[APP][Pro] Tuya Zigbee App
Does the new polling frequency for Power Plugs work for anyone?
I tried to set it to 15s, but it still takes about 60s to update.
[Update] Working with 0.2.5, great update for plugs!
Ooops… a typo in the code resulted in smart plugs not working in 0.2.4… fixed in 0.2.5
I confirm it’s working, thank you
Now it works again, thank you!
However, it seems like power isn’t updating. Amps, Voltage and Energy do, but not power. Always 0.
Hi folks, will you help me to bring this device to live ?
Tuya Smart Zigbee Smoke Detector Smart Fire Fire Protection Home Security Alarm Work With Tuya Zigbee Hub
https://a.aliexpress.com/_mPatwpQ
When I tried to connect, homey identified this device like unknown
@johan_bendz
The smart plugs work fine again.
Thank you for the quick fix.
Send a crash report from the app, please. :slight_smile:
be3498fd-4bc3-44df-adf1-2626b630865f
Looks like the device is not responding after a while. What reporting interval settings do you use?
Default 60s.
Please read instructions, for how to request support for a device, in post #1, Petr
That mention device “ZigBee Tuya smoker detector” is launched by homey, unfortunately like unknown ZigBee device
Looks like that the smoker could not be identified by this application. If it’s possible to add this device on the list, I’d more then happy. Thank you.
no not working, i have the same problem
I have the same model (8x TZ3000_dowj6gyi).
I’m seeing them using the test version but not getting any data from them.
Once they are paired with Homey they seem to turn off and not supply any data.
Tried a fresh battery yesterday instead of the Aliexpress supplied ones without joy.
@johan_bendz did you have any chance to look into this when you updated the app?
it still states “NOT_FOUND” even after the new update 0.2.5
regarding TS0201 _TZ3000_fllyghyj
The power plug WITH power metering type “TZ3000_ynmowqk2” is not recognized.
Sold by Lidl under the "Silvercrest’ brand.
Can you please add it to the list?
  "ids": {
    "modelId": "TS011F",
    "manufacturerName": "_TZ3000_ynmowqk2"
  "endpoints": {
    "endpointDescriptors": [
        "endpointId": 1,
        "applicationProfileId": 260,
        "applicationDeviceId": 266,
        "_reserved1": 1,
        "inputClusters": [
          3,
          4,
          5,
          6,
          1794,
          2820,
          57345,
          57344,
          0
        "outputClusters": [
          25,
          10
        "endpointId": 242,
        "applicationProfileId": 41440,
        "applicationDeviceId": 97,
        "_reserved1": 0,
        "inputClusters": [],
        "outputClusters": [
          33
    "endpoints": {
      "1": {
        "clusters": {
          "identify": {
            "attributes": []
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "nameSupport",
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "reportingConfiguration": {
                  "status": "NOT_FOUND",
                  "direction": "reported"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "name": "clusterRevision",
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": false,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16385,
                "name": "onTime",
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16386,
                "name": "offWaitTime",
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32769,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32770,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 20480,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32768,
          "metering": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "currentSummationDelivered",
                "value": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 512,
                "acl": [
                  "readable",
                  "reportable"
                "id": 768,
                "acl": [
                  "readable",
                  "reportable"
                "id": 771,
                "acl": [
                  "readable",
                  "reportable"
                "id": 774,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
          "electricalMeasurement": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 1285,
                "name": "rmsVoltage",
                "value": 219,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1288,
                "name": "rmsCurrent",
                "value": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1291,
                "name": "activePower",
                "value": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "zclVersion",
                "value": 3
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "name": "appVersion",
                "value": 68
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "name": "stackVersion",
                "value": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "name": "hwVersion",
                "value": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "name": "manufacturerName",
                "value": "_TZ3000_ynmowqk2"
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS011F"
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": ""
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "name": "powerSource",
                "value": "mains"
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "name": "attributeReportingStatus",
                "value": "PENDING"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507
        "bindings": {
          "ota": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0
                "acl": [
                  "readable"
                "id": 1
                "acl": [
                  "readable"
                "id": 2
                "acl": [
                  "readable"
                "id": 3
                "acl": [
                  "readable"
                "id": 4
                "acl": [
                  "readable"
                "id": 5
                "acl": [
                  "readable"
                "id": 6
                "acl": [
                  "readable"
                "id": 7
                "acl": [
                  "readable"
                "id": 8
                "acl": [
                  "readable"
                "id": 9
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
          "time": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
      "242": {
        "clusters": {},
        "bindings": {}
Is this switch Module still not integrated?
 "ids": {
    "modelId": "TS0011",
    "manufacturerName": "_TZ3000_qmi1cfuq"
  "endpoints": {
        "endpointId": 1,
        "applicationDeviceId": 256,
        "_reserved1": 1,
        "inputClusters": [
          3,
          4,
          5,
          6,
          57344,
          57345,
          0
        "outputClusters": [
          25,
          10
    "endpoints": {
      "1": {
        "clusters": {
          "identify": {
            "attributes": []
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": false,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16385,
                "name": "onTime",
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16386,
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32769,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32770,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 20480,
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 3
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "value": 64
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "value": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "value": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "value": "_TZ3000_qmi1cfuq"
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS0011"
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": ""
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "value": "battery"
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "value": "PENDING"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507
        "bindings": {
          "ota": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0
                "acl": [
                  "readable"
                "id": 1
                "acl": [
                  "readable"
                "id": 2
                "acl": [
                  "readable"
                "id": 3
                "acl": [
                  "readable"
                "id": 4
                "acl": [
                  "readable"
                "id": 5
                "acl": [
                  "readable"
                "id": 6
                "acl": [
                  "readable"
                "id": 7
                "acl": [
                  "readable"
                "id": 8
                "acl": [
                  "readable"
                "id": 9
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
          "time": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
OK, didn’t work just 1hour ago, but works now
:thinking::flushed:
Screenshot_20221202-190317__01
Happy!
:nerd_face:
