Hi Andi, thanks for the fix to the text value, that’s now working exactly as you’d expect, and no impact to other fields / data / display as best as I can tell.
I do have a couple of other things I was hoping you could potentially look at as time allows.
First one is that if I use a Advanced VD on the dashboard, then there’s a slightly strange issue which occurs in some instances, and I’m not too sure if it’s my config of the AVD, or maybe a small defect. This is that the correct number of decimal places is not shown for some fields, but it’s hard to pin down which ones / why it doesn’t work, I can’t see the pattern. Here’s my example for Battery Energy:
you can see the “Battery Soc” has BE with 20.6, which is good, and this is the AVD config:
but on the display:
Note that i also just re-ordered the energy and SoC % so that % was first and bigger, but still 21 is shown with no dp. I realise this might be an issue with AVD and not your problem, so no stress.
The other thing I wanted to ask you about was if you have a good way of managing this situation: I control my AC zones in my house with homey and i have three zones which i can “force on”, “force off”, or “auto”, the latter which means the AC will check the temperatures in the zone and determine if the zone should be included or not. I’d really love to have a picker with “On”, “Off”, “Auto” per zone, which I’d see being selected / pressed and then run a flow to set my homey variable as such based on the selection. All of this would be perfect on the dashboard of course, but i cannot get any of your many ‘stock’ included devices to work for my situation.
I did install AVD as it has custom lists, so i thought i’d create on/off/auto and use the list, but the AVD devices don’t appear to work at all on your dashboard as buttons or selectable devices, like your built-in devices do, so that didn’t work. The closest I’ve gotten to something that works - but is really clunky - is to have the AVD showing the text value, and your 'Remote" ‘up/idle/down’ device run flows to set the AVD text based on button pushed:
in this case, ‘Stopped’ = “Auto”…but that’s pretty ugly.
Any thoughts on how this could be managed? Thanks for a great dashboard, btw, it’s really ‘clean’, easily configurable and looks great on my old AMOLED Samsung tablet:
