[APP][Pro] SONOFF Zigbee
The question (and answer) wasn’t specifically about Zigbee. If you just want better Zigbee, z2m is enough, and you can run it without HA just fine.
Please make all requests for new device at Github: Issues · JohanBendz/tech.sonoff · GitHub
To request support for a new device you need to:
  1. have the device
  2. complete an interview of the devices added as a Generic Zigbee device
  3. create an issue at Github and add the interview data to it
  4. add url to an image of the device
Or… code the support yourself and send me a pull request (PR) at Github :slight_smile:
// Johan
Thanks Johan,
I’ve add the interview.
We will enjoy it when you have some time to add it.
Thanks
Hi @johan_bendz, I don’t think it’s your fault, but the device icon of the ZBMicro, which was added with test version 0.0.34, is nearly unrecognizable. Would it be possible to have the icon redesigned (by Ivo Derksen)?
Hi @DirkG.
Oh… but it is… I create most icons myself :rofl:
I’ll make sure to make that one better., or even let Ivo work :smiley:
Sonoff TRVZB is available in device list of Sonoff “Official” app:
I successfully added TRVZB device to Homey Pro 2023.
A test driver is now in the Test version of the app (see first post). Please get back to me with problems or a report that it works :slight_smile:
Hi @johan_bendz
I would love to benefit from your amazing work on my Homey Bridge :grin:
Hi, I got 3 Motion Sensors SNZB-03P. But with this app it doesn’t work. The battery charge is not displayed and does not respond to movement.
Can it be fixed because in the official app, the minimum delay is 15 seconds instead of 3? Should I create an issue with the interview?
Hi, I’m new to Homey. For now, I only have a Homey Bridge. If I understand correctly, is it not possible for me to test this app since I don’t have PRO? Thanks!
That’s correct, Athom will only allow “official” apps to run on Homey Cloud/Bridge (also relevant for @Vincsz)
Hi, just wondering if anyone has been able to set up the default power on status for the 01MINIZB.
By default is always OFF which is a pitty if, for instance, you have it attached to a light, you’d want to recover the last status or ON.
It’s looks it’s doable using their gateway but I haven’t found the option in Homey, any hint on where can I start looking?
This needs to be implemented specifically in the app, so if you can’t find it in the device’s settings it’s not implemented.
Apparently it is implemented for the ZBMINIL2 (w/o neutral):
But not for the ZBMINI (w/ neutral):
Amazing, I haven’t ever tried to create an app for Homey but I think I can try to create a PR to:
:crossed_fingers: wish me luck, any help will be appreciated
Will this https://sonoff.tech/product/diy-smart-switches/zbmicro/ be supported at some point?
any chance for the ZBMINIR2 (especially detached mode).
i have a few of them at home and im willing to help!
thx and regards!
I am trying to use a motion sensor SNZB-06P.
No movement/presence is reported. A contact alarm is shown, and displayed an alarm one time after the installation in Homey.
I have also tried the official app from Sonoff. It shows presence and brightness, but the sensor reports presence uncontrollably and absence again after 1-5 minutes.
Am I missing something, or is the sensor perhaps defective?
Pro23, software current versions, firmware sensor 1.0.6
Hi, any news on implementing the ZBMINIR2.
Im even willing to borrow the developer a unit to help move things along. Adding it as a zigbee device does not give me the DETACHED MODE Options (to still make use of my installed switches)
Thank you!
Any plans for implementing support for the new displays NSPanel120PB and NSPanel120PW?
