[APP][Pro] SMA Energy - My home. My energy. Our climate
Well. I performed another reset and this worked as well. Me not having Sunny explorer installed (I’m a Linux Mint guy, for a year now) tried another way. Disconnect the DC side (solar panels) of the inverter, disconnect the AC side (by disabeling the fuse). Then wait a little while and reconnect all, and SMA Energy app is working fine again!
Yeah, that’s what I do in “lazy mode”. It reboots the inverter and solves it as well.
But this should best be done while dark: disconnecting DC power from active solar panels can cause huge electric arcs, which can damage or even destroy your DC switch. Not to mention risking fire.
Me too, for 20y already I guess :zany_face:
On linux you’d be able to browse to
as well. I do this on my Android phone.
Good thing you marked my solution as potential dangerous. When I was doing this there was less than 100W coming form the solar panels. But bad luck, the Energy App can’t find its way to the inverter once again, real short after I thought I’d found the solution. I’m not able to login via ip, trying to make a connection via ip the browser says itś timed out. Might be because I have an SMA inverter for 14 years now. Don’t know if they had logging in via ip at that time. I remember I had to work via Bluetooth and Sunny Explorer.
Hm. The contact from SMA Energy with the inverter has broken today for the third time. The built-in solution to repair the connection from SMA Energy also fails. Any other ideas? I have a Sunny Boy SB 5000TL-21 and the connection was stable for years. I read that latest two releases of SMA energy are trying to fix the Modbus connection failing. I think this might broke my connection. Might be a problem that I’m on port 500 and not on default 502.
Made contact with my inverter with Sunny explorer. After setting my port to default 502, my connection with SMA Energy seems fine again.
Hi @Richard_B are there any plans to add support of SMA EV charger?
I’m having trouble connecting my SMA Sunny Tripower STP 8000TL-20 to the SMA Energy app in Homey.
My setup:
  • Homey Pro 2026
  • SMA Energy app v2.10.3
  • SMA Sunny Tripower STP 8000TL-20
  • IP address: 192.168.1.187
  • Modbus TCP: enabled
  • Modbus TCP port: 502
  • Modbus Unit ID: 3
I have tested the connection using QModMaster. QModMaster connects successfully to 192.168.1.187 on port 502 and receives Modbus responses from the inverter.
However, when I try to add the inverter in Homey, it still fails with the same connection timeout.
I read that a test version was released to address similar Modbus connection issues. Unfortunately, I cannot find or access the test version; the Homey App Store only shows the public version 2.10.3, which was updated on August 12, 2026.
Could you please let me know how I can access the test version, or whether there is another solution for the STP 8000TL-20?
Thanks!
The problem still exists on app-version 2.10.3
Homey Pro (Early 2023)
Versie: 13.2.1
SUNNY TRIPOWER
Is there some setting i can tweak/adjust?
Here you go
@Richard_B I’ve noticed the following.
When I use the app for curtailment via register 40023 on a SUNNY TRIPOWER 8.0 SE, and read out the value of register 40023, it shows a different value if I write the same percentage directly via modbus. Example: if I write 75% via the app then modbus read shows: 7500. If I use modbus for writing the register it shows 75, as exepected. The inverter goes to status derating in both cases if I look in the inverter webpage directly.
Any thoughts?
@Richard_B Regarding the Energy meter / Home manager: The amps shows positive value regardless of export or import. When exporting the amps should have a negative value (the same way as the Watts).
In my opinion that’s not true.
Amps are always positive, you cant have negative.
Amps is power, not a direction.
Watt is a measurement for power. Amperes is a measurement for current. When the current flows from positive to negative pole it is a positive current, when it flows from negative to positive pole (as in loading a battery) it is a negative current, as V/R = A
In the first case the voltage difference is positive, in the second case it is negative, so the current is negative.
Yeah. P=U*I.
P can´t be negative if U and I are positive.
Other energy meters that I have used over the years like Sungrow DTSU666 displays the amps as a negative value when exporting to the grid.
I believe that also Homey Energy Dongle displays the amps as negative when exporting but dont quote me on that..
This messes with some flows. One example:
I have a flow that measures the available amps for EV Charging grom the Grid + Solar generation.
Calculation: Main Fuse(A)-(Load from energy meter(A)-Load EV Charger(A))
The problem is that when solar is generated and electricity is exported; SMA Energy Meter reports this as a load (A) which results in less available amps for the EV Charging.
Let say I have 25A main fuse and 7A of Solar generation. The available amps should be 32 A.
But with SMA´s energy meter the result becomes 25-7 = 18A.
Ofcourse you can solve this by using a more complex formula that senses the direction of the watts in this perticular energy meter but that just makes things complicated.
My STP has the option to connect a battery.
But i havent connected one, now homey always complaints about the “empty battery”.
The app shows that it’s not available. Is it a homey fault, or can i set it somewhere in the STP of this app? I’d love to get rid of the empty battery warning on the devices ( on mobile ).
Your STP Smart Energy is a hybrid inverter, so the app offers it as a battery when you pair. Without a battery attached, the charge level reads as 0%, and Homey reports that as an empty battery. Just remove the “Battery” device in Homey and keep the Inverter device, and the warning will go away.
thanks for giving a solution, but do i underststand correctly that i need to remove the inverter completely and add it again?
I don’t see an option to remove the battery, it’s one device.
The inverter device type doesnt have a measure_battery capability, but send me a diagnostic report and I’ll have a look
Thanks ( in advance )
de6472cd-ce42-4fd3-8ef0-cb5a1e02c6ff
Thanks. I’ll wait for the update :wink:
