First and foremost, great job! This was the last thing in my house that i needed to integrate with Homey, and it has now been tested since September without any errors or failures.
My room sensors are not on the list, but they work without any issues. Is there a reason why you need to select a type, as it doesnt seem to make any difference?
The only thing im missing is the ability to change the status indicator to the current temperature rather than the target temperature. Would it be possible to change this in a future update?
Hi, this may be an odd question here, but is there a possibility to combine the Touchline SL and Elko One Matter thermostat without using a Roth termostat as “master”?
Background, I have an old Roth system, which I will upgrade to Touchline SL and I plan to upgrade to use the new Elko One series for button and dimmers. They have a thermostat that fits and that can instrument homey to turn on heating/cooling on the Touchline SL wifi module. Would be nice if I could connect homey directly to the wifi-module instead of a Roth thermostat, is that possible?
Tried to talk to Roth today, without a clear guidance on how to approach this problem, thus my question here
Hi, when I try to log in with my Roth username and password, I immediately gets “The entered user information is invalid.”
I have a new Roth Touchline SL with SW version 1.0.15 and I can login to the Roth app with the same user/password.
PS. I tested on another site I have, that has Homey PRO 2023 (SW 14.4.1) and there I could log in and add devices without problems. In my home where login fail (and where I have Roth devices…) I have a Homey PRO Early 2019 with SW ver. 12.4.0
Any help would be great
Hi.
Will this app work with the whole SL system? Can I use radiator thermostats also? Guess it some how still are controlled through the central unit?
Thanks for the app Peter
! Is it possible to ask for access to the Github repo as well? Username is: skjelmo
