Hi Alex,
Thanks — all four points were valid. Three are fixed in the next TEST version: Shelly Wall Display Dashboard | Homey
1. Dimmer. Worse than it looked: the slider’s touch area was only 4 px tall, and anything you hit outside it fell through to the tile and toggled the light. So it wasn’t imprecision on your part. The touch area is now 32 px and the slider no longer passes taps to the tile.
2. Blinds. My fault — one line meant up/down/stop only appeared when a device had no position slider. Your Bond blinds report both, so you only got the slider Bond can’t act on. There’s now a Blind controls setting (Settings → Design): Slider, Buttons, or Both. Switch yours to Buttons. Default stays Slider so nobody’s setup changes underneath them. Your outdoor blinds get three real buttons regardless — so no more tap-to-reverse and no more tiny stop icon in the corner.
3. Power on tiles. No setting existed; there is one now (Settings → Design). The Energy window still shows everything.
4. Tile shape. A real bug, not yet fixed. “Height same as width” sets the height to the minimum tile width while the actual width stretches to fill the row — on my display that gives 179 × 165. I know what needs changing, it just needs care with the grid. Next on the list.
On the Homey design guidelines — fair point, and partly agreed. The constraint is the 4" screen: an overlay covers all of it, and a lot of the value here is hitting one control in passing. But colour and colour temperature genuinely don’t fit on a tile, and thermostats, locks and speakers already open their own window. Extending that to lights, and making tile behaviour configurable, is the sensible direction.
Thanks for writing this up — it shaped the last few releases directly.
Andi
