balmli
April 3, 2020, 6:28am
1
Systemair support for Athom Homey
With this app and a Systemair Z-wave adapter or a Systemair Internet access module (IAM), you can control your Systemair HVAC.
You can control the set point temperature, set the fan mode and mode.
Device: Systemair IAM Modbus
This device supports the Systemair Internet Access Module in “Modbus TCP” converter mode.
See the Systemair Internet Access Module (IAM) user manual for setting the IAM to Modbus TCP converter mode.
Triggers
Set point temperature was changed
Temperature changed
Humidity changed
Fan mode changed
Mode changed
The extract air temperature changed
The outdoor air temperature changed
The overheat temperature changed
The supply air temperature changed
Alarm activated (Alarm code, Alarm description)
Specific alarm activated (Alarm code, Alarm description)
Function activated (Function code, Function description)
Function deactivated (Function code, Function description)
Specific function activated (Function code, Function description)
Specific function deactivated (Function code, Function description)
Conditions
Fan mode is/isn’t
Mode is/isn’t
Alarm is/isn’t active
Function is/isn’t active
ECO mode enabled/disabled
Actions
Set temperature
Set fan mode
Set mode
Initiate away mode
Initiate crowded mode
Initiate fireplace mode
Initiate holiday mode
Initiate refresh mode
Enable/disable ECO mode
Capabilities
Target temperature
Temperature
Mode
Fan mode
Supply air temperature
Extract air temperature
Outdoor air temperature
Overheat temperature
Humidity
Days before filter replacement
Extract air fan regulation speed
Extract air fan RPM
Supply air fan regulation speed
Supply air fan RPM
ECO mode
Device: Systemair Z-wave
This devices supports the Systemair Z-wave adapter.
Triggers
Actions
Set fan mode
Set mode
Initiate boost mode
Disclaimer:
Use at your own risk. I accept no responsibility for any damages caused by using this app.
Release Notes:
1.5.0
Added option to go back to previous fan mode
1.4.4
Support for Systemair IAM in Modbus TCP converter mode
1.3.4
Added option for Temperature report interval
1.3.3
Actions are handled sequentially.
1.3.1
Added capability, condition and action card for ‘ECO mode’.
Removed ‘Off’ as fan mode.
1.2.1
1.2.0
Fixes after changes to the logon method
1.1.2
Changed minimum target temperature to 12 °C
1.1.1
1.1.0
Added ‘Specific alarm activated’ trigger
Added ‘Function activated’, ‘Specific function activated’, ‘Function deactivated’ and ‘Specific function deactivated’ triggers
Added ‘Function is/isn’t active’ condition
Added capabilities for extract and supply fan speeds
Removed ‘Cooker hood changed’ trigger
1.0.2
1.0.1
Added “Days before filter replacement”
Swapped order for Overheat temperature and Humidity
1.0.0
Added support for cooker hoods
Added capability for overheat temperature
Added capability for days before filter replacement
Updated to firmware 5.0.0
balmli
April 6, 2020, 9:20am
2
To be able to view Mode and Fan mode, the device must be reinstalled.
Amund
April 7, 2020, 7:16am
3
Is it possible to have exhaust air temperature visible in the app - and also as a sensor? I control my system with the temperature of the extracted air. Thanks:-) God påske!
Amund
April 12, 2020, 6:51pm
5
And when activating boost mode - it goes to manual (visible in the systemair app) AND does not revert to Auto after end of boost time. I wonder why?
balmli
April 13, 2020, 4:56am
6
Version 0.9.8 ready for test:
Systemair IAM Cloud: added Extract air temperature
Systemair IAM Cloud: added Outdoor, Supply and Extract temperature changed triggers!
balmli
April 13, 2020, 4:59am
7
The current “boost mode” implementation stores the mode (auto / manual) and the fan mode when the boost mode is activated.
When the period for the boost mode is over, the mode and fan mode are set back to the state they had.
But, this can easily be changed of course
Amund
April 13, 2020, 6:59am
8
OK!
That sounds good - then I must try again to see if that works
I do want it to go back to the previous state
Thanks!
balmli
April 16, 2020, 9:10pm
9
Does extract air temp work as expected, @Amund ?
Amund
April 16, 2020, 10:16pm
10
Yes indeed!
I’m working with a friend to really connect the systemair with the NIBE water-water and all of the temperature sensors in the house.
This app was the last bit missing.
Thank you!
I see that the app is slow on updating the fan state.
Takk! Amund
balmli
April 17, 2020, 6:03am
11
It’s possible to change the polling interval from Advanced settings. The default is 30 seconds. You can set the minimum, if you want, to 10 seconds.
Amund
April 19, 2020, 5:25pm
12
OK! As you see the mode and fan speed updates are not updating - the other values are as expected
See picture:
Amund
June 9, 2020, 2:24pm
14
Very good app!
The fan speed is not updating.
Is this a known problem?
Thanks!
Hei!
Status oppdateres - men viftehastighet vil ikke oppdatere.
Er det et kjent problem?
Veldig bra app ellers!
Mvh
Amund
Caseda
June 9, 2020, 2:30pm
15
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you. If you would rather not or can’t communicate in English then please check out Non-English boards at
https://community.homey.app/c/non-english
balmli
June 10, 2020, 7:28am
16
OK, thanks.
I will have a look at the issue.
balmli
June 15, 2020, 9:27am
17
Can you go to https://developer.athom.com/tools/devices and search for the systemair device.
Check the last updated for systemair_fan_mode_iam and systemair_fan_mode_iam_ro.
Amund
June 15, 2020, 7:46pm
18
Yes:
2 weeks and the other 26minutes ago.
Picture:
balmli
June 16, 2020, 5:41am
19
And systemair_fan_mode_iam and systemair_fan_mode_iam_ro does not change, if you change the speed of the fan with the Systemair app ?
What if you change the speed with the Homey app ?
@balmli : Hi
I bought the Z-Wave unit from Systemair. What values can be retrieved from the unit with the app? -All modbus? Can values also be written to the unit?
