Hi Adrian
I cant seem to find the Person is detected card for my Trackmix camera, but i did find it for the other 2.
And in advance settings what exactly should i change ?
Hi Adrian
The person detected capability appears when the first event occurs, as there is nothing reported to say that is available. So, if the camera doesnât have that option then it hasnât been detected.
In the advanced settings, you could try different options for the ONVIF motion setting.
It all worked till 2 days ago when the was someone at the door, the general alarm was triggered. And i created flows from this card.
But the general alarm isnât working anymore. What is wrong ??
11bfce16-83cf-4e95-bafe-1d9252e26a73
Hw: reolink wifi doorbell
Same situation here with my Reolink Doorbell Wifi. Log send!
Arrg, my bad. I changed the alarm_generic to alarm_visitor without thinking about the consequences. So sorry for the oversight on my part.
I will add it back in the next update ASAP.
It should be back in the new test version.
Thank you for the fast fix
Ive updated to the new version 29 but its still not working
Could you open the Configure App screen and select Basic Information for the diagnostic log. Then ring the doorbell to generate the event. Then send the log from the Configure App screen using the Send log button.
Is cleared the log and after I pushed the button an event was created.
I send the log
Have you checked the URLâs are still set to use HTTPS?
New test version. I hope I have found the problem. It looks like when I added the channel tokens for the NVR it messed with single cameras that donât use tokens.
Yes everything is ok right now
I also see the alarms now in the logs
Not sure when this started but all my cameraâs are not working anymore all i get is ONVIF SOAP FAULT Restarted the cams and app already no luck.
Could you set the Diagnostics log in the Configure App screen to Basic Information, wait for the errors and then send the log.
Send you the log hope your can see what up with this
I can see it is getting part way through connecting.
Has the cameraâs firmware updated recently?
Was it working?
Maybe change the log level to Full Information and repeat the report.
Hi thanks for looking into this. Yes itâs always been working had 3 cams connected. No firmware update on the cams or other changes. Homey has been updated thatâs the only thing.
Sensed the full logs maybe that tells you where to look
Thanks
Regards
Stephan Voskamp
The error is:
<?xml version="1.0" encoding="utf-8" standalone="yes" ?>
<s:Envelope
xmlns:sc="http://www.w3.org/2003/05/soap-encoding"
xmlns:s="http://www.w3.org/2003/05/soap-envelope"
xmlns:ter="http://www.onvif.org/ver10/error"
xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2"
xmlns:wsrf-bf="http://docs.oasis-open.org/wsrf/bf-2"
xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery">
<s:Body>
<s:Fault>
<s:Code>
<s:Value>s:Sender</s:Value>
<s:Subcode>
<s:Value>ter:NotAuthorized</s:Value>
</s:Subcode>
</s:Code>
<s:Reason>
<s:Text xml:lang="en">Wsse authorized time check failed.</s:Text>
</s:Reason>
</s:Fault>
</s:Body>
</s:Envelope>
But I canât see why as the time looks fine in the request:
<s:Envelope
xmlns:a="http://www.w3.org/2005/08/addressing">
<s:Header>
<a:MessageID> urn:uuid:df911ac7-5e49-9b13-79f0-87ac03f86542</a:MessageID>
<Security s:mustUnderstand="1"
xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd">
<UsernameToken>
<Username>xxxxxx</Username>
<Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">xxxxxxxxx=</Password>
<Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">DpJdYLc4f15I1cSdWhEzbw==</Nonce>
<Created
xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">2023-03-04T09:05:28.327Z
</Created>
</UsernameToken>
</Security>
</s:Header>
<s:Body
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<GetProfiles
xmlns="http://www.onvif.org/ver10/media/wsdl"/>
</s:Body>
</s:Envelope>
And the response to fetching the time is:
<s:Envelope
xmlns:tt="http://www.onvif.org/ver10/schema"
xmlns:tds="http://www.onvif.org/ver10/device/wsdl">
<s:Header/>
<s:Body>
<tds:GetSystemDateAndTimeResponse>
<tds:SystemDateAndTime>
<tt:DateTimeType>NTP</tt:DateTimeType>
<tt:DaylightSavings>true</tt:DaylightSavings>
<tt:TimeZone>
<tt:TZ>GMT+01:00PDT,M3.1.1/00:00:00,M11.1.2/00:00:00</tt:TZ>
</tt:TimeZone>
<tt:UTCDateTime>
<tt:Time>
<tt:Hour>9</tt:Hour>
<tt:Minute>5</tt:Minute>
<tt:Second>28</tt:Second>
</tt:Time>
<tt:Date>
<tt:Year>2023</tt:Year>
<tt:Month>3</tt:Month>
<tt:Day>4</tt:Day>
</tt:Date>
</tt:UTCDateTime>
<tt:LocalDateTime>
<tt:Time>
<tt:Hour>10</tt:Hour>
</tt:Time>
<tt:Date>
<tt:Day>4</tt:Day>
</tt:Date>
</tt:LocalDateTime>
</tds:SystemDateAndTime>
</tds:GetSystemDateAndTimeResponse>
</s:Body>
</s:Envelope>
So all the calls look good. One thing to try is re-enter your password in the device advance settings page of Homey.
