[APP][Pro] Starlink Monitor
Starlink Monitor
A dish that works is invisible. A dish that half works is maddening: the call drops for four seconds, the stream stalls, and by the time you go and look everything is fine again. Starlink Monitor keeps the record you never manage to keep yourself, and it keeps it on your own network, with no account and no key.
It talks to the dish directly, the same way the dish’s own diagnostics page does. Nothing goes to the cloud, nothing is sent anywhere, and it keeps working while the internet does not, which is rather the point.
What the dish reports
Capability What it tells you
Dish state Where it is in its own cycle, or what is stopping it
Download speed and Upload speed In Mb/s, as the dish measures them
Latency In ms
Packet loss In per cent
Sky obstruction How much of its view is blocked, in per cent
Satellites in view How many it can see right now
Alignment error How far off its ideal aim it sits, in degrees
Azimuth and Elevation Where it actually points
Uptime How long it has been running without a restart
Power What it draws, so it shows up in Homey Energy
Misaligned and Obstructed Alarms
The alignment figures are the ones worth dwelling on. The dish knows where it would like to point and where it is actually pointing, and it never tells you the difference. The app puts the two side by side, so the question “would moving it help, and by how much” finally has an answer instead of an opinion.
The outage log
The dish keeps its recent outages with a cause and a duration for each, and then keeps them to itself. The app reads that log and puts it on a tile: obstructed, no downlink, searching, booting, and the rest. A connection that merely feels unreliable becomes something you can look at, count, and argue with.
Widgets
Seven, so you can build the dashboard you actually want rather than the one that was built for you.
  • Dish alignment, a compass with the aim error at its centre
  • Throughput, down and up
  • Latency
  • Satellites
  • Latency, fifteen minutes, as a curve
  • Throughput, fifteen minutes, as a curve
  • Outage log, the last 5, 10 or 30 outages with their causes
Every widget takes a background: Night, Slate or Plum.
Five triggers and three conditions. No actions: the app reads the dish, it never commands it.
Triggers:
  • The alignment error rises above a threshold you set on the card
  • The latency rises above a threshold you set on the card
  • Sky obstruction rises above a threshold you set on the card
  • The download speed drops below a threshold you set on the card
  • The dish state changes
Conditions:
  • The dish is, or is not, ready
  • The dish is, or is not, misaligned
  • The alignment error is, or is not, above a threshold
Thresholds live on the Flow card rather than on the device, so the same dish can feed a gentle warning and a loud one without the two fighting over a single setting.
Settings
Setting Default
Dish address 192.168.100.1
Refresh interval 60 seconds
Misalignment threshold 10 degrees
If Homey cannot reach the dish
Worth reading before you report a bug, because this one catches people and it is not the app’s doing.
The dish answers on 192.168.100.1, which is its own little network, separate from your home one. Your router reaches it because it talks to the dish directly. Homey has to be told how, and on some routers it simply is not: the request goes out of the wrong door and comes back as unreachable.
If pairing fails with the dish unreachable while your router’s own Starlink page works perfectly, that is what has happened. A static route to 192.168.100.0/24 pointing at your Starlink router fixes it. The app’s settings page explains the case in full, and it is written for people who do not spend their evenings in a router interface.
On a single router with one internet connection this almost never comes up. On a setup with two connections and load balancing it comes up every time, which is how I found it.
No account, no key
Nothing to sign into, nothing to paste. The dish has no authentication of its own and answers anything on the local network, so the app simply asks it. Your position, your speeds and your outages stay on your Homey.
Languages
English, French, German, Spanish, Italian, Dutch.
Reporting a problem
Post here with your Homey firmware version, the app version, your dish generation, and whether your router is the Starlink one or your own. If pairing is what fails, say whether your router’s Starlink page works from the same network, because that single detail separates a routing problem from an app problem.
I have tested this on Starlink Mini; please inform me if you encounter any problem with another dish.
Feedback and testers welcome.
Have fun :wink:
Hi Henri,
I have a Standard Dish (V4 / Gen 3) and your Starlink Monitor works perfect on my Homey Pro (Early 2019).
Thank you for your work.
I did not need a static route.
Via MQTT Hub i made it also available to Home Assistant.
Starlink Monitor 1.1.0 is out. Until now the app knew what the dish was doing; it now remembers what the dish went through.
Three more widgets, ten in all:
  • Sky obstructions, the sky seen from above, with the obstructions your dish has mapped. The trees finally get a picture.
  • Availability, uptime over 24 hours, 7 and 30 days, with the number of outages and their main causes.
  • Throughput and latency trends, over the last 24 hours or 7 days.
The app keeps its own outage log, so the 7 and 30 day figures survive a restart. An unreachable dish is not counted as an outage: Homey can lose its route to the dish while your internet is perfectly fine, and I did not want the app blaming Starlink for something your router did.
Backgrounds: five instead of three. Night is now Deep blue, and Forest and Sand join Slate and Plum.
Capabilities: Availability, 24 h, Dish alert and Active alerts. The alerts are the dish’s own, thermal throttling, stuck motors, slow Ethernet and sixteen others, which it used to keep to itself.
New Flow cards
  • When: An outage started, An outage of at least [x] s ended, The 24 h availability drops below [x] %, The dish raised an alert, A dish alert cleared
  • And: The alert [x] is active
Newer dishes that only give their serial number in their status can be added again; pairing no longer calls them unreachable.
If a figure looks different from what the Starlink app shows, tell me here, with your dish generation.
More about the app, every widget and Flow card included: Starlink Monitor for Homey — Rapinology
Have fun :wink:
Starlink Monitor 1.2.0 is out. So far the app told you how the dish is doing; it now also tells you when something changes, and every indicator finally looks the part.
Icons
  • Every indicator now has its own icon, where Homey used to show a dotted placeholder.
  • The device icon shows the dish on its tripod, line-drawn like Homey’s own icons.
11 new Flow cards
  • When: packet loss rises above %, the dish stops responding, the dish responds again, the dish has restarted, the dish software has been updated (with the old and new version), the Ethernet link speed changes (0 when the link is down), the dish starts moving, the dish stops moving.
  • And: the dish responds, the sky is obstructed right now.
  • Then: refresh now, to read the dish right away instead of waiting for the next reading. If the dish does not answer, the Flow gets an error instead of a silent success.
by exemple: a push message when the dish has not answered for three minutes, and another when it is back; a note in your log each time Starlink pushes new software; on a Mini in a van or a boat, a Flow that switches your setup when you start or stop moving.
“Stops responding” waits for three readings without an answer, about three minutes with the default interval: a dish that reboots in a minute does not wake you up for nothing.
Still no reboot or stow from Homey: the dish’s local interface would allow it according to community tools, but I have not checked it on a real dish, and a Mini has no motor to stow anyway.
If a card fires when it should not, or stays silent when it should fire, tell me here with your dish generation.
Have fun :wink:
