[APP][Pro] Samsung SmartTV
Ok, so selecting the “Approve” button does not work ?
Can du access the “devices” page, and search for “samung”:
https://developer.athom.com/tools/devices
At check what’s under “settings”
Samsung TV
Properties
Property Value
ID XXXXXXXXXXXXXXXXXXXXXXXXXXX
Class tv
Driver homey:app:com.samsung.smart — Samsung
Ready Yes
Available Yes
Custom icon No
Settings
Key Value
ipaddress “192.x.x.x”
mac_address “xxxxxxxxxxxxx”
Capabilities
Capability Type Value Edit value Last Updated
onoff boolean false truefalse 45 minutes ago
volume_mute boolean null truefalse 2 hours ago
volume_up boolean null truefalse
volume_down boolean null truefalse
channel_up boolean null truefalse
channel_down boolean null truefalse
@Aart_Hardeman After upgrading to v. 1.0.3 you need to reinstall the Samsung device. Sorry about that.
I have the same issue.
Did you reinstall the device ?
I tried this with HTTP://tv ip adres:55000/
Still no response
(I did not put < before ip adres)
Is there an option to detect the right port?)
OK. The address would be something like http://192.168.1.15:55000/
Always have the text to accept the homey on the tv. I have accept always in tv settings.
@Jesse_dg You have reinstalled after upgraded to v. 1.0.3?
Can you also check settings if you search for “samsung” in https://developer.athom.com/tools/devices ?
I tried that with my adres.
I did run a nmap on my rasperry
None of the Ports did work out
80
443
4443
6000
7676
I did check my tv modell
UE46F8000SLXXN
I’m having the same problem. It keeps asking for permission. I re installed my TV using the app after updating to v1.0.3.
This is what I see in developertools:
OK, thanks. I can see that the auth token is not stored in settings, as it should be.
I updated the app.
Reinstalled my tv.
But it connects with the homey, but functions do not work.
Not even on or off, i also do not get any errors.
Developer mode on or off didn’t make any difference.
Heres the result of the link:
“id”: “uuid:f58a5776-d5a4-45db-9094-e04abfc4d876”,
“name”: “[TV] UE55JU7000”,
“version”: “2.0.25”,
“device”: {
“type”: “Samsung SmartTV”,
“duid”: “uuid:f58a5776-d5a4-45db-9094-e04abfc4d876”,
“model”: “15_HAWKM_UHD”,
“modelName”: “UE55JU7000”,
“description”: “Samsung DTV RCR”,
“networkType”: “wired”,
“ssid”: “”,
“ip”: “192.168.178.113”,
“firmwareVersion”: “Unknown”,
“udn”: “uuid:f58a5776-d5a4-45db-9094-e04abfc4d876”,
“resolution”: “1920x1080”,
“countryCode”: “NL”,
“msfVersion”: “2.0.25”,
“smartHubAgreement”: “true”,
“wifiMac”: “fc:8f:90:d6:4d:39”,
“developerMode”: “0”,
“developerIP”: “192.168.178.95”
“uri”: “http://192.168.178.113:8001/api/v2/
I hope its useful to you.
If you need any more let me know!
And this is what developer mode from the homey says.
TV] UE55JU7000
Properties
Property Value
ID 898f4669-7ee7-4c2d-83cf-afaf5ae28e6c
Class tv
Ready Yes
Available Yes
Custom icon No
Settings
Key Value
ipaddress “192.168.178.113”
tokenAuthSupport false
mac_address “fc:8f:90:d6:4d:39”
Capabilities
onoff boolean true truefalse 7 minutes ago
volume_mute boolean true truefalse 12 minutes ago
@balmli
Do you have any idea what all the keys do?
Thanks
Well, just a few of them …
And not every key will work on the TV, in every situation.
Think you’ll have to test…
For newer 2018+ models, if you had trouble with version 1.0.3:
Check out version 1.0.5 of the app, in app store now.
Tv verwijderd en opnieuw toegevoegd en lijkt nu wel goed te werken! Top gedaan!
That’s good to hear :slight_smile: Fijn weekend
