[APP][Pro] Tuya Zigbee App
A while ago, I have added a Tuya Zigbee switch (switch_2_gang_metering) and everything was working fine, so I built it back in in the wall behind the outlet.
Now it shows like this:
Result of interviewing:
Question: is there a way to repair it without having to push the button (and therefore open the wall socket again)? It’s not that important, just a nice to have and I prefer not having to do this every so often :slight_smile:
There sometimes are multiple ways of activating the trigger to re-link. some devices trigger when pressing the device on-off for 5/7or 10 times. give it a try
Most probably what Partick said.
This is part of the manual for a similar device which says 5 times:
Thanks!
In order to do that, I’ll have to switch the breaker 5 times. That will trigger inclusion mode for a lot of other devices on that group :slight_smile: I only have this device here for power metering, so I will open the wall outlet at some point and hope it continues to report a little bit longer this time
no, you can just toggle the on off rocker/switch 5 times, if you have that connected to the unit to turn the lights on/off
There is no rocker/switch connected to this built in module :slight_smile:
That explains :sweat_smile:
Hi!
Can you please add support for the following Tuya Zigbee LED driver?
Homey adds it as an unknown Zigbee device, and dimming is not available.
Manufacturer: _TZB210_ngnt8kni
Product ID: TS0501B
Device type: Router
Device class: LED driver (constant voltage 24V)
This is a 24V WoodUpp/Tuya LED controller using standard Tuya clusters.
Here is the fingerprint from Homey:
  • Manufacturer ID: _TZB210_ngnt8kni
  • Product ID: TS0501B
  • Device ID: Router
  • Firmware: Unknown
  • Supports: level control (0x0008) and on/off (0x0006)
Please add this model to the Tuya Zigbee app as a dimmable LED controller.
Thanks!
Please read the start post for instructions how to ask for adding a device to the app.
However, the development of this app seems to have come to a long term halt.
I advice you to use this app:
Also there: read the start post.
Hi!
Can you please add support for the following Tuya Zigbee SOIL driver?
Homey adds it as an unknown Zigbee device, detect nothing.
Manufacturer: _TZE200_npj9bug3
Product ID: TS0601
Device type: Router
Device class: Soid Measure 2xAAA
https://es.aliexpress.com/item/1005008987466283.html?gatewayAdapt=glo2esp
Artículo: Sensor de humedad del suelo Zigbee
Protocolo inalámbrico: Zigbee 3.0(Necesita puerta de enlace zigbee)
Rango de humedad del suelo: 0% ~ 100%
Resolución de temperatura: 0,1℃
Resolución de humedad: 1%
Precisión de medición de temperatura: ±0,5℃
Precisión de la medición de humedad: ±5%
Voltaje de funcionamiento: DC3V
Corriente de espera:≤20uA
Tipo de batería:2 LR03 AAA(no incluido)
Aplicación: vida inteligente/Tuya
thanks
@darckrie did you read the first post? There you can find how to ask support for a new device.
Maybe there is some information in the post above yours.
I wanted to add a Zigbee door sensor from manufacturer: _TZ3000_n2egfsli
This ID is present in the first post as supported in the test version of the app. However, after installing the test version, I can’t add this device, as it’s being continuously picked up as an “Unknown Zigbee Device” and not a door sensor.
Any ideas what might be causing this?
wrong thread .
I Know :grimacing:
But i am not allowed in the right tread anymore :smiling_face_with_tear:
Hi Ronny you get around this by editing your own post from before.
Best regards Peter.
Could you please add this device?
Device: Temperature Sensor
Manufacturer Name: _TZ3000_xr3htd96
Product ID: TS0201
I have bought this and realize now, that this device entry is missing in your APP.
Many thanks in advance
Mirko
Development of this app seems to have come to a long term halt (see here).
I recommend to check this app:
Or post in [APP][Pro] Universal TUYA Zigbee Device App - test .
Hi there, before to ask dev to add this product, is it somehow already compatible ? On another app maybe ? Thanks. It’s an energy meter with 2 channels.
Open door: did you read the first post of this topic? :innocent:
Was already requested https://github.com/JohanBendz/com.tuya.zigbee/issues/1081, and Dylan is already trying to add it to the universal Tuya zigbee app.
