I’m not sure if all Modbus values can be retrieved, but there’s a long list of values, yes…
Hi Ine,
Yes, I think that should be possible
V. 1.0.0 is now ready for testing.
Here’s link to the test-version:
Changes:
- Added support for cooker hoods (trigger when the cooker hood state changes)
- Added capability for overheat temperature
- Added capability for days before filter replacement (can be used as a tag: “Days before filter replacement”)
- Updated to firmware 5.0.0
Please test! I do not have Systemair myself. ![]()
V. 1.1.1 is. now ready for testing.
Changes:
- Added ‘Specific alarm activated’ trigger
- Added ‘Function activated’, ‘Specific function activated’, ‘Function deactivated’ and ‘Specific function deactivated’ triggers
- Added ‘Function is/isn’t active’ condition
- Added capabilities for extract and supply fan speeds
- Removed ‘Cooker hood changed’ trigger
- Fixes for flow titles
Thank you so much. The new functions are working as intended. These will give me much to go on. Great work!
Please let me know if the Cooker hood - function works as expected. And maybe you can test if the Vacuum cleaner - function works as well ?
I do not have a vacuum cleaner connected to the ventilation, but I can confirm that the cooker hood function works as expected.
OK, thanks!
Hi
My systemair can change the temperature to 12 °C, while in the homey systemair app can only go down to 16 °C. Can you change that so it can go down to 12 °C.
Hi Ørjan,
Yes, I will fix that
Hello
Can you please add a section for “How To install”?
I do get an autentication error when connecting to IAM Cloud Module
Check that your IAM - user is written correctly. Just upper case, maybe ?
Yes, looks like that Systemair has changed their logon method. So currently it’s not possible to log in.
Any updates to logon method.
Do I understand it correctly: is it not possible to use the app anymore?
Any plans to update the app?
Yes.
As soon as Systemair agrees to change their logon method, or creates a public API that this app can use, I will update the app.
BTW: this is a community app, not an app made by Systemair.
Thanks — your effort is much apprechiated.
I bought the IAM just to use it with Homey. Is there anywhere I can influence Systemair?
I have found a way to fix this, and will release a test version with a few days.
