[APP][Pro] Synology Surveillance Station 2
@Patrick_Spadrille I will investigate what needs to be done for that.
Thanks a lot !
Any updates on this?
@Joey_Reynecke not yet
New app update (:orange_square: TEST: 4.2.0):
Changelog:
NEW:
1: NEW: add video streaming support
FIXES:
1: None
:collision: If you find any issues, send a diagnostic report
:warning: Note: Before sending a report make sure to reproduce the issue so the issue will be visible in the report
  1. :mobile_phone: Via Homey Mobile app:
    More - apps - Synology Surveillance Station 2 - settings wheel right top - send diagnostic report (add your email to the description)
  2. :laptop: Via Homey Webapp:
    Settings wheel bottom left - Select Synology Surveillance Station 2 - Click on send diagnostic report (add your email to the description)
You can install this version by clicking the link (version number) above and press install
:fast_reverse_button: Don’t want to be part of a test version? Install the live version → Synology Surveillance Station 2 | Homey
@Joey_Reynecke @Patrick_Spadrille See the TEST version in the previous post. Can you check it out?
Make sure port 554 is open in you Synology Firewall :slight_smile:
It doesn’t work for me. it says “authentification failed”. If i click on “Try to repair”, select my Synology and then click Save, same thing. An error message saying Authentification failed, please repair Your Surveillance” Station”. The port 554 is open on my Synology Firewall.
@Patrick_Spadrille please send a diagnostic report
Here it is : 298a6f07-0a4a-43e1-a02d-16c3361521da
When I’m on our home WiFi I’ve got sound but no picture. When I’m on 5G the player fails to stream even the sound. Port 554 is open in Synology Firewall.
@Joey_Reynecke not sure I can do anything about that :stuck_out_tongue:
Only thing the app does is expose the stream from Synology to homey there’s nothing in between
And of course 5G doesn’t work it doesn’t have access to your local network right
@Patrick_Spadrille I didn’t see any issues for the authentication.
Can you restart the app and send a new report?
After updating this app i had to fill in all the credentials off the app.
Even if the app should remember the credentials.
After filling out the name, password, portnumber and ip adres off the Synology it worked again.
I just removed the camera and then add the camera again. Now it works. :grinning_face::+1:
But if I understand correctly, it won’t work when I’m away from home anyway?
@Joey_Reynecke I have to check that
In theory it should work because you remotely connect to your homey which does have acces to the local network
But not sure if that’s the case
Here it is : 262b7fc6-c365-4470-899e-45aa7f0bf832
I suspect that it might be my problem too but i don’t find the way to fill out the credentials again. Can you help me?
@Patrick_Spadrille still nothing to see
I have to say that I don’t l know the ins and outs of this app
Didn’t create it and this was my first real update to this app
So not sure how the authentication works and where you see the error
If you can give me a bit more info I might be able to help
I used for my Synology his local ip adres and for the port i used voor now 5000. I have used http.
And of course a username and password with acces to the Synology.
Now this works for me i will change setting to another port in my router.
And change it to https
Yes but how did you find a way to enter them again in the app? I don’t find a way for the app to ask me for credentials.
