[APP][Pro] Tuya Zigbee App
Title: Please add multi-gang support for Hejhome Pika TS0601 (_TZE284_c8ipbljq) – 3‑gang and 6‑gang
Details:
  • Homey model: Homey Pro
  • App: HejHome/Tuya Zigbee
  • Device brand/models:
    • Hejhome Pika 3‑gang (GKZSW391L2DB03)
    • Hejhome Pika 6‑gang (GKZSW391L2DB06)
  • Zigbee fingerprint:
    • Manufacturer: _TZE284_c8ipbljq
    • Product ID: TS0601
  • Behavior:
    • Pairs as device type “Router”.
    • Only one switch tile is created.
    • On/off control doesn’t work under generic Zigbee, and also not when pairing via Tuya Zigbee multi‑gang tile.
    • Advanced settings do not show endpoint/cluster list.
  • Expected:
    • Each gang should be exposed as a separate switch (3 tiles for GKZSW391L2DB03, 6 tiles for GKZSW391L2DB06).
  • Request:
    • Please add this fingerprint to the appropriate multi‑gang TS0601 driver and map all endpoints so each gang is controllable in Homey.
  • Notes:
    • Device pairs within 2–3 m of Homey Pro.
    • Factory reset performed before inclusion.
Ive posted in [APP][Pro] Universal TUYA Zigbee Device App - test as well
Could you please add this device?
Device: Pressure band
Manufacturer Name: _TZ3000_pjb1ua0m
Product ID: TS0203.
Thanks.
You really should read the first post of this topic…
Hi there,
I am new here and appricatie all the work that has been doen so I hope this is simple to answer, trying to add an energiemetered power plug which identifies as (_TZ3000_ww6drja5). According to the Universal Tuya Zigbee Device Finder this should be supported in Homey but it keeps identifying as an universal zigbee device.I am on universal Tuya Zigbee V5.5684 Experimental.
ID feeca713-ddaa-441e-a52f-9b6cddc3a954
Name Zigbee-apparaat
Driver homey:virtualdriverzigbee:driver
token “5a35a8d9-569a-4af3-a259-a199eb4d7241”
zb_product_id “TS011F”
zb_manufacturer_name “_TZ3000_ww6drja5”
zb_receive_when_idle “✓”
zb_device_type “router”
zb_ieee_address “a4:c1:38:ad:2e:0a:8d:1e”
zb_sw_build_id “1.0.5”
Long live the search function…
I have had several Curtain Modules working with this app for months, however, if I try to add new ones now, they are not recognized anymore and are added as generic zigbee devices.
Everything that I’ve added before still works and is recognized. The strangs thing is, all my modules are of the same type TZ3000_e3vhyirx; the ones that are already connected and working but also 3 new ones that refuse to connect and appear as generic devices.
Any idea why this is happening and how this can be solved?
I’ve tried other apps mentioned in this thread but so far no luck.
I have another Zigbee hub laying around for test purposes (Lidl Silvercrest hub) amd through that one, I am able to connect the 3 modules and they work as intended
Tuya is being notorious for deviating from zigbee standards as they please;
most probably there’s something different between the existing and the new devices , despite having the same type tag.
To find out what’s different: interview both a functional and a non-supported model. You can do that here: tools.developer.homey.app/tools/zigbee
For each result, save it to a text file (f.e. with notepad)
Next, load both text files in a diff tool, this will mark all differences between both interview results.
Exactly! I had the same thing: I was confident that the devices I bought were already in the list of supported devices. However, it turned out that one of the sub IDs wasn’t. I needed to add them and after that I was able to add the devices.
You can also think of using the Universal Tuya Zigbee app: Universal Tuya Zigbee | Homey
Device Request: Tuya Smart Knob (4 Gang Scene + Dimmer)
Hello @johan_bendz,
Could you please add support for this new Zigbee Smart Knob (Model 2025)?
It has a rotary dimmer and 4 scene buttons in the corners.
Currently, it pairs as a Generic Zigbee Device.
Device Details:
  • Manufacturer ID: _TZE284_tgeqdjgk
  • Device Type: Smart Knob / 4-Gang Scene Switch with Rotary Dimmer
Thank you very much for your hard work!
Also, there are other options which are maintained.
Sorry
This has nothing to do with the Tuya ZigBee app. Please ask in the Govee app topic.
I have a single room ventilator (Arida Venti 160 WiFi) connected to the SmartLife app, and noticed now that I can connect to this via this app in Homey. I can connect is as a fan in Homey, but then with quite limited functions. Only on/off and setting fan speed (1 - 3).
This ventilator works as a heat recovery unit that blows air in for an amount of time, and then turns direction on the fan so it works as an exhaust. Then there is an heating element in the fan that stores some of the temperature from the indoor air. And when the direction turns again the outdoor air that blows in gets heated up from the heating element. You can also set the direction to only blow in, or only out. Also it has a CO2 sensor, and some more functions.
Is it possible to add support for this device so you can set the functions directly from Homey? Link to product under (norwegian site).
That device uses WiFi, you need the other Tuya app
I’m using that app, but see now that I have posted in the wrong thread. Sorry about that.
Seems like the test version of this app still gets updated…
The main version did not get any update in 5 years.
So I’m not sure what app to contribute to now…
Hi all, been a while… :wink:
A new Test version is out, and I’ve asked for it to be published as Live.
I’m also in discussions with Athom about the future development of this app. I’ll keep you posted.
It’s good to have you back, Johan. I hope you’ll also have time for an update to the Hue app soon.
Is it possible to be more specific in the descripton of the devices? A few icons and texts seem to be identical. Guess there are differences. Do they matter on inclusion?
Good to have you back! In the meantime I have created my own version of the app. Only difference being adding some previously unsupported devices.
However, a while ago I was struggling with Tuya Zigbee devices sending way too many messages. I still don’t know what went wrong there but it completely clogged up my Zigbee network and everything Zigbee was terribly slow!
Things seem to be ok now as everything runs smooth. But I am not sure if Tuya Zigbee devices are still sending way more messages than other Zigbee devices. Would that be something you can look into too? It is kinda hard as currently it doesn’t seem to be an issue, so I cannot really deliver test data
