Nice to know I’m really not the only one. How long do you have your Smappe installation running already (without and with homey integration)? Maybe there’s something there in the manufacturing year or so, I have one that was originally meant for load-balancing an EVbox charger (Evbox and Smappee discontinued their collaboration soon after Smappee started their own line of chargers).
Hi all, just FYI, I’m a developer at Smappee and we are tracing issues with certain user accounts not being able to access our API due to issues with the OAuth2 authentication. So we are aware of this issue and working on getting it resolved.
First of all, thanks for creating this great app and making it available to all of us! Great work!
I couldn’t find a way to send you a DM, so I hope it’s fine to address my request to you this way…
I wonder if there is/could be a way to set the Smappee charging speed (in Ampère) from within homey. I found out the Smappee ‘smart charging’ option isn’t working correctly in combination with my home battery, so I would like to find a way to have homey set the Ampèrage (charging speed) instead, based on the power I’m injecting into the grid (measured through my Homewizard P1 meter).
There is an option in the Smappee smartphone app (slider) to set the Ampèrage of the charging station when using standard charging. Would it be possible to set this value through the Homey app as well?
If you need any information or access to my smappee station, please let me know.
Thx for this! I see you implemented the ‘Dim’ functionality on the Wall Charger, is this as a reply to my question of 27/03 (request to be able to update the maximum charging speed)?
If I implement this in a Homey flow, it changes the clarity of the LED of the wall charger, but not the maximum charging speed of the wall charger.
I hope setting the maximum charging speed is available through the Smappee API, I have no idea actually…
Hi Edwin.
Again - Thanks a lot for your help “back then” adding my “smappee plus” to the app.
I might need you assistance again
I think Smappee changed something in their API when updating there phone-app 5-7 weeks back. I also struggled with the OAUTH, but it worked again after a week or so (i wrote Smappee).
I believe the variable “Effect” now shows the total use in the house - unrelated to the production of the solarpanels. Before if was the total (enegy comsumption - solar production). Being negative if using more power that produced and so..
I have plenty flows working after this, and I can’t find the corrosponding values in Homey so that I can change it.
Is this possible to adjust anywhere?
(sorry for bringing my problems to you - but I hope it’s quite simple to answer )
Snip from phone and Homey…
2.254 (effekt) = 2.08 (house) + 0.18 (always on)
I’d really really like the 3.29 - power in/out information to be available as “Effekt” like before.
By the way… I realised that i have an extra Solid Core 3 Phase CT which is connected just after the solar edge inverters.. so my solar power is measured separate from the net, where there is also an Solid Core 3 Phase CT just behind the on/off Switch. Which measures what is coming from or going to the net.
I have installed Smappee application on Homey and added both Smappee Connect and Smappee Wall. Problem is that Smappee Connect and Smappee wall give the exact same values for power (measure_power). So I can’t actually get a clear indication for the charging power, which I really would need. Is there a way to get that properly out of it?
To my experience, the “smappee solar energymeter” integration is fragmented at best. The app developer is not to blame for this. I changed myself for a Fronius eco system.
Never mind: have un-installed the Smappee app, reinstalled it and added the EV Wall & Genius system again, but when my car is being charged, the EV Wall keeps on showing 0 W for Power consumption while I would have expected it to show the actual value that I can also see in the Smappee app itself.
I’m having the exact same thing.
My Smappee EV Wall is configured that only my card is white-listed and I’ve set up split billing.
Maybe it has something to do with that?
