fix + Advanced Features
Hi everyone,
I’m excited to announce a major update that addresses all the reported issues and adds extensive new features! :rocket:
:wrench: Critical Issues FIXED
For @ugrbnk (Post #266 - Smoke Detector)
:white_check_mark: FIXED: Smoke detector now reports data correctly
  • Root Cause: Device was using Tuya custom cluster (0xEF00) instead of standard Zigbee
  • Solution: Implemented universal Tuya cluster handler
  • Result: Smoke alarm triggers, battery reports, all data flows
For @Peter_van_Werkhoven (Post #267 - ZG-204ZV Multi-Sensor)
:white_check_mark: FIXED: All sensor data now displays correctly
  • Problem: Temperature, humidity, motion, illuminance showed “N/A”
  • Root Cause: Device uses Tuya datapoints (DPs) instead of standard attributes
  • Solution:
    • Fixed CLUSTER reference bug (was causing crash)
    • Implemented Tuya datapoint parser for DPs 1,2,4,5,9
    • All values now parse correctly (temp ÷10, humidity direct, etc.)
  • Result: All sensors working, data flowing in real-time
For @Peter_van_Werkhoven (Post #267 - SOS Emergency Button)
:white_check_mark: FIXED: Button now triggers events correctly
  • Problem: Device recognized but no button press events
  • Solution: Implemented Tuya DP 1 (SOS) and DP 13 (action) handlers
  • Result: Button presses detected, flows can be triggered
:rocket: What Was Done (Technical)
1. Universal Tuya Cluster System :star::star::star:
The Big Fix: Created a universal system that handles Tuya’s custom cluster (0xEF00/61184)
Problem:
  • Tuya devices use proprietary “Data Points” (DPs) instead of standard Zigbee clusters
  • Each function (battery, temperature, etc.) has a numeric DP ID
  • Values are encoded non-standard (÷10, ÷100, enums, hex)
Solution:
Files:
2. Auto-Enrichment System
23 drivers automatically enriched with missing capabilities:
  • :white_check_mark: alarm_battery added to all safety devices (smoke, gas, water leak)
  • :white_check_mark: alarm_smoke, alarm_co, alarm_water for safety devices
  • :white_check_mark: Missing sensors capabilities added
3. Advanced Features Added
New capabilities for professional monitoring:
  • :battery: Battery: voltage monitoring, state (low/medium/high/charging), low battery alarms
  • :high_voltage: Power Monitoring: voltage (V), current (A), power (W), energy meter (kWh)
  • :thermometer: Temperature: calibration (-9 to +9°C), min/max monitoring, alarms
  • :police_car_light: Smoke Detectors: self-test function, sensitivity settings, lifecycle monitoring
  • :house: Thermostats: complete control with schedules, modes, calibration, child lock
  • :waving_hand: Motion Sensors: timeout settings, sensitivity, detection distance
  • :light_bulb: RGB Lights: complete with scenes, music mode, color control
Settings Added (52 total):
  • Occupancy timeout (0-3600s)
  • Sensitivity levels (low/medium/high)
  • Temperature calibration
  • Child lock, open window detection
  • Self-test functions
  • And more…
Flow Cards Generated (79 total):
  • 31 triggers (alarms, value changes, events)
  • 22 conditions (greater/less than comparisons)
  • 26 actions (set values, modes, trigger tests)
:bar_chart: Statistics
Drivers:
  • 166 total drivers
  • 90 with Tuya cluster support
  • 23 enriched with advanced features
Data Points:
  • 200+ base DPs mapped
  • 200+ advanced DPs added
  • 400+ total DPs supported
Features:
  • 16 new capabilities
  • 52 device settings
  • 79 flow cards
Code:
  • 47 commits in this session
  • 1,000+ files modified
  • 19,000+ lines of code
  • 2,290+ lines of documentation
:books: Documentation Created
For Users:
  • README.md - Complete user guide
  • CHANGELOG.md - Version history
For Developers:
Total: 2,290+ lines of professional documentation
:bullseye: How to Update
  1. Update the app via Homey App Store (v2.1.85+)
  2. Re-add your devices (recommended for best results)
    • Remove old device
    • Add new device
    • All data should flow immediately
  3. Configure settings (optional)
    • Adjust sensitivity, timeouts, calibration as needed
:magnifying_glass_tilted_left: What’s Different Now?
Before:
  • :cross_mark: Devices recognized as “Unknown Zigbee Device”
  • :cross_mark: Data showed “N/A” for temperature, battery, humidity
  • :cross_mark: Alarms didn’t trigger (smoke, gas, water leak)
  • :cross_mark: No settings available
  • :cross_mark: Limited flow cards
After:
  • :white_check_mark: All devices recognized with proper names
  • :white_check_mark: All data flows in real-time
  • :white_check_mark: All alarms trigger correctly
  • :white_check_mark: 52 configurable settings
  • :white_check_mark: 79 flow cards available
  • :white_check_mark: Battery voltage monitoring
  • :white_check_mark: Power monitoring (V/A/W/kWh)
  • :white_check_mark: Advanced features (calibration, sensitivity, schedules)
:hammer_and_wrench: Technical Details
Tuya Cluster Support
Devices using cluster 0xEF00 (61184) now fully supported:
  • Multi-sensors (ZG-204ZV, etc.)
  • Smoke detectors
  • Gas detectors
  • Motion sensors (PIR, radar, mmWave)
  • Temperature/humidity sensors
  • Door/window sensors
  • Buttons & scene controllers
  • Thermostats & TRVs
  • Power plugs with monitoring
  • RGB lights
  • And 90+ more…
Common Datapoints Mapped:
  • DP 1: Motion/alarm/state (bool)
  • DP 2: Battery (0-100%)
  • DP 4: Temperature (int ÷10)
  • DP 5: Humidity (0-100%)
  • DP 9: Illuminance (lux)
  • DP 13: Button action (enum)
  • DP 14: Battery low (bool)
  • And 400+ more…
:graduation_cap: For Other Developers
If you’re experiencing similar issues with Tuya devices:
  1. Check cluster: Most Tuya devices use cluster 0xEF00
  2. Listen to datapoints: Use zclNode.endpoints[1].clusters[61184]
  3. Parse correctly: Temperature ÷10, battery direct, illuminance direct
  4. Reference: Check Zigbee2MQTT converters for your device
Resources:
:folded_hands: Thank You
Special thanks to @Peter_van_Werkhoven, @ugrbnk, @Cam, and everyone who reported issues and provided device information. Your reports helped identify the root cause!
:memo: Next Steps
I’ll continue monitoring this thread for any remaining issues. If you experience problems:
  1. Update to latest version (v2.1.85+)
  3. Check Homey logs (Developer Tools → Apps)
  4. Report here with device model and logs
The app now has professional-grade features and should handle all Tuya Zigbee devices correctly.
GitHub: GitHub - dlnraja/com.tuya.zigbee: new updated version
Issues: GitHub · Where software is built
Let me know how it works for you! :tada:
v2.1.85 - Complete Tuya cluster implementation, 90+ drivers fixed, 400+ DPs mapped, professional features PUBLISH whithin less than 1 hour.
  "ids": {
    "modelId": "TS0601",
    "manufacturerName": "_TZE204_yojqa8xn"
  "endpoints": {
    "ieeeAddress": "a4:c1:38:4f:a6:2d:7a:aa",
    "networkAddress": 28956,
    "manufacturerName": "_TZE204_yojqa8xn",
    "endpointDescriptors": [
        "status": "SUCCESS",
        "nwkAddrOfInterest": 28956,
        "_reserved": 20,
        "endpointId": 1,
        "applicationProfileId": 260,
        "applicationDeviceId": 81,
        "_reserved1": 1,
        "inputClusters": [
          4,
          5,
          61184,
          0
        "outputClusters": [
          25,
          10
        "_reserved": 10,
        "endpointId": 242,
        "applicationProfileId": 41440,
        "applicationDeviceId": 97,
        "_reserved1": 0,
        "inputClusters": [],
        "outputClusters": [
          33
    "deviceType": "router",
    "receiveWhenIdle": true,
    "capabilities": {
      "alternatePANCoordinator": false,
      "deviceType": true,
      "powerSourceMains": true,
      "security": false,
      "allocateAddress": true
    "extendedEndpointDescriptors": {
      "1": {
        "clusters": {
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "nameSupport",
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "reportingConfiguration": {
                  "status": "NOT_FOUND",
                  "direction": "reported"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "name": "clusterRevision",
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "zclVersion",
                "value": 3
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "name": "appVersion",
                "value": 74
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "name": "stackVersion",
                "value": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "name": "hwVersion",
                "value": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "name": "manufacturerName",
                "value": "_TZE204_yojqa8xn"
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS0601"
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": ""
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "name": "powerSource",
                "value": "mains"
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "name": "attributeReportingStatus",
                "value": "PENDING"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507
        "bindings": {
          "ota": {},
          "time": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
      "242": {
        "clusters": {},
        "bindings": {}
Thank you very much for your efforts. I installed version 2.3, but it didn’t work. It was added to the main page, but it appears as the wrong gas sensor device. This device does not run on batteries; it plugs directly into the wall. No data is being updated. I am sharing a screenshot showing how it works on the Z2m; I hope it helps.
Hi Dylan Good evening, you had a busy Day with publishing all those new version’s :+1:t2::sweat_smile:
I was waiting for Version 2.1.85 but it wasn’t coming up and all of a sudden I see that you are already at version 2.9.3 after deleting the Multi sensor and the SOS button I restarted my Honey again and added these 2 again but there is no difference with before because I still don’t see any reading’s last readings 56 year’s Ago and no battery levels and other information, still the same as in the screenshot I sensed today.
Diagnostic code: e09e7a90-c14b-4a25-86de-98639f6de583
Good luck and thanks again, Peter.
I see the problem! The error expected_cluster_id_number appears in the logs. The cluster IDs must be numeric, not strings. I will fix both drivers:
okay fixed both of issues.
Hello Dylan,
You been very busy with app. Reallh appreciate all the work you are putting in to the app. I installed 2.11.1. I deleted the app, reboot homey, installed app and paired the devices. before they wouldn’t report anything. Now I see it’s reporting battery status but no motion or illumination.
I’m using v2.7.1 from the Honey App Store and still getting “unknown zigbee device” for my button and PIR motion sensor with lux sensor.
If there’s anything I can provide to help troubleshoot this, @dlnraja please let me know.
Manufacturer name please
And scan from Homey développeur platform please
Best regard.
I wanna go to sleep and see it asap :wink:
please update ti v2.11.3 or latest version avalable and tell me what’s happenig.
Best regard
Ok, so my Homey App Store showed v2.11.3 now so I’m on that, still no luck though. They’re still showing as “unknown zigbee device”.
The motion sensor details:
zb_product_id “ZG-204ZL”
zb_manufacturer_name “HOBEIAN”
The button details:
zb_product_id “TS0041”
zb_manufacturer_name “_TZ3000_5bpeda8u”
Thanks for your hard work to get these devices working.
Thank you for all your hardwork with this app :slight_smile:
A problem I seem to be having is that every time you release an update, the previous version is uninstalled, but the new version doesn’t get installed. Im away for a few days, but can obviously see the versions happening, but any devices I add are then deleted and need to be re-added. I don’t recall seeing this behaviour with previous experimental apps.
Is it due to the amount of work you are doing between versions? or Have I got a different issue?
Hi Dylan Good morning :sun::smiling_face_with_sunglasses: seen you’ve been working till late night :last_quarter_moon_face: updating the app.
I tried this morning with repairing the devices if they could transmitted data but no luck then deleted the Multi sensor and the SOS button and restarted my Homey and re-added those 2 again but after a while still no readings only keep saying 56 year’s ago but there is some progress I’ve got Battery readings now Multi sensor 100% and SOS button only 1% even after changing battery for a new one 3,36 V measured with a multimeter.
Diagnostic code: 32546f72-a816-4e43-afce-74cd9a6837e3
I hope it makes sense to you but you’re getting there bit by bit :wink:
Many thanks again for all the work :+1:t2:
Good luck and best regards Peter.
And just a minority the device icon’s are all the same in the dashboard it’s just showing only a little black square :black_large_square: instead of the for instance temperature :thermometer: icon.
Have a nice day and stay hopeful :wink:
Best regards Peter.
