[APP][Pro] SONOFF Zigbee
Hi.
Any idea as to why Sonoff app is recognising my thermostat as a sensor? Im not able to add it as a thermos in the Homey app?
Okay, so i installed the test app and then added my thermostat, and it actually did add it to the system, and now as a genuine Thermostat ( see pic )
However…
Nkw im not able to control the thermostat from Homey anymore, and also it doesn’t read the batteri state ( see pic ).
If i go to the bedroom and manualky control amd set the desired temperature on the device, it does report that back to the test app, but only that direction. I cant set or turn off the device from Homey.
Thats what i have for now
Update
In the Homey battery feature widget, it shows that it has 3xAA batteries, but still not the batteri level
I have a few SNZB-04 contact sensors and when i try an pair them with homey they are being detected as temperature sensors?? Anyone else had this issue and know a fix?
Thanks
I have no solution for your problem, but I had also a curious problem with a SNZB-06P, but didn’t got any feedback to fix it.
With the official Sonoff app workes everything fine. Give it a try.
Is it possible to make the new Sonoff Mini-D compatible with the official Sonoff app please?
Welcome, Daniel.
You don’t need an app in order to connect certified Matter enabled devices to Homey:
For you to find out if this device is Matter certified.
Hey
Do you currently accept PRs?
I added 1 eWelink device, maybe it can be accepted
Hi @johan_bendz are you planning to support these wall switches by any chance? ZBM5 - SONOFF Official
Thank you!
Does this app work fine next to the official app? Moving my switches to the official app will take some time and I want to try new sensors and switches only supported by the official app. I just installed the official app and experienced inconsistent behavior where switches could not be controlled anymore. Uninstalling the official app seems to have solved it. Is this expected behavior?
Is there a chance that the sonoff app will support SONOFF Zigbee Smart Water Valve?
Hi Damian,
Have you succeeded in installing the Sonoff valvle? I am considering to purchase it but I am wondering if it could be added as a general zigbee device without the specific app. Of course if it could be added to the Sonoff App that would be certainly better.
Yes, you can definitely add it as a regular zigbee device, with an on/off option. The rest of the parameters will be visible only when it is in the app, i.e. the water meter.
Hi :slight_smile: Before I buy, from Aliexpress, can anyone verify that the Sonoff SNZB-02P now works with Homey Pro 2023? I only found outdated posts that they didn’t work, but I guess they work now?
Hi, great app.
I’m curious, why there hasn’t been a release version since 0.0.29?
Almost missed that SONOFF Zigbee | Homey test version 0.0.43 supports so many additional devices meanwhile. Wouldn’t that ease accessibility?
Regards, Michael
is there a way to operate the irrigation programmer: sonoff SWV-BSP (smart water valve ) zigbee? Thanks
https://www.sonoff.nl/a-93188000/zigbee-producten/sonoff-zigbee-smart-water-valve/#description
Hi. I added support for SNZB-03 Leak sensor. With details, I made a PR to you on github containing changes to repository to add that device.
New Sonoff device released: SNZB-02LD
( Zigbee LCD Smart Thermometer (Probe Version) | SNZB-02LD - SONOFF Official )
Finally a Zigbee thermometer with probe!
Any change this device will be supported soon?
Or maybe the support is already there?
Thank You in advance!
Is is possible to have the option for the ZBMINI2L to set them in Detached Replay Mode?
Is there a chance that the sonoff app will support SNZB-02WD and SNZB-02LD ?
Regarding the 02LD:
To request support for new devices in the SONOFF Zigbee community app, refer to the instructions in the first post. Note that the developer hasn’t been active on this forum/Github recently, so not sure whether your request will be picked up soon.
