[App][Pro] SmartThings Community (was the HCS version 2) Obsolete
Could you expand on the problems.
If you open the Apps - SmartThings2 - Configure App screen and select the Detected tab, then tap on Get Log and once the list is populated tap on Send Log.
Next, select the Log tab and enable the Diagnostics Log. Then change the mode so you get the problem and go back to the Configure App screen to send the Diagnostics Log.
