Hello Peter, thanks for the quick replay.
But how do i get this sensor to work true on the Tuya app in Homey so that it indicates the temp and humanity?
Product id TS0201
Fabrikant ID _TZ3000_dowj6gyi
Product id TS0201
@johan_bendz when are you releasing a new test version? Wanted to test the device that you have added a few weeks ago.
I was also hoping if you could look into my older request for the garage door opener with wireless sensor? Thanks in advance
THX Peter, That was the problem ![]()
Working great now
Can order more temp. device now
Hi, I can’t add radar sensor model nr ZY-M100-24G. Do you know when it will be added to the app? ![]()
Hi Stian,
You should read the first post here at the top.
Best regards Peter.
Why does the app say v0.1.45 and that it haven’t been updated in 4 years, but the changelog shows a lot of versions since? I did not realise I had to install the experimental version to get updates.
As long as a test version has not been promoted to a stable version, you indeed need to install the test version to get test version updates.
Typically test versions get promoted to a stable version after a relatively short period and you would get updates to your current stable version more frequently.
In this specific case updates have only been made to the test versions (quite often the last months). If I understand correctly, the developer is working towards a stable 1.0 version with many Zigbee devices supported.
Are there more people who are unable to connect a new smart plug since a few days? Not sure if its since homey update 12.2.0, but it feels like it.
It started with being unable to control a smart plug, so i deleted it from homey and tried to reconnect it, with no succes. Today 3 new plugs arrived, with the same result. I cant connect them at all.
Sometimes it just remains on the screen with “hold the button for 5 seconds etc etc”, sometimes I get 1 step further with the message “device is being added etc etc” but it stays there and after a while it tells me it failed because it took to long.
Using the Blitzwolf plugs, SHP13 was connected but stopped working and wont connect anymore, SHP15 just arrived and doesnt connect either.
Btw, the other plugs in the house that i did not remove started working again after i installed a backup on homey. I just cant add new ones anymore.
If they hardcoded it to a specific gateway, should it have the Zigbee-logo?
If it’s just a repeater it should work with the generic Zigbee integration, no specific app required.
Ok, stupid question. How do I install the experimental version?
See first post of the thread (it’s called “test version”).
I tried the test version for adding a new tuya zwave radar I just got in the mail and it doesnt seem to work. It is added as a generic zigbee devices. I have other, older, versions that do work great.
Is it possible to add those new ones as well:
Fabrikant ID: _TZE204_ya4ft0w4
Product ID: TS0601
Edit; request in the making
Hope its possible!
Cheers! ![]()
Read the first post of the thread.
In the homey flow (if i select the AND) i only see “De batterijwaarschuwing is aan”
Why is that?
Product id TS0201
Anny ideas?
Perhaps it’s easier to explain what you expected, but my guess is that you have to look at how Logic cards work.
I sold my Homey for several reasons like poor support for Zigbee devices and poor integration of MQTT and ESPhome. Still I would like to thank @johan_bendz for his great work on this app. Homey should hire you and/or pay you since you are filling a big hole in their eco system, despite their cloud app. Also I would like to thank @robertklep for his support and active role on the forum, I learned a lot from your content. I will miss Homey for sure but I had no other choice.
