Hello everyone,since a few days(maybe the last Homey update?),all my Tuya devices(plugs and sensors) doesn’t update their status in Homey,example:if i open a window the sensor alarm is still off…If a flow stop a the plug every night at 3a.m ,the plug is still on in Homey.
No problem to control the plug inHomey manually the on/off button works…and after a restart of the app the status is updated!
I remove a sensor and try to reconnect in Homey but the app can’t find it…
I precise in the Smartlife app everything is working well,sensor appear and every devices status are update and in Iot platform all my devices appears online…
If someone can help?Thanks
Tuya version:Experimental 1.1.12
Would like to know this as well as I would very much like to have the energy readings from my tuya socket into homey.
Sorry for late reaction, I was ill and it’s going a little better now.
I don’t have any influence on the data pushed to the app by Tuya, if the power is absense, I can’t do anything about it. Also the update rate of values are not something I can do anything about, it’s get pushed by Tuya. Only if it’s an error in my app when receiving gives an error I can fix it. Till now I did not see an error here. As soon as the app received a message, it gets processed as raw flow. If the value is used in adevice, that value gets updated in Homey.
The link is to the documentation to instruction and status set and below the link is the code currently used to get power, so no kwh, but only power values.
Standard Status Set-Tuya IoT Development Platform-Tuya Developer
if (statusMap.code === 'cur_power') {
this.setCapabilityValue("measure_power", statusMap.value/10).catch(this.error);
@Tirrazo, this app is open source and you can contribute to it and/or check the code for erros if you believe this is the case. I have not seen an error yet in the app with passing power.
jurgenheine/com.tuya.cloud: Connect homey to the Tuya cloud (github.com)
@HvN and @Peter_Kawa, both big thanks for helping to find a solution to this issue
@Peter_Kawa , I saw your example of logging events . For logging it should be enough to log text event received only. The boolean and nummeric values should be passed as text also. they are also passed as boolean or nummeric so they can be used directly without type conversion in flows.
Hello all,
I just tried to add my sockets to Homey, but they only get added as a light (the socket has a led ring).
I want to have them added as a socket too. I tried to add them as sockets but then there are no decided found.
Can someone give me a pointer?
Thanks,
Frank
If your socket is representing itself as a light instead of a socket, you can add it as a light and not as a socket. Tuya should give it it’s own device type, they already have plenty of them. To use it, you can go the raw flows way as described in opening post and see also
Hi Jurgen,
I managed to get the details you refer to. So I can use flows to switch the device on and off
(something I also could do with scenes created in the Tuya app). But the main reason I ask is that I am missing the energy monitoring functionality. I even see them coming in the the above ‘Text event received’.
I think it is not possible, but can I change something in the Tuya IoT platform so I will announce itself as a socket?
This are the details I receive when calling the Get Device Specification
api call in Tuya IoT platform.
(And just “No” is an acceptable answer ;))
"result": {
"category": "dj",
"functions": [
"code": "switch_led",
"lang_config": {
"false": "OFF",
"true": "ON"
"name": "Led Name",
"type": "Boolean",
"values": "{}"
"code": "bright_value",
"lang_config": {
"unit": ""
"name": "Bright",
"type": "Integer",
"values": "{\"unit\":\"\",\"min\":25,\"max\":255,\"scale\":0,\"step\":1}"
"code": "work_mode",
"lang_config": {
"colour": "Colour",
"scene": "Scene",
"scene_1": "Scene 1",
"scene_2": "Scene 2",
"scene_3": "Scene 3",
"scene_4": "Scene 4",
"white": "White"
"name": "Mode",
"type": "Enum",
"values": "{\"range\":[\"white\",\"colour\",\"scene\",\"scene_1\",\"scene_2\",\"scene_3\",\"scene_4\"]}"
"code": "colour_data",
"lang_config": {
"unit": ""
"name": "Colour Data",
"type": "Json",
"values": "{\"h\":{\"min\":1,\"scale\":0,\"unit\":\"\",\"max\":360,\"step\":1},\"s\":{\"min\":1,\"scale\":0,\"unit\":\"\",\"max\":255,\"step\":1},\"v\":{\"min\":1,\"scale\":0,\"unit\":\"\",\"max\":255,\"step\":1}}"
"code": "scene_data",
"lang_config": {
"unit": ""
"name": "Scene Data",
"type": "Json",
"code": "flash_scene_1",
"lang_config": {
"unit": ""
"name": "Soft",
"type": "Json",
"code": "flash_scene_2",
"lang_config": {
"unit": ""
"name": "Colourful",
"type": "Json",
"code": "flash_scene_3",
"lang_config": {
"unit": ""
"name": "Exciting",
"type": "Json",
"code": "flash_scene_4",
"lang_config": {
"unit": ""
"name": "Wonderful",
"type": "Json",
"code": "switch",
"lang_config": {
"false": "OFF",
"true": "ON"
"name": "switch name",
"type": "Boolean",
"values": "{}"
"code": "countdown_1",
"lang_config": {
"unit": "s"
"name": "countdown",
"type": "Integer",
"values": "{\"unit\":\"s\",\"min\":0,\"max\":86400,\"scale\":0,\"step\":1}"
"status": [
"lang_config": {
"false": "OFF",
"true": "ON"
"name": "Led Name",
"type": "Boolean",
"values": "{}"
"lang_config": {
"colour": "Colour",
"scene": "Scene",
"white": "White"
"name": "Mode",
"type": "Enum",
"lang_config": {
"unit": ""
"name": "Bright",
"type": "Integer",
"lang_config": {
"unit": ""
"type": "Json",
"lang_config": {
"unit": ""
"type": "Json",
"lang_config": {
"unit": ""
"name": "Soft",
"type": "Json",
"lang_config": {
"unit": ""
"type": "Json",
"lang_config": {
"unit": ""
"name": "Exciting",
"type": "Json",
"lang_config": {
"unit": ""
"type": "Json",
"code": "switch",
"lang_config": {
"false": "OFF",
"true": "ON"
"type": "Boolean",
"values": "{}"
"code": "cur_current",
"lang_config": {
"unit": "mA"
"name": "Current",
"type": "Integer",
"values": "{\"unit\":\"mA\",\"min\":0,\"max\":30000,\"scale\":0,\"step\":1}"
"code": "cur_power",
"lang_config": {
"unit": "W"
"name": "Power",
"type": "Integer",
"values": "{\"unit\":\"W\",\"min\":0,\"max\":50000,\"scale\":0,\"step\":1}"
"code": "cur_voltage",
"lang_config": {
"unit": "V"
"name": "Voltage",
"type": "Integer",
"values": "{\"unit\":\"V\",\"min\":0,\"max\":2500,\"scale\":0,\"step\":1}"
"lang_config": {
"unit": "s"
"type": "Integer",
"success": true,
"t": 1664122164154,
"tid": "6bf0048a3cec11ed9f8a22dacb9008b9"
You could try with a virtual socket with measuring enabled? This “replaces” your original socket (move it to a zone with a name like z_donottouch, so it is kind of hidden)
I made a complete flowset plus virtual socket for this issue, you can import it right away:
Wow! That looks promising. Will buy Advanced flow and will test is out.
I have tested it and it works, but not the way I want… but i gives me the possibility to do what I want.
I need to link the lights off action to the power off action.
Is it oke for you if I shared a little changed flow in The Flow Exchange(r) - Exchange Your Flows with Others! - #18 by Peter_Kawa?
Again thanks for the nice flow your created!!
Of course it is okay
I managed to get it all working thanks to @Peter_Kawa.
See my solution: The Flow Exchange(r) - Exchange Your Flows with Others! - #20 by Frekel
And again a big thanks to @Peter_Kawa for this excellent flow I just needed to tweak
Nice to hear, Frekel!
A little housekeeping, would you be so kind to cut & paste your post into this topic?: https://community.homey.app/t/share-your-device-advanced-virtual-devices-from-device-capabilities/68676
@Jurgen_Heine Thanks for developing this great app. Recently I tried to integrate the Tuya Wi-Fi presence into Homey, but I found that the status in Homey app won’t change while it function normally in smart life app, I can see the status change. I look into the Tuya IoT platform and I can’t find any timing options for status push.
The only option to make the status change in Homey is to restart the app, and it will get the latest status from Tuya cloud. But after that, the status is keeping the same.
May I know if know any specific reason why it can’t update in the homey app? Thanks
Does it send text events maybe?
Try this:
Just ignored this question, I found the issue, I dont have device status notification API added into Tuya cloud project
Hi Jurgen
I had to restore my homey today and suddenly i get the message Missing Capability Listener: onOff when I try to turn a plug (Tuya) on.
When i try to turn on a tuya light i get no response
When i use the tuya app i have no issues
I am on the official API
Homey app 6.11.5.956
Tuya app 1.1.12
I tried: different wifi channels…
Restore and reboot
Seams like i have no connection to tuya at all
a00c91a8-bdf2-49a6-b833-73987cfd74dc
According to log is this because the cloud development trial is expired. See this in more logs starting last week. A couple of weeks ago I got myself a e-mail that I had to log in on portal otherwise the account get’s expired.
Tnx Jurgen, again as swift as always. Now i have to figur out how to renew
Let me know if you solve it.
Same behavior overhere. I only did not restore my homey. Everything just stopped working while I didn’t change anything.
I also get no error message when switching lights and missing capability listener when switching plugs. All devices can still be operated via smartlive app and all devices are available in tuya iot cloud.
I logged in in the iot cloud but that does not fix the problem.
