[APP][Pro] Tuya Cloud - This app allows you to connect Homey to the Tuya cloud
Hi @Jurgen_Heine,
I have a Tuya 3 Button Wall Switch (S603) which works great with Homey Tuya Cloud App. I’m only not able to use it with the existing flow cards. I receive the following error when I try to use a trigger IF card and try to select the right switch button.
I can work around this with RAW commands (and virtual devices if needed), but using the default flow cards would be great.
The device has the following device capabilities.
It would be great if you can look into this and if this can be fixed.
Best Regards, Hugo
Does anyone know how to get the Ped Feeder working with homey through the Tuya Cloud
Hi Hugo, the app isn’t maintained, but when you/someone can fix the code per PR, Jurgen will update the app and publish it.
Yes, read post #1 and look for ‘tap-to-run’ scenes’ and/or ‘RAW Commands’
Hi @Jurgen_Heine
I’ve 4 smart curtain.m motors added with Tuya cloud app but when I manually input down or up in honey the state will not updated
Is this a known error so yes is there a fix ?
Ik heb net dit geweldige item op AliExpress gevonden. Bekijk het nu! €59,23 40% Off | Avatto Wifi Smart Rolgordijnen Motor,Tuya Wifi Elektrische Sluiter Gordijn Motor, remote Voice Control Werk Met Alexa/Google Thuis
https://a.aliexpress.com/_ExWbX6T
Hi Peter, thank for pointing me the right direction, I have got the Ped Feeder working through this option
Nice! Thanks for sharing the flow.
Is there any way to expose Tuya group devices to Homey? When linking the Smart Life app in the Tuya Cloud UI, it only linked the 6 bulbs of my lamp, but not the group device I had created in Smart Life to control them together as a single lamp.
And of course, since Homey doesn’t supporting hiding devices, I’m left with those 6 bulbs cluttering up my Homey UI, and having to create a new device in Homey.
I’m happy to submit changes to the GitHub repo if someone points me in the right direction. I guess the first step would be to somehow have the Tuya Cloud link the group device?
I guess you will need to create a group in Homey for that, for instance with the Group App: < groep > App voor Homey | Homey
Also, you can create a few tap-to-run scenes for the grouped lights device in the Tuya Smart app.
@ Homey, you can then command these scenes.
I bought a temperature & humidity sensor at Temu and it was connected easily to the Smartlife app. Unfortunately it can’t be connected with the Tuya cloud app yet.
I hope the device can be added.
Info from the Tuya platform.
Product Name - WiFi Temperature & Humidity
Device ID - bfa483292bb6eec1d7egyz
Product Category - wsdcg
The device is discontinued at Tuma so all I can show is this image.
Capture_1001
Thanks.
@Heula I have one, and it is working perfectly :slight_smile:
@RezaRose As what device did you add it in Homey?
As temperature with tuya cloud app
It seems that temperature sensors are not supported anymore.
I have tried several of these devices but all of them show no devices found.
I have Ledvion GU10 spots configured in the smart things app, and connected with the Tuya Cloud app of Homey.
Until 2 days ago everything was fine. But then my flows stopt working.
In a flow I switch the light on/off, change the temperarture of the light and change the dimming level.
The flows didn’t work anymore. Not by pushing the buttons, not by using the app.
I could turn off/on the light in the devices tap. So the connection was working.
After a while I found out that when I removed the dimming setting from the flow, it worked again.
The temperature doesn’t stop the flow, but it doesn’t change either.
Can this possably be a bug in the new version of the app?
Homey = v10.0.3
Tuya Cloud app = v1.1.23
Smart Life= 5.4.1
Sensors which aren’t recognised still can be used, with Raw Commands, it’s all in the first post.
Great stuff! Thanks a lot. It works like a charm on the new homey pro with Hombli lights
I got this message today, any who can tell me what this mean and how to solve this?
HP23
Did you read the first post of this thread?
