[APP][PRO] Samsung Wireless Audio Multiroom
i have some strange problems since homey update to version 6.
The power off option seems not to be working anymore or when it works with a huge delay.
The other commands (source, volume etc) work fine/ normal, only the power function not.
The result is some flows do not work and when that the sound bar turns itself ON again when turned on by remote (reported a while a go).
I fixed that issue when my harmony remote turns everything OFF (and homey detects this) i also gave power down via this app (so soundbar stays off), when i do not do this then for unknown reasons the soundbar is turned on again by the app, as long until you turn it off by the app also.
But when used in a flow then the power state is NOT detected anymore since homey v6.0.
Hopefully this can be fixed soon.
Is there a way to just force a device being made, it says it doesnt find a system on my ip but when i surf to: http://10.1.1.18:56001/UIC?cmd=<name>SetFunc</name><p%20type="str"%20name="function"%20val="hdmi1"/>
Q950T
it changes input so something must work right…
  • I Deleted the app an reinstalled … all fine now! –
anyone testet the “play URL Audio” function?
i tried it but it dont work on my homey. (Not Pro)
every Else works!
nice App!
Is it possible to add samsung soundbar Q700A?
It will not work when I add those at the manual way.
Thanks
V. 1.0.1 with SDK3, ready for **Homey Pro (Early 2023).
Click on this link to install the test-version:
Please test.
Since a couple of weeks i get the error timeout. Normaly it works good. But now no more sound. It says it is on but there is no sound.
Restarted the app multibale times. Please advise thnx
I don’t know if balmli changed this since your post, but for me this device works on port 56001.
I have the same problem. Timeout error. Still no solution?
Any luck adding Q995C?
Please add support for a samsung Q990C soundbar
Today I added the Samsung HW-Q80R soundbar to Homey with the use of this app.
Port setting 56001.
Remote control response time in Homey (e.g. volume or input channel) is super fast.
Thanks!
Hi, Alex
Can you add HW-Q990C
Hi Walter,
I’m not the app creator. @balmli is the app creator. Maybe he can help you with your series soundbar.
In my post I only confirmed the Samsung HW-Q80R soundbar connects to Homey with this app.
Thanks
Hi Walter
It appears that the HW-Q990C is now controlled via SmartThings, so you would need to contact the developer (Athom) of the app to ask if they can implement the soundbar.
As a workaround until then, you can control the soundbar via Home Assistant.
Chris
https://9to5toys.com/2023/10/05/samsung-smartthings-hubs-software-update/
I have found a better solution.
Just try the “new” SmartThings Community app, it seems to work, but I haven’t been able to test it extensively yet…
Indeed, you are right, it works with this app. Thank you very much for your help.
How do I find the ip address on my soundbar?
You can log in to your routers settings and find it there. Doesn’t seem to show in the smarthings app
Hello :slightly_smiling_face: I have a Samsung Soundbar Q800T, which is connected to a Samsung TV and to Homey Pro. I have given it a fixed IP and also added it to Homey manually with IP. I can control the sound, but not the status. I cannot turn it on or off nor can I see if it is on or off. Can the problem be solved?
Problem with the soundbar solved. :partying_face:
I used the app “Samsung SmartThings Community” instead as @ChrisG suggested earlier.
“Samsung SmartThings” didn’t work, but “Samsung SmartThings Community” did. :+1:
None of them worked with our TV, buth the last one worked with the soundbar.
Both apps found the TV, but didn’t work.
“Samsung Smart TV” works very well with our new TV. :+1:
