Another rate limited datapoint here. Have 2 Tesla’s connected via the Homey Tesla App. One using the Tesla Vehicle Command proxy and one using the REST-API. Both vehicles experience a rate limit. Online polling was set to 1 minute, but I changed that to 5 minutes for now based on the previous experiences in this thread. I don’t use polling in my flows; all my (car) flows are event driven.
I’m also using TeslaFi on one of these cars (using Tesla’s Fleet API), and that one is still succesfully connected.
Also noticed ‘rate limited’ this morning. Checked ‘API rate limit’ and is 0.65% maximum in June. Car is not used for a week. Besides Homey and Tesla app nothing else is connected.
The. app internal counter is only counting commands.
The rate limit issue is caused by Tesla FleetAPI.
You can try 5min online interval to stay below the limit.
Downloaded this app 2 days ago and everything seemed ok until last night. Have uninstalled and reinstalled, but cannot connect to the car. What is wrong?
Thanks,
I think the suspicion is confirmed
It seems the rate limit is 300 requests and the reset is at 0:00 UTC.
19h and 50min are about 300 calls at 4min.
Reset at 0:00 UTC, 2:00 am for you.
How does the triggers actually work when there’s a polling api? If Tesla had a streaming API it would make sense to have triggers like “location changed” and “gear state changed” but when polling e.g every five minutes, will the Homey then receive all events emitted from the car?
No, all is polling based.
Gear, power etc. is only for the current moment.
Locaction leaved/reached is calculated based on old/current coordinates (crossing the geofence). This means, you get a flow trigger after a request if the geofence is crossed since the last request.
Thanks! Had a perfect flow where the garage would open when the car arrived and close when it left, but with polling only every 4-5min it’s easier to just push the opener than wait for the next call🤓 Hope Tesla changes this -
In the meantime, I’ll try to make it work with user presence…
Anyone else experiencing this odd behaviour with tyre pressure data? My car is set at using pressure in “bar”, but sometimes it seems psi data is received, and then back to bar
