[APP][Pro] Sensibo - Air Conditioning and Quality
Contribute
If you enjoy what I do, consider supporting me on Ko-fi or Paypal! Every little bit means the world!
ko-fi
paypal-donate
Introduction
Sensibo Sky, Sensibo Air, Sensibo Pure and Sensibo Room Sensors
Installation
  1. Get an API-key from https://home.sensibo.com/me/api . On the form, enter an API key name and press the add api key button.
  2. Set the API-key during pairing of the device
Device Features
Click the :play_button: to view details.
Device: Sensibo
Models
  • Sensibo Sky
  • Sensibo Air
  • Sensibo Air Pro
Capabilities
All devices
  • On / off
  • Fan level
  • Fan mode
  • Target temperature
  • Swing
  • Horizontal swing
  • Climate React
  • Temperature
  • Humidity
  • Last seen
  • Filter clean due date
  • Filter clean due hours
  • Filter run hours
Air Pro devices
  • CO2
  • TVOC
  • Inside Air Quality Score
Flow cards: When - Triggers
  • The target temperature changed
  • Thermostat mode changed
  • The temperature changed
  • The humidity changed
  • Device turned on
  • Device turned off
  • Device offline
  • Timer created
  • Timer fired
  • Timer deleted
  • AC state changed
  • Climate React changed
  • Filter alarm changed
Flow cards: And - Conditions
  • Thermostat mode is
  • Is on
  • Climate React is enabled / disabled
  • Timer is enabled / disabled
Flow cards: Then - Actions
  • Set the temperature
  • Set the mode (Automatic, Heat, Cool, Off)
  • Turn on
  • Turn off
  • Set the fan mode
  • Set the fan level
  • Set Swing mode
  • Set Horizontal swing mode
  • Control Climate React
  • Control Pure Boost
  • Control light
  • Sync power state
  • Set timer
  • Delete timer
Device: Sensibo Pure
Capabilities
  • On / off
  • Fan level
  • Temperature
  • Humidity
  • Last seen
  • Filter run hours
  • Device turned on
  • Device turned off
  • Air quality changed
  • Device offline
  • Timer created
  • Timer fired
  • Timer deleted
  • Is on
  • Turn on
  • Turn off
  • Set the fan level
  • Control light
  • Set timer
  • Delete timer
Device: Sensibo Room Sensor
Capabilities
  • Temperature
  • Humidity
  • Battery
  • Last seen
  • The battery level changed
  • Device offline
Device: Sensibo Elements
Capabilities
  • Temperature
  • Humidity
  • CO2
  • PM2.5
  • TVOC
  • Ethanol
  • Last seen
  • The CO2 changed
  • The PM2.5 changed
  • The TVOC changed
  • The Ethanol changed
  • The Inside Air Quality Score changed
  • Device offline changed
Useful links
Reserved for future
FAQ - Frequently asked questions
No devices found with a new API-key
If you have just created the API-key, the Sensibo API might return an empty list. Try again after a few minutes.
TODO - Features Requested
If you would like to request a feature to this app, please open a feature request at Github.
Known Issues
Why isn’t it possible to set fan mode? I can tell Google assistant to set cool, heat and auto but not fan.
Yes, I guess that’s not possible in the current version of the app.
It’s possible to set the fan mode with a flow.
Yes I am aware of that but it had been nice to do this on the thermostat :slightly_smiling_face:
Google home only supports the 3 modes: cool, heat and auto, any other modes are not supported, nothing we can do about that as it is a Google home limitation (Amazon Echo and Homekit have this same limitation)
Great app, one of the most usefull i came across. Sensibo and Homey combination makes it completely endless as for possibility’s.
Had mine working within minutes. I’ve got an Haier Airco that can be controlled by an app using a USB Wifi interface. This worked for 3 years but it’s an crappy app and they didn’t want to share the API etc for me to build an app. I removed the wireless interface and used the USB port to power the Sensibo. Routed the USB cable within the airco and the Sensibo on the side.
One question though… My Haier only supports vertical swing, not horizontal. There is no way i can control this direction with your app. Any idea why? Ik errors with code 450, probably because horizontal swing is not in use with this airco.
Thanks.
Can you control the swing from the Sensibo app?
Yes, tried it and vertical swing works. Upper position, down position, stop and swing continuously.
This is the current list of swing modes that are supported:
Fixed bottom
Fixed middle bottom
Fixed middle top
Fixed middle
Fixed top
Range bottom
Range full
Range middle
Range top
Stopped
I know… but the way the app/contols are build it is selecting every mode that comes by. Mine only looks to have fixed top, range full and stop. It errors as soon as an other one had passed
But you can set the swing with a flow ?
Yes i can, but the controls from your app are very nice. Can’t you use another control way for the swing? Not all aircos have all functions
I will create a fix for this:
  • support “Horizontal” and “Both” swing modes
  • check that the selected swing mode is among the supported swing modes for the device
Here is v. 1.2.1 ready for testing.
V. 1.3.0 with support for Climate React is now ready for testing:
Amazing work! Thank you for your contribution. Climate React is a killer feature for Sensibo and now we can schedule CR which is what the sensibo app cannot do.
