I compared this setting with a device using no scale factor.
temp_set	Integer
  "unit": "℃",
  "min": 18,
  "max": 30,
  "scale": 0,
  "step": 1
This device only uses integer values without decimals. I thinks that’s why it doesn’t use a scale factor.
In this examplemple, the “scale” option is 0. So it seems, it represents the scaling factor for the values (10^scale).
I’m wondering if it could be device dependent (with/without decimals).
